TurboEuro88
Hey there! The name is Tony and by day I am an IT Systems Admin, by night a huge car nut who loves his Audis more than he rightfully should. Been a long time lurker of this wonderful corner of the internet and have waited for the day I could finally post my own space here. Bought my first home back in May and have been spending the time since setting things up inside the way I like and generally adjusting to a fully independent bachelor life. Now that I've got most everything settled in, it was time to begin focusing on the biggest reason I bought my house - the 2 car garage.
Here is my little slice of heaven that I'll be renovating into a true space for me to store, clean, and work on my cars. And to also serve as a place for me and my friends to hang out. It's nothing special - Just a ~480sqft detached garage built in the mid-70s. But to me its a space to myself for my cars and where I have an opportunity to build it out the way I want.
The biggest issue facing me is the concrete - It's not in the best of conditions, but all things considered it's held up great since it was poured 40-some years ago. That said, I've done my research and unfortunately a repour is out of the question - the foundation and floor are one continuous pour and thus would be very difficult to replace. Instead I am going to plan for a full repair and epoxy. I've already been communicating with a local installer about the job, working out what would be needed to get this back to a nice, smooth working surface. Mostly waiting for funds to align to make it happen and, if all goes well, should happen while I have the place gutted during the renovations.
Another major problem that I'll be addressing is the electrical. Currently the entire garage is serviced by a simple 12/2 20A circuit. Needless to say that isn't going to cut it. Not one bit. Not when I am going to putting in some serious lighting, plus an electric heater, compressor, etc. The major hurdle at the moment is how I am going to run this line. Currently the 20A line comes out of the house and goes under my deck stairs in a 1/2" conduit. This needs to be replaced with a 6/3 line so I can install a full subpanel in the garage, but doing so will require a new conduit run for the wires to run in. After pulling a stair to get a better view, my only real option that I can see is to remove the stairs entirely to get better access to run the conduit. Not ideal... but luckily not a huge inconvenience. Unfortunately all the screws are rusted to f*ck and back, so uninstalling these stairs isn't likely to go smoothly. This is probably the biggest pain in the *** so far and it's literally the first thing that needs to be done.
That's about as far as I am right now. Overall, however, this is the basic plan for the garage at the moment. I am sure it will change to some degree...
Still haven't moved most of my tools or other equipment from my parent's house yet and won't do so until the garage is in a "near done" state. What's here is just what I need at the moment. That will likely cause a lot more work as I get bright ideas of more things to change/install. But that's half the fun of it
Here's a very amateurish CAD mock-up of how I am currently envisioning setting up the garage. You'll have to excuse some of the very rough or basic drawings, but the concept is there:
Anyway... this is my introduction and looking forward to sharing my progress. Hopefully things will speed along as long as the winter weather cooperates. Once I have the electrical done, that'll allow me to really get started inside the garage with ripping out the old and starting to install the new.
For those interested in high-res photos, you can view the album I'll be posting all the photos to here:
https://flic.kr/s/aHsmySJ7xd
- Repair concrete, lay epoxy coating
- Run a new 6/3 feed from a new dual-pole 60A breaker in the main breaker panel to a new 16-space subpanel in garage.
- Remove all existing wiring and lighting
- Install x10 5200lm 4' LED fixtures
- New interior outlets, exterior GFCI outlets
- New LED outdoor Motion-sensor spot light
- New exterior lights
- CAT6 Ethernet w/ new Ubiquiti access point
- Custom corner workbench
- Cabinets, etc.
- Walls/roof insulated (more on that later)
- Insulate garage door
- New steel man door that opens the correct way
- Liftmaster 8500
- New air compessor (make/model TBD)
- Mounted TV (possibly with in-wall speakers?)
- Build loft "space" for overhead storage
- Drywall, painting, misc finishing work
