New upgraded HF Parts Washer
LeeG
Phoenix, AZ
There have been plenty of times I could have used a parts washer in the past, but I always got by with spray bottles and rolls of shop towels. I was inspired by a video by Jay Dighsx. His improvements on the Harbor Freight 20 gallon parts washer went a long ways toward what I wanted. The only thing his build didn't have that I needed was the ability to move it to my backyard over packed quarter-minus - a moving dolly wasn't going to cut it.
I started by welding up a new base using 1″ 16 gauge square tubing. I cut gussets for each corner from some 16 gauge mild steel, and used some scrap expanded mesh for the bottom shelf. The wheels are basic 6″ lawn mower wheels from Harbor Freight. I made the base high enough that the solvent barrel below it would have about 4″ of clearance. The base is quite sturdy and doesn’t have any flex during movement.
I wanted to be able to easily move it, so I found some steel tube that was a slip fit for a piece of 1/2″ schedule 40 galvanized pipe and welded it to the top of the base. This allows me to collapse the handles in so it takes less space when not in use. To move it around, I simply pull the handles out, drop a pin in a hole drilled in the handle to prevent it from sliding back in, and maneuver it around like a wheelbarrow.
I went a little overboard on the connections side. I used brass bulkhead fittings from Amazon for each hole through the side of tub. I used the same pump, power supply, and filter setup Jay used on his build, but I added a switch to the pump that fills the wash from the reservoir. Inside the reservoir, I have a filter and a piece of PEX tubing that extends down to about 1″ – 2″ off the bottom. This allows for the gunk to settle to the bottom and not be brought back in when I refill.
Overall I am quite pleased with how it all turned out. It was a bit of a pain getting all of the components, and I spent way more than I would have liked on all the brass fittings, but since this will spend a lot of its life outside, I wanted to have quality components.
For a list of the components used, check the description on Jay's video in the link above.
Lee
driftpin
Looks like some good improvements. Thanks for the post.
Between this and the mods to make the HFT blasting cabinet a vapor blaster, you could have a good pair of machines for home work.
dkmc
NYS--Upstate in the corn fields
So do you have a 2-3 gallons of water in the yellow bucket for the solvent to float on.......and the dirt to sink down into? Keeps the solvent and the filters much cleaner.
A plastic bag liner (didn't see mention of one) inside the bucket helps with clean up as well.
Super Mech
Bronx,NY
I really need to do something like this to get away from my Safety Clean machine. Way too costly with them and it doesn’t even degrease like the older chemicals did.
4EyedTurd
Texas
Parts washer and finish the sand blaster is on the list to do this year. I’ll have to remember this thread
picah
lol ... $50 worth of parts on Amazon for $90
As the famous broadcaster used to say, "and now for the rest of the story".
Let's look at the real costs. Can't even buy the oil filter relocation unit, the proper thread size drain valve, and 5 feet of "fuel rated" hose (not crappy window washer hose - real hose that will stand up to cleaning solvents) for $50 (and actually expect it to be shipped to your home). In addition, the wrong perimeter sealing strip (like cheap foam) will be eaten away by the solvent fumes and the the multiple small parts cost more to ship than to buy the parts. What is being offered is an all in one package, with all the best and correct parts that will not just fit together but provide the least restriction to solvent flow.
I tried to beat the cost of this kit. Didn't happen. If you have half of the primary parts laying around the garage already and can McGyver a few other things, then yes, absolutely you can do better. Otherwise, the convenience alone makes this a good deal for the guy who simply wants a plug and play DIY solution, with full instructions and without the hassle and 8 or 9 separate internet orders or driving all over town to find out it costs even more in the box stores and they are out of stock of the part you wanted anyway.
And that's the rest of the story. Goodnight America!
sberry
Brethren, Michigan
I am not sure about the kit but probably dump the solvent in it and see how it worked. I been around these for decades and never saw o e with all that **** on it. Now it's something that everyone thinks they got to have. Not sure why the mfg doesn't offer it up,,,.seems like it would be a great sales feature.
The wheels I understand.
Willie Makeit
lol ... dude, go pay for an ad if you are going to contribute very little to this forum other than spam ... guys here are sharper than you give them credit for.
picah
Thank you for your highly revealing comment. I give them lot's of credit and trust them to do the cost comparison for themselves with real numbers, not put out purposely misleading info in an attempt to lead them astray and have them spend more in the long run, or buy cheap parts that will fail them in the near future. The thread was about improving the standard HF parts washer. This is simply an option for those who choose to pursue it. Have a blessed day.
joe49
Tonica, Il
The Donking of HF wash tanks. If it makes you happy go for it. Me I,ll use the money to change solvent.
bulletpruf
San Antonio
Kit definitely looks overpriced to me, but I still may end up buying one. I get a lot of use out of my parts washer, so improvements are welcomed.
Speaking of improvements, my main issue with the HF unit is the doggone pump. Mine is dead. Anyone have a recommendation on a replacement?
Willie Makeit
not sure of your budget, but it's hard to go wrong with any pump by Little Giant
rattle_snake
Chandler, AZ
So it appears that the re-plumb does 2 things
1) filter solvent with spin-on filter using original pump
2) store solvent in drum below.
Is #2 just to reduce the evaporation loss and smell? Mine looses a lot of solvent to evaporation as it sits outside in 110* weather. Could a decent lid gasket solve this?
Willie Makeit
"Any" pump or any parts washer rated pump? The parts washer rated pumps go for a big premium.
since the topic of conversation is parts washers, i assumed we all understood i was suggesting a parts washer rated pump. a 300 gph little giant parts washer rated pump can be found pretty easily for less than $80.
L
LeeG
Phoenix, AZ
Justin,
I'm the OP on this. I store my parts washer outside in the AZ sun, and I don't actually use it but maybe once a month. I had 3 reasons for the storage drum. Reduce solvent loss via evaporation, lower center of gravity to make it easier to roll from my back yard to the shop area, and prevent spillage during movement. I am pretty happy with how well it works on all three accounts.
If you are not moving your washer, then I would say that a good seal around the rim would probably work ok at keeping the solvent from evaporating, but still not as well as the tank. The tank would indeed be a pain if I used the washer more often, but for occasional use, it is perfect. It only takes a few minutes to fill the main tank.
Lee
