How do you organize screwdrivers and wrenches in tool chest?
peterp
What is everybody using to organize screwdrivers and wrenches in their tool chest drawers?
If you have a great solution for organizing screwdrivers and wrenches -- please post them.
I've tried a bunch of different organizers and don't like any of them.
For example, I just ordered four set of these from Sears based upon positive reviews, but don't like them at all. The foam dividers are too flimsy, but also too stiff to easily insert/remove screwdrivers/wrenches, and they are too tall so that if you have rubber lining in the drawer, the drawer is difficult to close because of friction from the foam hitting top of the drawer frame. I don't know how they get positive reviews.
dthor68
Greer, South Carolina
Google “screwdriver organizer” and then click on photos. You should find something that you like. I used the Ernst low profile for a while. The material was awesome. It just did not work well with my Wiha’s. So I made my own.
dthor68
R_einan
Eastern WA
Wrench organizers came off the MAC truck, because I don’t like the Ernst ones because the teeth get progressively smaller. The screwdriver organizers are magnetic ones from Torin that I massaged into fitting side by side in that drawer. I do use Ernst gripper wrench racks in various sizes to hold the more specialized wrench sets in another drawer.
tomtomgt356
*******, GA
I bent a sheet metal tray to go in the middle of my screwdriver drawer. Flats on the left, Phillips on the right, small screwdrivers in the tray. It doesn't look pretty, but it works.
Ohmthis
Outside of Louisville KY
I like those! I don’t have a need for organizing that many drivers. I use organizers I found on Amazon. Both for the screw drivers and some of my wrenches. I used wrench racks for the rest of my wrenches. I’m not sure which brand, but I do like them. Here’s some pictures.
Ohmthis
Nice set up, OT, how do you like this SK drivers?
NCBearhawk
I just use stiff soiled core coated wire twisted into 1.5 inch coil (twisted around a dowel rod). Yes ,I am cheap. However, this was/is about maximizing available space. Pretty sure I stole the idea from someone's toolbox pics here ��
mmsalvage
I've got soooo many screw drivers, they just get stacked up in one of my drawers. One for philips and one for regular. Just upgraded to a 72" cabinet with end cabinets and still don't have enough room.
P
peterp
Thanks -- this looks like it might be perfect for screwdrivers. My biggest issue with every organizer I've tried is that wrenches and screwdrivers move around when you close the drawer. I really like the magnet grip a lot to solve that. I wish they made one that was a little more compact for wrenches.
I've added the Torin to my cart on Amazon, will be adding more as suggestions come in.
Allen Arin
North Carolina
I don't use a tool box for keeping screwdriver what I have done is made a circular wooden hollow ball with holes on it the dia of it is such that the screwdriver gets placed into it easily and can be taken out easily whenever needed.
2ndGearRubber
Pittsburgh
https://www.garagejournal.com/forum/showthread.php?t=421994
Toolbox tour of mine. In general, wrench holders of various sizes, and in reversed layouts to maximize space. Push the holders or the wrenches until they contact the drawer edges, don't be afraid to "cheat" whole sets to one side in the holders. I like the ernst style with the grippy fingers.
https://www.amazon.com/dp/B005ZHX802/?tag=atomicindus08-20
Screwdrivers laid out handle up/handle down to maximize space. I got an OEM tools one I like. Check out amazon for ideas.
What kind of box are you organizing, and with how many tools?
EDIT: BTW, I was able to squeeze both sets of flank bit wrenches AND a 10-19mm torque adapter set in that wrench drawer. :bounce: (Video @3:50)
R_einan
Eastern WA
I’m very happy with them, I have larger hands and these are comfortable to use, and they feel similar to the old MAC hard handle screwdrivers, which I liked. I’m not a fan of comfort grip or the like and these fit the bill for me. Also, they’ve held up well so far, I use the Torx drivers a lot on my bike and they haven’t twisted on me yet, though I do with they offered them in a shorter length set.
Have you checked out the EZ RED wrench organizers?
https://www.amazon.com/dp/B0186ND9R8/?tag=atomicindus08-20
I looked at these, but I wanted to keep all my wrenches together and it just didn’t fit my organizational plans. I’ve read good things about them, maybe there’s here will chime in on them.
P
peterp
I had this one added to my cart (https://www.amazon.com/dp/B07KSNCVDN/?tag=atomicindus08-20) -- which looks similar or maybe exact same thing. The reviews seem to be slightly better on the one above -- the Big Red colors are cooler but a lot of quality complaints in the reviews. They are probably the exact same, but I will probably order the other one.
