medic583
Hello all... it's been quite awhile since I joined up here looking for information and somewhere along the way... the building of my garage/shop got put off again and again and...
Yet this year I decided I couldn't wait any longer so I'm back and the build is just beginning.
Bit of background... bought a piece of property in our rural community... a couple of acres right inside town/city limits with a couple of houses on it, town sewer/water/gas/hydro... you name it... and on the river to top it all off.
But... what I didn't know when I bought the property a dozen years ago was the fact that both houses should have been bulldozed... they were in that bad of shape.... even the property was a mess...
Yet... over the past few years I've managed to clean up the yard somewhat, rebuild and sell the rental, sell off another chunk of property and almost have my little shack completely rebuilt as well. From not knowing which end of a hammer to use to this point... well... it's been a long learning process getting to this point.
Now... after all these years.... it's garage/shop time... and I just can't wait any longer.
Best of all though... for the first time in over a dozen years... i'm hiring someone to help out... a BIG first for me. Why... simply because of time and the fact I'm not really interested in getting up on a roof this fall
Anyhow... the building itself is going to be stick framed, metal clad 30'D x 40'D with RIA trusses on 10'H walls (2 x 6) heated with an in-floor heating setup and 4inch pad.
The main 30x40 area will be divided into two basic rooms (3 if you include the little office area)... a 16W x 30D auto area lined with metal so I can weld, grind, etc... and the 24W x 30D wood area will be used for the table saws and all things wood.
Easier to show a layout I guess
So...that`s the layout for now... in the spring there will be a carport style room added to the backside for the building so I can hide the trailers and such out of the sun, yet not fully closed in just yet.
But... for now... it`s just the basics...
Looking back a few years, here are a few shots to show the changes already done...
1. The dozer hired a few years ago to fill in the swamp after I had cleaned out all the junk.
2. The building of the pad begins... sort of... hours before this shot was taken and while I could not get into my yard due to the dozer tearing it up... the contractors came to my door and said `woops` they screwed up the estimate and the cost would be double if I wanted them to continue past that point. I had no choice... they told me flat out that because their estimate was not in writing it would be father and sons word against mine and if I didn`t want them to continue that I could find someone else to put my driveway back in.
3. Well, instead of having an area 40D x 50W (so we could use scaffolding when putting the shop up) level with the driveway they just made it big enough for the 30D x 40W garage I was planning for... and even skimped out on the apron area to top it all off. YES... Lesson learned
4. The swamp is levelled from dirt in the back of the yard moved forward and the pad compacted was compacted with a highway packer... Unfortunately due to other projects which were a tad more important (weeping tile, metal roof and siding on house, windows, etc...) up until this week it was used for storage only.
Sooo... that`s the old photos... and from many, many years ago.
This summer I decided it was time to build... have talked to a couple of places about packages... have two rough estimates... and decided to call a local builder to see if he was interested in helping me out build this thing.
Sure enough... he showed up last week, recommended the cement crew that everyone seems to recommend... and the next thing I know they`re at my door wanting to start the pad on Monday morning. The framing package hasn`t even been ordered... only a week for delivery I`m told... but wow... they had a couple of days available and want to get it going.
So... here`s the form work being done this week...
Yet... there is another hold up. Our community has changed their bylaws... requiring `chairs` to be built for the footings to tie into the pad itself... so they have to be custom built in Winnipeg and should be here in two days. Yes... these are not the `chairs` we all know which support the rebar or mesh... but rebar bent to look like a `P` to ensure the weight of the walls do not push the footings down and away from the pad... a new engineering requirement.
70 `chairs` are on order... the 6mil poly is down, the 2in HD styro is roughly in place and as soon as the chairs are here we finish up the rebar and mesh and I get to lay out the PEX and they can begin the pour....
Stay tuned... will figure out what I just did to my keyboard on the laptop to make all the characters turn french instead of slashes and question marks, colons, etc... and will be posting a lot more photos as the build progresses
I do know I`m going with the Room-in-Attic trusses... throwning my leftover Hickory flooring down up there, having the access to it outside instead of taking up valuable interior floor space... and... hmm... need to think about the heating setup and what and where to get it from.
Other than that... electrical is going to be 100amp, might be able to run the Natural Gas line back to it as it comes right down the driveway currently... soo much more to think about... soo much mored to do...
Anyhow... hi all...
Anyhow... hi all...
