Anvil cleanup complete...
burgie
Falcon, Colorado
For quite a while I was looking for an anvil in the 100 pound weight region and while back home in Massachusetts recently found a nice Hay Budden 102. It was sitting in my shop for a few weeks and yesterday took advantage of some nice weather to clean it up a bit. I'm sure the Anvil Purists may scoff at my job but I didn't want to weld edges and deal with heat treat issues.
I used engine bright to remove grease and oil then a knotted wire wheel on my 4-1/2" grinder to clean it up. The horn, table and face where refined using #80 & #120 flap sander disks. Instead of welding I elected to radius the edges a bit to clean the edges and minimize further chipping. Wiped it down with some isopropyl alcohol and finished with a light coat of mineral oil. I threw my machinist rule on edge across the face and was pleasantly surprised to see flatness <0.008". Now onto a laminated wooden block as a stand...
DSLTRK
PHELAN, CA
Ford trucks, Kubota tractors, and heavy US forged anvils.
What's not to like? Oh and the anvil, nice job.
ndnchf
Fredericksburg, Virginia
Nice work - looks fine to me. I did the same with my 1870s era 100lb Fisher.
burgie
Falcon, Colorado
Thanks for the votes of confidence, team!!
Coach, that's a Kubota B2620 HSD. I have a backhoe, weight box, tiller, rake and box scraper for it and once my shop is finished on the inside I am going to fabricate my own forks. I chose the pin-on style vs SSA quick disconnect setup and am very pleased so far. Just recently turned 300 hours and it had been flawless in operation. I change the oil every 25 hours and HST/hydrostatic fluid every 100 hours. Most consider it overkill but I see it as a small investment in maintaining an expensive piece of machinery.
Copymutt, your anvil looks awesome and sooner or later mine will have that used look as well.
ndnchf, That's a great looking Fisher!!!