If anyone has any experience with these, I'd love to hear it. I will kick off an order of something before midnight -- still haven't determined what.
P
peterp
Great video and toolbox. I think I'm going to try this one (https://www.amazon.com/gp/product/B00H49FD8E/?tag=atomicindus08-20) because it's so compact and holds metric and SAE together. I'm also going to order an Ernst for stubby wrenches based on your video to try it out. I ordered ones that looked a lot like the Ernst before, but they have nothing to grip the wrenches, so it was a fail.
These are the failed holders I have:
R_einan
Eastern WA
Personally, I’d spend the extra to get the EZ Red version, the reviews are better. Plus I think I saw one on warehouse deals for >$17. Might just order one to check it out and see if it works for you
P
peterp
Thanks. They are pretty much the same price, I thought the reviews on the other one were slightly better, but they are very mixed on both. There are several posts about poor quality that kind of scared me off for now and I want to try this one first (https://www.amazon.com/dp/B00H49FD8E/?tag=atomicindus08-20). If I don't like it I'll try the Big Red or the other.
I also ordered the Torin screwdriver and the Ernst wrench holders (I got the stubby version as a test) based on recommendations in this thread. They are supposed to be here Saturday, I will report back. Still interested in more suggestions as I'm reorganizing my entire tool chest (and hopefully this discussion will help others).
Yarpo
Minnesota
Those are designed that way and made by Ernst too. I actually prefer them this way tho I have a few of each. I'd recommend just regular Ernst holders if you're going to buy them for the stubby stuff anyways
Alpine4x4
Central, WA
Still deciding on wrenches. Will probably do magnetic sdjustable rails. Screwdrivers stay in their trays:)
Legion Prime
Leelenau County MI
I stuck my 14pc Williams wrench set in one of the Ernst racks PeterP posted and then got a reverse one for a couple other sets in the drawer. They work great, my wrench drawer has never been so organized. The old Craftsman 2x open end wrenches got stuck in the Williams roll and hidden away, apart from the weird 19/64 one everything else is doubled or tripled in the drawer already and everything is way WAY better organized.
P
peterp
Thanks for all the feedback. This is still a work in progress, but here's what I learned so far:
1. The magnetic Torin screwdriver holder is a keeper. It seems a bit short for a typical drawer, but works for me because I'm going to store my screwdrivers that are too big to fit on a rack behind the magnetic rack (see pic). I'm ordering two more, 1 for more screwdrivers, 1 for punches. Some reviews complain the magnets are too weak, but for horizontal placement, they stick for virtually all normal sized screwdrivers (for stubbies I need to make sure they are square on the magnets).
2. Yarpo is correct, I don't know why I didn't like the Ernst non-gripper now that I try them again. They actually are very good, probably will order another pair for SAE Wrenches. The wrenches do stay in place when I close the drawer, so I don't know why I didn't use them before (they've been on the shelf for a while).
3. The Ernst stubby gripper is very good. The only drawback is that the grippers need to be taped to the drawer because it requires a bit of force to remove each wrench. Taping to the drawer isn't a big deal obviously, but I have rubber liners in each drawer, so taping won't work (and I don't want to remove the drawer lining). If you have drawer liners, non-gripper a probably better. If you can tape it down, then it comes down to preference whether you want wrenches held more securely or whether you want them to be easier to remove.
4. I found a large black organizer that holds 2 sets of wrenches, allen wrenches. I bought it a long time ago -- also in storage. It's pretty awesome. Couldn't remember where I got it, but I think this is it at Harbor Freight for the princely sum of $12.99 -> https://www.harborfreight.com/mater...ganizers/76-piece-wrench-organizer-46884.html
Magnetic holder:
HF Organizer (foreground) + Recomissioned Decommissioned Ersnt Non-Grippers (far side of drawer):
HF Ad Photo (it holds a LOT more wrenches than their photo suggests):
boostin20v
North East
Metric wrenches:
sae and large metric wrenches:
screw drivers:
Wrenches on OEMTOOLS organizers, I liked them because they're low profile than most others. Used 3 sets in my 44 HF chest.
bonneyman
Desert SW
:thumbup:
Did that at work on the employee tools and it lasted about a month. Nobody would keep it up. But it was great while it lasted.
P
peterp
I’ve got a new toolbox in my immediate future, going to be stealing some ideas.
