Cheap Chinese Auto Lift Vs Brand Name Auto Lift (Triumph vs Bendpak)
latenttweet
Satellite Beach
Recently shopping for lifts, and ran across some findings I wanted to share. I am looking for Sub 9' lifts, particularly:
Triumph NT-9 9,000 lbs ($1,800)
BendPak Grand Prix GP-7LCS 7,000 lbs ($3,200)
Came across this article here:
https://www.bendpak.com/a-study-in-lift-design/cheap-lift-vs-bendpak/
This article is going to be biased as it is written by bendpak, however its a good source to just compare the design, material, and manufacturing of both lifts.
now what's interesting is they [bendpak] make a lot of vague statements, like, our cable is stronger than theirs, with no real talk of tensile strength of cable, ratings, corrosion resistances, sourcing. Or , our metal is thicker here, but that doesn't necessary mean better, actually could be worse in some applications. its almost like someone wrote this article pretty quickly because a real mechanical engineer could really pick apart the differences from a design, longevity, and safety standpoint. Which then leads me to wonder, what kind of Stress Analysis was done on the Bendpak units? but then again, they have the certifications to back up their claims.
Now someone told me, that metal is never going to break when the car is resting on it. this may be true. However, Look at the diagram attached showing the differences between the locking nubs. More is better from a peace of mind standpoint when the car is rising up, but that's not the point I want to make. You have those two yellow bars on the cheaper unit, say you are lifting the car up, pump is running, line explodes (already in trouble because that can be skin piercing pressure), now the lift comes to a free fall (or whatever the resistance of the hole in the line is). Take this yellow locking tab on the cheaper unit, from a static engineering perspective, 4,500 lbs (half of what its rated for/1 side of a truck) will never bend that. But now drop the car from 13” onto that (the distance between those two locking bars, strictly a guess from the picture), and consider the lock ratchet mechanism isn’t the same size as the bar, its smaller, so now you have Force X gravity(13”) distributed into a tiny area of pressure where the lock mechanism is. This force could shear the lock (in my imagination anyways) You also have scenarios like the car not falling straight down, There are many lift accidents from the car not being lifted properly (setup), this type of failure will cause the vehicle to go forward backward or side to side, and who knows what weird force that will have on these lift arm restraints. Also , besides the fact of heavy metal failure and cracking, the cable system will probably go before all of that. Cable condition is what you look for when buying a used lift. I think after seeing this, I am definitely spending the extra money on a better lift. the ANSI and other certifications sold me. Obviously everything is made in China these days, but the better brands just have better quality control, but at the very least if an American standards company is willing to rate it, then that is peace of mind for me. I Will be spending the extra money on the Bendpak.
Longevity is also another issue, I know people with the cheap Chinese lifts that are years old, they seem to be fine, but just from the pics in the article you can tell some parts are going to wear faster.
The last issue I want to mention is that $1,000 price difference is pretty huge difference, but the fact that I could get the Chinese unit, have it break, then have to take it apart, ship it back, this could cost up to $1k of my time lost and shipping to have a warranty fix. Granted, most warranty would probably be something with the hydraulics.
L
latenttweet
Satellite Beach
I'd look for a 10,000 lb lift
Wow awesome video, i didn't even bother searching for a test video like that just assumed nobody has done it.
And yea thats what i do with cheap tow straps. i derate them by half in my head, so if it says 1,000 lb its 500. anything harbor freight is like that. i guess in China they don't care about factor of safety margins.
The funny thing is the cheap lifts are rated for more weight than the more expensive, rated, lifts.
Thanks for the video. after researching these lifts, i don't think i would help work on a friends car if it was under a no name lift. especailly if you are trying to yank a trans out rocking it back and fourth. Maybe you can get some extra jack post under the cheap ones.
wssix99
Chicago, IL
This will be true because everyone will test their product to their ultimate claim. However, their factors of safety may be different and metal members will generally bend a great deal before they yield.
I have a two post lift from Bendpak and the posts deflect visibly (just from bending of the metal) with less than 50% of the maximum load up on the lift.
L
latenttweet
Satellite Beach
Good timing. We are thinking of getting an Atlas brand lift. The 9k lb one is 1700, the Extra tall extra wide 10k is $3k.
https://www.gregsmithequipment.com/...BJEI8A772TLcB4lw0vYBYm53mpCS0OT-hIn_pTKYmBDDI
Do you know if the ATLAS is ANSI rated? i didn't see anything on their webpage. seems like the bendpak has a lot more certifications.
