WWII 50 lb Alemite Grease Dispenser
I picked up this US Army Ordnance Dept grease dispenser at the flea market this morning.
It dates to WWII. It has a leak-proof lid, a pump, a 5-foot hose and a goose neck nozzle and it has been mounted on a skid with casters. The Federal Stock Number for this piece of equipment in WWII was 41-G-1425. Official nomenclature is “GUN, pump, bucket, lubricating, low pressure, with flexible hose, 25-50 pound capacity.”
These are fairly rare. I know of several in the hands of WWII Military Vehicle enthusiasts. Highly desirable item to set up near a group of vintage MV's for a WWII Living History Display at a rally or show.
They were standard issue, 1 each, in 2nd, 3rd, and 4th echelon tool-sets, as well as special Armored Forces. Mechanics would push these around the motor pool or maintenance depot like a big grease gun and use the attached hose and nozzle and extensions (two of them were tucked inside the rolling skid) to grease fittings (Zerk) like you would with a regular hand-held grease gun, or you could bring the hand pump grease guns to this pumper and refill them. Used on everything from Jeeps to the largest trucks during WWII, but these really came in handy for construction vehicles, engineers equipment, and armor, all of which had dozens of fittings.
Stewart-Warner's Alemite Division made these forever before it was passed on to other OEMs (Lincoln, GRACO, etc), and there is little difference between one made in WWII through the 90's. The "Super Grease Gun" is still in the US system as FSN 4930-00-244-4859. And of course Alemite (and Lincon, etc) made versions of these for civilian service stations as well. Newer equipment has fewer service points, of course, so these have largely been replaced by newer smaller and faster automated air or battery powered jobbies.
It was caked with old grease and grime, but I knew what it was as soon as I saw it and the “ORD 152701” marking on the neck of the pump (that is a US Army Ordnance Dept stock number) confirmed it.
Unfortunately I used a little bit too much Simple Green and a little bit too much force on the "U.S. ORD" marking on the lid.
The red coat is primer. The forest green coat is original to 1939. I believe the OD green coat, which is 1942 spec, was probably applied in the field.
I was more careful with the "Alemite Stewart-Warner Corp" marking, which shows the coats even better.
I was even more careful with the stenciling.
Before:
After:
The light blue stenciling reads “B 109“. It may be a unit number, perhaps (wishful thinking here…) B Company, 109th Infantry Regiment, which shipped out of Indiantown Gap, PA, but drafted over half its ranks from New Jersey (where I live) and New York in 1941.
The red stenciling reads "C G", which refers to "Chassis, General", signifying that this particular pumper was used for general purpose grade grease.
wrenchguy
NW Indiana
Very nice, especially being wartime original condition. I never seen straight up cylinder shaped alemite greaser b4.
JoCoSawdust
Eastern NC
Well we know how you spent your day! That thing found the perfect home, congrats. Thanks for the education as well. Alemite made some really cool stuff.
Lugz,
I think that Tin Medic has an Alemite catalog from 12/44 that might have a listing for it. I only kept copies of these three pages having to do with Jeep grease guns.
-DonDDFCDB17-4E35-46C6-B49B-8B6F549B1555.jpgD3751FC7-626F-4149-8119-28E0DAAAEB72.jpg33649D2E-8659-4CC9-9FFF-AB064B49590A.jpg
Nice find. Like you said, that must be a hit out at a show. That chart is neat, lots of grease points.
What are the letters? D- daily, W- weeky, M- monthly, S- some day when you feel like it? :lol_hitti
Rileysan
Milwaukie, Oregon
You can see the "CG" and other grease grades cited on these lube charts.
I guess I shouldn't be surprised to see these - the US government loves bureaucracy! But I was thinking thinking about how irritating it must have been to be an army mechanic performing preventative maintenance on vehicles ...
Mechanic - "Permission to fill out form to requisition lubricant CG, sir!".
C.O. - "Have you cleaned and dried all fittings with solvent X?"
Mechanic - "Not yet, sir. I don't know the War Department code for solvent X. What do I do?"
C.O. - "Forget it. The enemy just surrendered.
Brian
P
Haha. Moments just like those were captured in comics drawn by famous illustrators that appeared in Army Motors, an Ordnance Dept magazine distributed in Europe and the States during WWII.
But I actually think the lube charts were one of the shrewdest things the ORD did. Consider the numbers. Over 3 million vehicles in the ETO total. A million CCKW's (the famous 2-1/2 ton trucks) and Jeeps alone. Over 300 different variants of sedans and trucks. At its peak, there were 6,000 vehicles on the road at all times on the "Red Ball Express", the vast supply line that served the advancing Allied troops marching east from Antwerp to the front lines after the Normandy invasion. That's a lot of different maintenance intervals. The lube charts were put in a laminated sleeve in a steel sleeve under the hood in the engine compartment.
gpw_42
NC Sandhills, USA
Brian
That vignette has nothing on peacetime-Army chickensh*t...
MR.X
Brian
Hey Brian I can assure you as a track driver in the 2nd A.D. back in the day the Lube Order was the operator's responsibility and that card was useful in the soul crushing quest to keep our equipment operational.
thehorse13
Jefferson County, WV
I have NJ flea market envy. You and a guy that I grew up with back home are constantly pulling treasures from NJ fleas. He hits the ones in Bergen and Passaic Counties.
Outstanding find. Anything Alemite is hard to find in the wild these days.
P
Thanks, Sonny. It's one of the good reasons to stay here, for sure. As for Alemite, I find my share of small vintage push-type grease guns, but nothing as big or as gorgeous as your workstation! :)
P
I picked up this Alemite Model 6593 15-oz. lever-action grease gun at the flea market this morning. It is a WWII survivor.
It was coated with grease, but I recognized it immediately. This is the third or fourth I have found now and they are in demand for portrayals at shows. That red you see on the handle is not rust, it's primer. The handle and mechanism was painted OD green and this is a very usual condition with the OD green remaining farther down the handle and the head. This is one of the better ones I have found with a lovely shade of OD and much of it intact.
These were standard issue to every Willys MB and Ford GPW jeep after mid 1944, replacing a smaller 9-oz push-type. There was a bracket for them under the hood. Here is an excerpt from the November 1944 issue of Army Motors magazine advising troops on the change, where the bracket is located under the hood, how to mount it in the bracket, and how to use it.
Lookin4'67Galaxieconv
Atlanta, GA
I like that grease gun. Somehow I've fell into collecting older, vintage ones. They're relatively cheap and I found I've ended up with several now. Hard to pass up.