Glad to hear the information will be used. I will be posting more as a I go through the rest of the tool box. I'm organizing sockets now, will post what I used when done. Hope others will continue to post ideas -- all the feedback has been very helpful.
ekimneirbo
Kentucky
My personal opinion is that tool organizers are a waste of time. Don't get pissed....I've tried that stuff. The truth is that unless you are an aviation mechanic and need to account for every tool, or have a Nascar sponsor, its a waste of time. First, the organizers never hold every tool you have or they have places for tools you don't have. You always have those sockets that don't fit because they hit the next large socket, or the sizes on the labels don't match the sizes in your set. Take the money you spend on the organizers and buy other stuff. I have several tool boxes in my shop located in different places. I have many different brands of wrenches and sockets. I bought 4 top boxes and sat them on a workbench. One box has drawers for standard wrenches and one box has drawers for metric wrenches. Same thing for the sockets. I have a drawer for each size wrench. Iput all my 9/16s in one drawer and another drawer for 5/8s. As the wrenches get larger, I use the larger drawers and have them cover several sizes.
With the sockets, I put some of those little socket holders in the drawer and rivet them in. I have 1/4" sets and 3/8" sets 1/2" sets and 3/4". Also drawers for impact sockets.
Yep, it ain't as pretty as a perfectly organized box, but I've got a lot more wrenches and sockets and there is no way to make them look "purty". One of the handiest things I have Is a pegboard next to the lift. Its mounted on the back of an old Craftsman roll around workbench. Put some metal bracing behind it and tapped holes to accept 5/16 bolts that I had cut the heads off. Made em about 4" long to hold lots of wrenches. The thing that makes it handy is that the wrenches are mounted according to ascending size. Doesn't matter whether its a standard or a metric wrench, only if its the next larger size. Then I printed the decimal size for quick reference. So now when I have the wrong wrench (std vs metric) I take two steps and hang the wrench on the pegboard and grap the next size. No more guessing and grapping a handful of wrenches. The wrenches are all types too. Box open,combination, ratchet, I have a choice and its very quick. I don't care about brand names, only about grabbing the best wrench for the job and doing it quickly. Lots can be said for "organized chaos".
Then I put sockets on the table surface. A quick look at the next larger wrench tells me what socket I need to grab. A drawer holds ratchets divided by size. Another drawer holds all the extensions organized by size. Small angle iron wings on each side are drilled to hold screwdrivers, and a couple studs to hold some cheater bars. Couple short pieces of pipe to hold some flashlights. Yep, it works well if you use your tools instead of admiring them.
To me, functionality is more beautiful than just getting frustrated trying make all my tools match the available slots. I'd rather have more tools than slots.
ddawg16
S. California
I have a better method. I keep buying screwdrivers and leaving them around the house in every room.
Eventually, I'll never have to go to my toolbox for screwdrivers....there will already be one or more in that room. Along with a hammer....tape measure....box cutter....
Except when I forget to put the tape measure down on my way to the garage.....then I end up with 6-8 tape measures in the garage and non in the house.
P
peterp
I suspect we were separated at birth.
Ohmthis
Do you have a shop tour? I’d love to see your shop. I’m limited in my work area. I have a two car garage and a one car bay perpendicular to it. The one bay is 17.5 x 24 deep. I have a two post in there and three boxes. I need to do a tour and get some advice on making it a little better work area.
ekimneirbo
Kentucky
Might be possible. Is "Ohmthis" a real name or just a play on words ?
Wyoming09
Wyoming, MI
I use the Ernst wrench rails. I like them well enough but they're not perfect. I have no good way to store my screwdrivers.
P
peterp
Ordered some socket organizers, some good, one not good for my application.
First the good: These were perfect to organize 3/8" sockets. I had craftsman drawer inserts for socket organization before, but they weren't space efficient and nothing held the sockets in, and the holes were too close to tolerance so sometimes sockets wouldn't fit in the hole as labeled (depending on individual socket width) .
With this OLSA metric/SAE set, the sockets are very compactly stored, held in place with magnets, sizes are well labeled, and the holes are slightly oversized so the can fit varying socket brands as labeled (<- for 3/8", not the case for 1/2" (I tried), but they are intended for 3/8"J). They are perfect for organization in the drawer. I didn't really try them in portable use, but I will say the magnet on the bottom (which holds it firm in the drawer) will pick up anything metal underneath (it kept picking up my 1/4" sockets when I moved the holder around), which could be annoying if you are moving them around.
https://www.amazon.com/gp/product/B07BKMGB4Z/?tag=atomicindus08-20
https://www.amazon.com/gp/product/B07BKP12WQ/?tag=atomicindus08-20