Are you talking about this one? https://www.gregsmithequipment.com/Atlas-9KBP-Baseplate-9-000-lbs.-Capacity-2-Post-Lift
that is the same price as the Triumph one i was looking at that seems to be the same unit all the other resellers carry. It seems a little too good priced.
pbon
Greg Smith is pretty good. They have stores and stock parts for what they sell. I had an Atlas for 5 years and liked it.
finn
The UP, God's country
Ever stand on a bridge with car and truck traffic?
Ever watch the wingtips of an aircraft from the window seat?
Ever been on the upper floors of a skyscraper when the wing blows?one thing they all have in common is that they flex under load, same as a well designed auto lift.
Did you know that the piston pins bend under load in a Diesel engine running under full load conditions?
Shootinok
Oklahoma USA
I've been patient and watching for a lift for some time. Found a used Rotary 9K for $1700 and jumped on it as fast as I could. The Rotary lift really looks like quality to me.
I just didn't want a cheap one.
JamesW84
Springfield, MO
I've been in a lot of shops in the area for work and most of the reputable or larger name shops that I've paid attention in have Rotary lifts. That would probably be my first choice if I couldn't find a good condition, used Mohawk.
3rdgendslmech
Maryland
We've got a Rotary 2 post 18K at work. It picks up everything we have no problem....but I did pick up on something that seems a little sketchy to me. The drive through width between the carriages that hold the arms are about 106½". Weve got an enclosed service truck that we tried to balance out pretty even with tools and hardware. One day the truck mechanic had it up on the lift and something I noticed was how the extensions were damn near full out and arched just to pick up the truck.
I think if it was me I'd rather have a narrower lift for heavier trucks than wider. It's just an erie feeling to see the arms arc like that when you're 5 k from the max limit
wssix99
Chicago, IL
Yes, all of these things have design guides and parameters for maximum allowable deflection. It does not appear that automotive lifts do; even certified ones.
The BendPak deflection causes the lock release to be a little wonky on the tall two post lifts and it causes relative motion of the lifting pads to the vehicle. Not a big deal... - but I shudder to think of these effects being worse for lesser lifts.
haanzel
Texas
While we all like to save a buck, this is not the time to go cheap. I searched for awhile, couldn't decide which to get or what path to take. I wanted a certified one though. I debated on going with a Chinese one ($2600) or a US made one ($4100).
Well, I finally called my local Napa store- they sell Coats, the same company that make the tire changers/balancers. I got a 10K lift with about $600 of attachments/adapters included for $3200 after tax delivered to my door. Best part is it is made in Canada, which I am fine with their metallurgy. You do need a heavy loader or forklift to remove it, it is large and almost 2k lbs. For me it was the best of both worlds, a quality, certified lift at a near china price with canadian welds.
This snuck under my radar, I wasn't even aware Coats made lifts.
Shadowdog500
Down the shore
My Mohawk doesn’t flex!
pbon
Mohawk is very nice and premium priced. I would have one if I could.
Barrymaxx
Dont buy a bendpak GP7 because of the name, its built in china just like the rest and has many safety and quality issues. Its not like the good old bendpak lifts. I think I would of been better off with a Atlas or something more proven.
ALI certification is an absolute joke. I would be embarrassed to have my certification on this lift.
If you would like more details feel free to PM me.
wssix99
Chicago, IL
I wish my BendPak had a safety system like this. I would expect their columns would bend about the same as Mohawk's, but since they are taller, the deflection at the very top is much more. This causes issues at the pulley's that carry the safety lock cables across to the other sides.
haanzel
Texas
I was at my mechanics today, I saw some bend on one of the Rotary with under half of what it is rated for. My Coats has some flex too. I do use 2 harbor freight 4k jack stands to stabilize, they are awesome and highly recommend them.
tff
Greer, SC
I ended up going with a Rotary 2 post. A bit pricey but certified, great quality and highly recommended by my installer.
