Car lift you can set pinion angle, and adjust suspension at ride height?
Weekiman
Weeki Wachee, FL
I've been thinking four post, but after reading the archives I'm not sure. For the racers out there what do you use to setup up suspensions at ride height? That's my my main reason for wanting a lift. Wondering if there is a way with a two post so I could do more?
douglawrence42
Evington, Virginia
Hopefully someone has a better idea, but my method (one wheel at a time) is to measure center of wheel to wheel arch with the car on the ground. Then lift the car on the 2 post. Then I use a floor jack sitting on a heavy duty table to jack the wheel or hub or whatever I have available up to the previously measured ride height. That doesn’t really help you on pinion angle, but if I was doing that i might make 4 sturdy boxes to set the wheels on.
firebirdparts
Kingsport, TN
I think the short answer is no. It’s possible to drop a car on a jack but you need 100% weight on the jacks and zero on the lift. It is possible to safely do this but you can’t easily set a jack under a tire. For this a 4 post is superior.
You can get a two post lift to pick a car up by the tires. That would be the ultimate two post solution.
1redTA
Pace FL
I have seen some adapters for two post lifts that allow a two post to raise the vehicle on the tires. I’d be concerned about raising the rear end to ride height without something preventing the front end of the vehicle from pivoting on the front lift points. I’m thinking of you having a see saw type problem
You would be better off with some ramps or stacked 4x’s to raise the vehicle a little bit off the ground and use a creaper
CraigStu
Blacksburg, Va
I do the suspension stuff on the floor. I can't adjust the coil over collars w/ the car on the wheels to change height. I can do some of the alignment adjustments w/ the car on the wheels but not all. Also, I like to roll and bounce the car to settle the suspension after each adjustment, so it would need to come off the lift anyway. Look critically at your suspension adjustments and also realize that the ramps on a 4 post are pretty wide so they might block access.
LS6 Tommy
Northern NJ
Putting the car up on jack stands under the suspension is about the closest you're going to get to being on the ground without using wheel stands or lug/hub adapters.
The floor has to be more or less perfectly level, too.
Tommy
Ironcrow
Arizona
I welded 4 stands out of 1 inch tubing. They are 2 foot square at the base, 1 foot square platform on top, about 3 feet tall. I lift the car with a 2 post and set the wheels on the stands. The 2 post is left in position with a small gap to lift pads for safety.
When not in use the stands nest and store in a corner.
racerex
NY
How about on the ground using tire cribs. I built an insert that allows me to go a little higher, as needed. My friend built a slightly higher set for his Factory 5 Cobra.
Jazz1
Thunder Bay On.
I agree with others. Full weight of complete vehicle has to be on the wheels to set pinion angle. I learned this on my first frame off restoration.
pi_guy
N/A
Doing it right requires scales and level platform that hold scales.
hotrod1968
oregon
This,, yellow not my car. Orange 68 mine. This is how I do on my two post. Complete speedtech suspension frt and rear so lots of adjustments before I got my setup where I wanted.79c8df723c013e03b1ee9efa042ae30a.jpgb9aabe7a5645939dca3e1ef78defc98b.jpg35aeff10fdda560747f61d31f6f558f3.jpg
clamhammer
Omaha, NE
with the exception of bouncing and settling the car, you cant go wrong with the 4 post.
QwikKotaTx
Seabrook, TX
Keep it cheap.
Sent from my VS987 using Tapatalk
Falcon67
Merkel, TX
Tommy
This. Although, unless your angle is way the hell out of whack, who cares. I've had several race cars and never once set pinion angle. Bad pinion angle is when the rear end yoke is pointing at the ground. All you really need is it to not be directly in line. If the trans tail and rear yoke are not pointing directly at each other, it should be good enough.
W
Weekiman
Weeki Wachee, FL
Good to know, also wanting to adjust my roll bar links and coil overs.
39CAMC
St. Louis, MO
I only have experience with road race and autocross cars, but on those, pinion angle is pretty important for maximizing corner exit grip. If you have a cambered axle, it is extremely important.
DaveW
