dsmproject
Hello! I have been a lurker/member for a very long time on this site. So much information from all of you, thank you for that!!
I finally started my garage project this year. It started off as a basic attached 2+ car (24x26) with no power or drywall.
I am well into the project now - wiring, insulation, drywall (sheets not yet taped), and flooring are done so far.
What I started with was quite the mess. The previous owner hung insulation over a HORRIBLY dangerous wiring job. When I stumbled across that, I tore out all insulation to expose any further issues. It took me way too long to get it sealed back up - the garage turned into an oven in the summer and icebox in the winter. This was my biggest motivation to get the garage done.
I do a little bit of everything in the garage - automotive and woodworking are a couple main ones. We are fixing up our house so lots of home projects. We have kids, so of course all of their stuff is around.
I started the project with wiring. I had done a very basic wiring job after finding the wiring disaster I mentioned above. I added 2 50amp and 1 30amp 220, new outside motion lights, and 3 outside outlets (one on each wall). I had a new sub panel installed in the garage, 100amp, fed from the house.
Then for my favorite part... insulation! I went with open cell full fill foam - 2x4 stud walls and 2x8 ceiling. I went back and forth on this, but given I wanted to heat the garage as cheaply as possible using electric, I figured it would be worth the money.
Then on to everyones favorite - drywall. Long story short, I have reminded myself I need much more practice with these damn sheets! Hopefully when I get to the mud/tape stage I can cover a lot of my sins!
On to current day. My wife's only request for this project was we make the garage nice enough to setup tables during holidays for family gatherings. As the floor was original to the house (1978) it needed some work. Our neighbors just had this flooring done by a local company and it looked fantastic. We decided to pop for the nice floor, definitely a splurge with this project.
Before -
After -
Next up is getting the drywall finished then onto paint. I am stealing inspiration from Toms Turbo Garage with gray bottom, black vinyl stripe, and off-white top. Should look great.
I will try and keep regular updates as I can get work done. With the weather being super cold lately, it has slowed progress down for sure.
Thanks!
Before -
After -
Thanks!
