Bought several different socket rails. What do you want to know?
PCMusicGuy
Houston, TX
So I ended up buying several different socket rails (organizers) so I could see which ones were the right fit for me. I bought all 3/8" to compare and generally picked up the ~12" rails unless they were not available at the time. I currently have a couple old Craftsman metal rails as well as some generic Harbor Freight metal rails. Below is what I bought.
  • VIM Magrail TL
  • Ernst
  • Olsa Tools
  • ARES Magnetic
  • ABN
I have played with them a bit so far and have already figured out some of my own opinions, but I'd like to know if there were any specific use cases or scenarios anyone would like me to test before I start sending some of them back. The vast majority of my sockets are older Craftsman, with some small amount of others. I do plan to purchase a Mechanics time saver's rail as well.
P
PCMusicGuy
Houston, TX
Why not just throw your thoughts out initially
Ok. Here are my quick thoughts for my use.
Ernst - I really dislike these. I like the fact that the rail itself is wide and stands up pretty well, but that's about it. The twist lock feature works inconsistently (easy for some sockets and tough for others) and sometimes the entire clip twists on the rail which can move it slightly. Moving the clips along the rail is also a pain. Some more pretty easily while others do not. Once locked, they are very sturdy. They also come with small labels that stick to the clips which may be helpful for some.
Olsa Tools/ABN - These rails and their retention clips are good. If you plan to lay your sockets down or utilize both sides of the rail, it's really hard to find something to complain about. They are cheap, solid, and you can get more clips pretty easily. The clips are super easy to adjust. In my case, for deep sockets, they are not super stable while upright. I can't put them side to side in a drawer and close it and have them stay up.
Ares Magnetic - These are probably my favorite. Solid rail, good clip retention, and they are easy to adjust. The magnetic backing is strong enough to have large, tall sockets on them and stay up in the drawer even when closing it a little harder than I should. The only thing I could complain about is that they only come in one color. But from the link below, it looks like you can get them in SK green now too.
VIM Magrail TL - I've heard about these rails for years and I understand while people rave about them. There are no clips, only guide posts which screw down to lock into position. You organize them the way you want and simple set the socket over the guide post. Magnets embedded in the rail keep the socket in place. The magnet is quite strong and it also attracts through the back side of the rail holding it securing to the drawer bottom. This makes the rail very secure, able to hold sockets upright even while slamming the drawer shut. The downsides are that the magnet is so strong it is not easy to remove the rail from the drawer when you need to. Another downside is it takes a little while longer to adjust the clips since you sometimes have to adjust several at a time, especially if you need to insert a new size or shift the sockets down.
I am not done with the hunt. I simply want socket rails I can place side to side in the drawer, will stay upright when the drawer is closed forcefully, flexible enough to add additional clips or posts, and can be picked up when fully populated with deep sockets just grabbing a couple of the sockets. Finding that balance of securely stuck to the drawer, yet not so secure that I can't easily pull out the rail if I need to take it across the garage/house is what is key. So far, the Ares rail works best for that.
Is the Olsa rail bent as **** or what?
I saw that when I looked at the picture. It's a camera issue. The rail is straight.
Do the Olsa and ABN clips interchange?
SK has new socket rails out in green in different lengths & three drive sizes:drool: :lol:
https://www.eppys.com/tool-storage/organizers/Socket Rails/3-8-dr-16-magnetic-socket-rail.html
The Osla Tools and the ABN rails and clips are identical in every way except color/logo.
The SK rails looks like identical copies of the Ares magnetic rail.
JiminAZ
Phoenix, AZ
Barrel distortion in wide angle lens.
Been using the Olsa/ABN for some time now and would echo your observations. Heavy/tall sockets tend to encourage it to fall over. But up to say 1-1/4", 27 MM or so they're pretty good. Easy to grab and take to whatever I'm working on. Big upgrade over the traditionaly type in the top of your photo.
I have been hesitant to use any magnetic base because magnets tend to attract and retain magnetic fuzz and I don't want any residual magnetism in my sockets. Not sure that would happen but it is a concern.
BroncoAZ
What about adding some neodymium magnets inside the soft end caps on the Olsa/ABN rails to have them stick to the bottom of the drawer and stay upright? I was looking at the new locking plastic end cap Olsa rails, they might be a bit more stable because the end caps look lower profile.