JackSkyvet
I had the opposite experience with Greg Smith. They were rude, nasty and misleading. At the end of the day I am actually glad he was so nasty as I purchased both a 2 post and a 4 post lift that, while slightly more expensive, they were better lifts overall than the Atlas. The difference in the Customer service was night and day and even though it has now been several years, that kind of mistreatment by Greg Smith has never left my memory.
pbon
My experience was in store so maybe my location was good. But I think GS has since closed or combined with another company, and that may also make a difference. I later bought a Bendpak 4 post and found customer service to be ok but the lift arrived a bit beat up and even had a tiny bit of surface rust and was missing two small parts.
jmdirk
Probably not actually made by Coats. Likely white labelled from some other manufacturer. My Snap-On/Hofmann unit is actually made by Wheeltronic.
jmdirk
You really have to be careful with the "Made in **" country. That can be a really ambiguous statement. I think a number of people on here have commented about receiving Bendpak lifts and then the column have Made in China stamped on them when they arrive. So major components like the columns are offshore, but the whole thing is assembled and designed in the US, so it is therefore "Made in USA". Some companies are a little more honest about this. They'll say "Made is USA with global components"
China can make good stuff. It all comes down to the company contracting them to do so. Too many companies, simply go to China and say, "make me this for as cheap as you can". So they do it. But if the company goes in and says, I want it made to spec XYZ and I want such and such level of quality control, they'll do that too. It'll just cost more.
If you want a guarantee of quality, at least get something that's ALI certified. I believe that one of their requirements for certification is that it needs to be designed with a minimum Factor Of Safety of 2. Meaning if it's a 10K lift, it'll go to 20k before failure. But given your original post, I'm guessing you already know what FOS means ;)
I ended up getting a lightly used ALI certified lift from a shop that had gone out of business for about the same price as I would have paid for a new Chinese one. Lift had been inspected just a few months before. And if it's ALI certified, you can always get someone to come out and reinspect it. Not sure you'd get someone to come out and inspect a non-certified lift - but I could be wrong on that.
racecougar
Missouri
GS did an excellent job of making a name for themselves as having an incredibly rude customer service/sales dept. It wasn't surprising when they were bought out by Tooltopia.
ronr80
ontario
I bought a Bend Pak HD-9 15 yrs ago and love it , only had one issue a hose broke but it's been a great lift. R
andyvh1959
Green Bay WI
If I can avoid it, I wouldn't buy any damn thing from China, certainly not something like a car lift that is easily built in North America. Really don't care if China can build decent quality or if its a screaming good deal. I'd sooner buy something used of good quality and condition.
isb cornbinder
Both of the lifts listed by the OP are made in China. I bought a set of Bend Pack wheel dollies about 5 years ago. After years of silly attempts from the manufacturer to rectify this situation, I still do not have anything that works. This is the worst $1000 I have ever spent. While the customer service is really interested, there seems to be a lack of product knowledge. I just gave up and told BP to stop sending solutions that have not worked. I posted something about this situation yesterday. If anyone is interested, they can easily go there, from here.
sweetk30
finger lakes area upstate ,ny
Almost ALL are made in china . Bend pack quality is going down hill if you ask me . My buddy has 1 BP and 2 rotory 2 years apart and the new rotory are MUCH better quality hands down .
Now if you want premium top shelf MOHAWK made in upstate new york with as much in house and usa sourced parts as possible .
Atleast get a GOLD CERTIFIED lift from the testing lab . And there is a few youtube videos on how cheepy units fail and dont lift min spec weight . The company that does this is 1.25hr north of me .
My shop came with a cheeper unit and its quality ***** . I am keeping my eye open for a used mohawk.
gregs
I have a Eagle brand 2 post thats about 10 years old. Typical looking 9k import 2 post. Been happy with it overall. I think for a non commercial use its more than adequate on its build quality and overall construction. I wouldnt get to hung up on future parts availability as I dont think most vendors are going to be able to supply parts for it a few years later. And honestly there is not much to go wrong with it. I had a hose that leaked at the swivel fitting that I finally got around to replacing. I ordered a made to size off ebay cheap, no big deal. Last year one of the cylinders developed a leak. Took it out and apart and found the ucups and seals online at a hydraulic supply house. Spent $20 for the parts to fix both. I doubt I will ever have an issue with the hydraulic power unit, but they are pretty universal and available online. The rest is just iron, not much to go wrong there. And if its a budget issue, I would gladly take a import lift rather than working on the ground. Once you have a lift its pretty hard to go back to working on jack stands.
With all that said... If I was a commercial shop and the lift was going up and down all day, 5 days a week making money I would definitely invest in a Rotary or Mohawk. Seems like they lift faster, have the single point lock release and some other nice features that would be worth it.
