Titan SL-6600 Scissor lift review/install
TylerRNEMT
Pendleton, IN
Hello,
This last spring I finally pulled the trigger on a scissor lift! I have been looking for a couple of years and finally decided it was time..... I looked around at all options, stopped in at my local Greg Smith and looked at the Atlas options, bendpak, etc and finally decided on Titan's SL-6600 Midrise. There were a quite a few reasons I went with Titan:
1. They are headquartered about an hour south of where I live.
(This meant I could easily pick up myself and save on freight expenses)
2. They seemed to have excellent reviews from everything I could find.
3. They were the only only I could find at the time that had a 6600 lb capacity (most if not all of the others were only 6000lbs and my Supercrew F150 was going to be right at if not a touch over the limit of the 6000lb units.)
4. It was the only one that had 3 rollers on each leg instead of a single.
5. It had way more catches or lockable height increments than most I saw.
6. It ran on 120v instead of 240v.
7. It came with multiple adapters including truck adapters.
8. It was priced extraordinarily competitively with other sub-par units.
After looking at all of my options Titan won hands down!!!!
I spent a ton of time last winter in sketch-up trying to plan out my layout and positioning for the lift for once I got it home:
Titan was excellent as far as purchase and pick up! I purchased and ordered from one of their online vendors whom offered it at a few hundred under most other's I saw with the option to pick it up myself at headquarters in Greenwood, IN. The transaction went flawlessly and I scheduled a time a couple days after purchase to head down with my little old trusty utlility trailer to pick it up.
I showed the front office my paperwork and they sent me across the street where one of their warehouse employees happily loaded it on my trailer with a fork lift. He was very friendly and made sure he centered it well over the axles and that I was happy with how he loaded it.. I strapped it down and off I went!
I made a stop at Home Depot on my way home and picked up the lumber I had planned out for making parallel ramps to get my Mustang high enough to clear the lift, then headed home.
Once home I backed the trailer down my gravel drive to the garage and then it hit me just how dang heavy this thing actually was!!! I decided my best bet was to unpackage as much as possible on the trailer. Getting this thing off the trailer and then again off the pallet it came on was SIGNIFICANTLY harder than I had anticipated..... I would strongly advise anyone thinking about one of these to have a few helpers and a very good plan in place!!!
Once I finally got it unpackaged and off the pallet onto the floor of the garage I was able to turn my attention to making the ramps. I wanted them to be modular but yet lock together when in use so I decided on making each ramp out of 3 seperate sections. I constructed them out of 2x4's framed approx every 6-8 inches on center. The top was 1/2 ply that overlaps the other middle section that I then covered in carpet before attaching. I decided I would bury a carriage bolt in this overlapping section with a not on the bottom side and then drilled out the frame to allow this bolt to drop in therefore locking the pieces together. I was very happy with how this design turned out and required exactly one 4x8 sheet of plywood. I used another piece of wrapped 2x4 as a stop on the rear of each ramp.
Once these were done, I was able to get everything in place and lined up how I wanted on the garage floor and then hooked up the unit, filled up the reservoir with fluid and gave it a couple of tests. Everything worked as intended with no leaks!
The quality of the lift itself and the power unit was far beyond my expectations! The powder-coat finish looks great!
I went ahead and drove the Mach 1 up on the ramps and gave it its first workout! I couldn't be happier with how well this setup works for me!!!! Unfortunately my garage height won't allow me to use it at its full height position but I can still easily get under the car and do what I need on a rolling stool. SOOOOOOOOO much better than rolling around on a creeper knocking elbows on everything!!!!!
First project I actually used it for was a new exhaust system on my F150...... The lift made this project a piece of cake!!! And it didn't struggle AT ALL lifting the supercrew!
I have to pull the truck further over the ramp to center it correctly but I have marked out with yellow and blue tape on the floor of the garage the corners of where the ramps need to be depending on whats going on the lift. The mustang lives permanently on the ramps over the lift.
Ultimatiley I can not say enough praise for how well this product is made, how well it suits my needs, and how easy Titan was to work with! Would definitely recommend for anyone looking for a scissor lift!!
-Tyler
gearhead82
Thanks for giving this detailed review and the great pics! Just ordered this lift myself and I'm excited to get it set up soon! How are you liking it now that you've had a few more weeks with it?
cspcrx
Phoenix, AZ
Ramps turned out very nicely! Home made version of race ramps. Enjoy your scissor lift my favorite tool in my garage
Ohmthis
Outside of Louisville KY
Great review and thanks for the pictures. My two post lift is a titan. I, just like you researched tons before pulling the trigger on one. I, like you went and picked mine up. And I, like you was very happy with my lift. I’ll second the Mach 1 is awesome!
PoorOwner
CA
I love using mine. I move it up and down as needed to work under the hood, and then under the car, it is very easy to do, lower it, raise it to a stop, then release on it again.
One thing you probably want to look into, especially that truck, is the mid/tall jackstands.
T
TylerRNEMT
Pendleton, IN
Thanks for all the posts! Still can’t express enough how happy I am with this lift!!!! It is something I have always dreamed of having! I find myself just raising the Mach up in the air and rolling around underneath looking and cleaning random things for no good reason just because I can.
Grunt&aHalf
Have you looked at how much the load arms and platform channels are deflected when under load? I just got a new SL-6600 and am a little concerned about this. Lifting a 4500-lb Honda Pilot, the load arms deflect downward an inch or so, and the platform channels tend to twist or deflect so the roller underneath is only making contact on the outer edge, with a sizeable gap on the inner edge.