Maybe magnets like these:
https://www.amazon.com/dp/B07PWP9DWC/?tag=atomicindus08-20
mrjaw14
Nashville, TN
I'm surprised to hear that you don't like the Ernst rails. i was thinking of getting some of those. That's really the first bad thing Ive heard about them
decableguy2000
I have found the Olsa, ABN, Kobalt, and Performance Tool, aluminium rails the clips all interchange.
Wamsutta
Amarillo, Texas
I'd be interested in your assessment of GearWrench rails. They're not magnetic, but they're so broad that they stand up by themselves. Socket retention is a simple spring loaded friction ball.
AmericanMechanic
Unless defective or not as-advertised, why send some back? So the next guy gets used rails? You chose to only order one of each which seems logical. But now the vendor and the next guy have to deal with what you don't want? Just keep them or sell them.
Chromdome35
I have a combination of Hansen, Ernst, and Westling rails in my box. The Westlings are by far my favorite.
I agree with your comments about the Ernst rails being inconsistent, but I do like everything else about them.
Hands001
I searched and choose Ernst rails.... standup well and I like the twist lock. Yes, some take a twist or two to break in, but once used they hold well and twist off easy.
JeepinMike
Ok - what's your thoughts on what would survive (sockets stay retained) in a toolbag the best?
darkzero
SoCal
Glad someone took the time & money to try a bunch of them. I didn't want to as I just wanted some for some Craftsman sockets that I got for dirt cheap. Too bad for me this wasn't a week ago but I probaly would have still made the same choice.
I went with Ernst rails cause they had the trays & the price was good. I like them. I do agree that the clips are hard to move but if you do it with a finger nail on each side they're much easier to move. I actually like that they are hard to move so they stay in place. Once I set the spacing for the clips I have no reason to move them.
magtl
IL.
The Magrail TL can easily be removed from a tool box drawer using the MRRL1 Rail Lifter. A package of 10 is around $6.
Duker
Livingston, TX
I think it was Strouty who turned me on to Magrails. I use them in many different applications but the most useful has been my Montezuma tool box that I use as a road box in my truck and mule for repairs around the ranch. I rattle the heck out of that box and the sockets all stay put.
P
PCMusicGuy
Houston, TX
I am actually heading out to work this week away from the house for an indeterminate amount of time so I will be keeping them. Not all of them are opened anyway. When I decide on what I want, perhaps I will ship all of the leftovers to someone here that wants to make the same evaluations.
I didn't know these existed. I'll likely buy one and give it a go.
One last comment on the Ernst rails, them falling over would not be an issue if you used them in the socket boss tray, but that does waste a little bit of room.
BroncoAZ
I ordered $227 worth of Olsa Tools rails today after receiving my backordered 1/2” socket sets. The Olsa rails are cheapest on their web site with a readily available 10% off coupon, free shipping over $50, and no tax on my order. Amazon would've cost me $275 for the same items.
Wyoming09
Wyoming, MI
I agree that the twist lock feature is inconsistent and sometimes difficult to use. Ernst also offers a push on/pull off style called Dura-Pro HD. They work very well and securely hold the sockets. These are my go-to.
P
PCMusicGuy
Houston, TX
Just as an update, I've changed my opinion on the VIM Magrail TL rails. Once I started playing with them in the drawer, the fact that I can easily pull off a socket with a couple fingers without the rail moving is a good thing. For my use case, I don't actually every pull an entire rail out of my box and take it with me often.
By contrast, the Ares rail has such good socket retention and not as strong of a magnet, that the rail doesn't stay put trying to pull off the same socket. You have to use part of your hand or the other hand to stop it from moving.
Also, running the numbers (based on cheapest I could find on VIM, amazon for the rest):
VIM Magrail TL - $458
Ares Magnetic Rails - $402
OlsaTools Rails - $260
Ernst Rails - $150
kbeefy
Harington, Eastern Washington
I have a ton of socket organizers and the VIM magrails are by far my favorite.
If you buy them in the 'jobber' pack they come with the rail lifters and a apex bit holder which is pretty decent.
