ESCO 10498 Jack Stand Pictures
Vintage Veloce
San Diego
I just received my jack stands. They do look solid. I had read in the reviews that the finish and workmanship wasn't great... and that is apparent. I thought I'd post pics in case someone else wants to see them.
For the price, they should be finished better, IMO. Even the stickers were hanging loose... either not fully applied or just peeling up.
Some had complained about uneven pin holes or shafts without the tops welded straight... mine seemed to be fine from that perspective.
View media item 94786
View media item 94787
View media item 94788
View media item 94790
View media item 94791
View media item 94792
View media item 94793
I'll keep them.
Stadger
Yikes! Four of 'em for almost $500 on Amazon! At that price they should lift the car by themselves.
RKA
Zewnten
I think we paid $60/pair. Ours are fine finish is what i expect for made to a price point, no competition on the market frequently abused never loved shop tool haha. That said 4 of them hold up a 12000 pound skid steers very well and completely stable, much better than the other stands we used, they were rather sketchy when you're calibrating the tracks at full speed or raising the boom to work on the engine.
tym
^ I have the US Jack stands. Good quality, made in USA.
the intimidator
ontario canada
While those us jacks look nice their not anywhere close to the same style as the op. Hein Werner used to make a set of pin type jackstands. Their is a rv company who makes a few pin type jackstands in America as well I forhet who it was but I had a set with my old mallard trailer
Locker537
Massachusetts
I've always liked the design of the flat top on the Esco jack stands.
I have stands that I believe were from Wal-Mart in the early 2000s that are quite good, but always consider upgrading to something with a flat face on the top. Most the cars I work on have jack points that would be better suited for those faces.
MJK
Tucson, AZ
Love my Escos, and I paid more than $55 ea. My only minor niggle with them is they take up more space to store than my prior ones.
BroncoAZ
I think those Esco stands look pretty good. I much prefer their adjustment mechanism to the ratchet type.
For truck stuff I nutted up and got a pair of these Sunex 10 ton stands on sale for $189 shipped. I wanted something I could trust when removing the suspension and sitting under the suspended half of the truck. I need a stand 32” tall for the truck to sit level. I do hate storing them indoors, they probably should be moved to the wood shed.
https://www.amazon.com/dp/B0093NBRHA/?tag=atomicindus08-20
V
Vintage Veloce
San Diego
Have had these (4) for years. Great product.
Interesting that those don't have the cross bars between the legs! I think the original AC stands were made in Denmark, but those don't seem to be easily available in the USA anymore.
RKA
I don’t think the AC branded stands had the reinforcements between the legs. As far as I know they only imported them to the US for a short time. I have the same ones, purchased from an AC dealer over 15 years ago. I think when the Esco copies became available, they added the reinforcements.
Edit: nope, it looks like AC did add the reinforcements at some point. The early versions didn’t have it though.
PoorOwner
CA
LOL it's just the petroleum smell from the rubber.. you can wash it with some dish soap and it will go down a bit each time.
Qualitytools
SOCAL
I have them, I use them a lot and I feel safe under a car supported by them. That's what matters as they have and continue to serve me well. Money wel spent!
HenryAZ
MEMBER EMERITUS
South Congress AZ
I just received my pair of ESCO 10498 stands. Overall, they look good and sturdy, and the finish/welds are fine, not USA made quality but good Chinese. The only thing I did not like was the flimsy linch pin used to secure the end of jack pin. The hole in the end of the jack pin will accept a 1/4" pin, but they supplied a tiny linch pin that I have no faith in remaining in place (too easy to knock it and unfasten it). So I replaced those two pins with 1/4" steel wire-lock clevis pins from McMaster, @ $2.50 per. The stands are rated at 3 tons per stand.
Qualitytools
SOCAL
Interesting, I just used mine this morning. I have had mine for a few years now, so here are some shots of the pins that came with them. Not sure if they are the same as yours or they have changed them.
M6erfan
'Merica!
^^^Clevis pin is a good idea :thumbup:
V
Vintage Veloce
San Diego
Here is a picture of the pins that came with mine. The ring is sprung to flip up and cover the end to prevent retraction. Are these the pins you didn't like?
HenryAZ
MEMBER EMERITUS
South Congress AZ
Yes, those are the ones I don't like. They are much too small for the application (the hole in the jack pin will accept a much larger diameter pin, up to 1/4"). I found it very easy to "un-snap" them, and do not trust I could do that inadvertently while in use. Because of their small size, there is very little spring power holding them closed. The clevis pins I got from McMaster have a 1/4" pin, which just barely fits the jack pin hole (but they slide freely), and it takes a concerted effort to release them. Heck, at <$2.50 each, it is cheap insurance, and no I did not pay McMaster to ship just those two pins.:) I keep a cart at McMaster with stuff that is not needed right away, so they came along with several other items.
VolvoRyan
Kentuckiana, USA
Here's a pic of my four that I bought in 2015-2016-ish.
Positively no corossion, problems with the welds, surface rust, or defects bubbling through. These live in southeast Ohio, America's humid armpit.
They've gotten tons of use with big clunky cars on them. Even the rubber pads have somehow held up.
I would contend that the armchair complaints on "quality" are not realized in real life.
-Ryan
Steve_P
I have 4 of these and am a fan. Mine don't have the plating issue like the OP, but come on, these are jack stands, not jewelry. If they were bare metal they'd last a million years. As far as the small pins for the support pins... really? You use those? I understand why Esco included them, but you insert the main pin. It's not going to magically retract - at least in my garage. YMMV...
I have no idea where those tiny pins are for my stands...... but they're not in use...
Qualitytools
SOCAL
I grabbed a couple of my jack stands today to support my car so I can do some work and as I was adjusting the height to set them under the car I realized that I have 2 different types of ESCO stands (see photo).
I have some with a single hole and some with a double hole. I have a total of 6 stands that I did not purchase at the same time or the same year. I am wondering if anyone else has the single hole in the tripod and if it's possible to drill an additional hole on the singles for a "finer" height adjustment? I also don't know which type is older, the double hole or the single.
Anyone else have a mixed set?
16again
Boynton Beach, FL.
I have both the single hole version without cross bracing AND the double hole with cross bracing versions.
My single hole are original AC stands. These new (red) are the Esco stands.a5c4b3416e0143999b57c2bac17a3236.jpgfa365538268f6aa3198cb70f1c220693.jpg
Qualitytools
SOCAL
Thanks for sharing, I like the red color