If anyone can post similar photos while under load, so I can compare, I’d greatly appreciate it.
I’m waiting on feedback from Titan Lifts as well.
PoorOwner
CA
I have lifted about 5000 lbs it is a Lexus SUV with truck body so the arms does not need to be way out like a Honda unibody car. The only thing I can think of is the very large nyloc nut that holds each arm stud on. They don't seem to be all to be threaded on the exact same amount but it has not bothered me. The arms slides ok so I have not attempted to adjust them. Maybe you can thread it a little more so the arm is "tighter" to the platform. I hope this helps.
The roller contact does look concerning. I am assuming you have checked the floor is level left to right, stuff like that. in terms of front to back , you want the pivot pin of the scissor to be roughly lined up a bit behind the steering wheel for 4WD assuming something usually 54F - 46R weight distribution. For example for FWD I line up the steering wheel with the pivot to not put so much weight up the front.
Grunt&aHalf
The reference horizontal in those photos is actually a 6' level, as I was verifying the floor & lift are both level. The lift arms deflect downward on both sides, but most of the deflection seems to be due to the overall platform weldment (two main channels joined by cross members) flexing. There's actually a slight crown from one side to the other since both channels lean away from each other.
I also showed the attached photo to Titan, as I'm concerned about the stress generated at the weld between the cross member and the channel (disregard the circle, I was also showing Titan a paint defect). The fillet is relatively small and there is no gusset plate to reduce the stress. Not sure what the design safety factor is, but if a crack, or void in the weld metal, were to come into play, this could easily propagate and lead to failure.
Already a little nervous about hanging out under a vehicle, I think I'm gonna just get four high-reach stands to keep me company. The extra $500 investment is a little painful, but not as painful as a dropped car.
Regarding your comments on weight distribution. I was wondering if it mattered whether a vehicle is on the lift facing forward or rearward. It looks like it would be easy to push the CG too far toward the edge of the lift base if the vehicle is on rearward, especially since the rear leg is rolling toward the CG while lifting. I'm thinking the engine should always be over the cylinder end of the lift. Although the OP's photos show his car on rearward. Another reason for those supplemental stands, I suppose.
PoorOwner
CA
I always use the unit like the product photo with the pump in front of the vehicle.
You should be able to use it the other way (backing in) as long as you balance it correctly. I always try to line up the CoG with the scissor pivot if possible.
Tall jack stand is a good idea for larger and longer vehicles.
PoorOwner
CA
I have looked at more pictures of this lift (because my car is currently over my lift).
It appears the front is a "strap" to clear the cylinder comparing to the rear support which are square tubes.
I know I read before there are guys with the Porsches and the bendpak they actually cut off this strap so they can drop the transmission.
The lift probably isn't going to split apart but I can see how that can be a concern... we have members here dropping the arms or the vehicle frame rail right on jackstands for more stability.
Besides the weight we have to think about torque, torque is what bends stuff. Maybe you can see if there are alternate lift points such as under the control arms, it may not bend as much, and then you have the option to lower the vehicle onto tall jackstands.
BukitCase
Oregon
Resurrecting this thread, I'm considering one of the SL-6600 lifts but didn't see any mention of the actual current their "110 volt" pump motor actually draws - my initial use would require about 75' run to closest 120 volt power.
Anybody actually MEASURE the amp draw on one of these? If so, thanks... Steve
BukitCase
Oregon
One more question, hopefully this will be easier (and get at least ONE more response :geek:
I edited one of OP's pics to show a measurement I can NOT find - need to know the MINIMUM length of smooth floor I'd need to get full range of lift with the Titan 6600 - see pic, please help if you have one of these lifts - thanks in advance... Steve
BukitCase
Oregon
Thanks; I checked their site and didn't see one that looks like the Titan, do you have a model # of yours? Might be discontinued, or??
PoorOwner
CA
Motor sticker says 19 Amps. You need 20 Amp circuit to be safe.
I do not remember this one dimming my lights like on the 4 post lift when first pushing in the button.
PoorOwner
CA
I got my 5000 lbs SUV on it again and I do not see any deflection or bending. It was effortless lifting it.
BukitCase
Oregon
PO, thanks for the update - My situation is gonna be kind of "fluid" unless/until I get far enough ahead to build an entire new shop, so I bought an identical lift (it's obviously same factory, different paint job) to the Titan, from Amazon a couple months ago -
I found this on Amazon during a "short sale", for $290
And, since I don't want PERMANENT concrete where I already have (temporary) covered space just yet, I found a used but flat 1" "loading dock ramp" consisting of a 4x8x1" steel plate with 1'x4'x1/2" "flaps" on both ends at the local metal recycler for $600 - I have 3 magnetic lifters rated at 2200# each that I use on my Case 580 backhoe (for lifting tricky stuff), and I already have a welder extension cord that's 75' of #6 SO cord -
These "goodies" will let me run the 60 amp welder service far enough to use either of two "shelters" that are a bit closer than 75'; That'll let me run 240 volt to the transformer, step it down to 120 volt and connect to the lift with an RV cord @ 120 volt 30 amp capability.
The "loading ramp" will give me enough room to use the lift with no more "pain" than I'm USED TO when "making do" like I've done most of my life :beer:
This area gives me a 15'x24' covered area next to the 20' container - and a few tarps/straps keeps the wind and rain out; I designed/built the roof in modules, so a 12x24 section can be removed when/if I get to replace it with a 2 story 3 bay garage - the removed modules can be used elsewhere on the 10 acres, always need more shelter than we have :rolleyes: ... Steve
