I had a small LLC powder coating for several years. Lots of fun, can make money once you know what you are doing and create a niche for yourself. Lots of mine was mail order and I've forgotten how many states my work is in as well as a few countries. Some of it made the cover of a motorcycle mag I did parts for.
First step, get rid of those shop towels near your powder, you are introducing lint. And your tac rag, unneeded with powder.
If you have an oil bath compressor with no filter, that will guarantee fish eyes. If you have an air cooled/standard/inexpensive compressor this is not likely your cause unless you've introduced oil into your lines via an oiler and what you are seeing is residual. Regardless a filter sounds in order and may cure everything.
Unless you are doing cast wheels outgassing isn't necessary, if you are doing cast wheels, go 475/500 for at least good hour. This is sufficiently above your cure temps and get your PMT up.
If you are doing steel wheels, once media blasted blow them off well with compressed air and you can shoot them. Regardless, if you are wiping down with paper towels right before you shoot them I promise you are leaving lint behind, but this is different that fish eyes. Lint will appear as debris left behind.
A few things to help adhesion once you've blasted. Go ahead and outgass/bake if it makes you feel better. There is no harm in it. Once it cools off hit it with iron phosphate from a squirt bottle. Let it evaporate and hit it with powder. Available from nearly all powder suppliers. I've used IP and without, you'll be hardpressed to tell a difference, but its has its uses. I liked powder365.com - but prismatic is great as well. IF you find a reason you absolutely HAVE to wipe down a part, hit it with a propane torch afterwards. Just going over it to burn off lint.
I started off with a $49 Eastwood gun and made money with it, but Eastwood guns are a half step above Harbor Freight, maybe. Cheap way to get your feet wet, but don't expect too much once you start doing clears/chromes/2/3 colors. You may be experiencing faraday, which is a real sun-of-a-***** until you learn to fool it and smack it down. This could cause a fisheye like fault in your finished product, depending on where they are appearing. Near an angle or crevis? The first step is to check your ground. I don't mean an alligator clip on an oven rack ground, I mean drive yourself a grounding rod outside the shop and run a thick solid core wire from that rod to your spray booth with a proper clamp from the electrical department. It'll take you a few weeks to stop being amazed at what you were missing. A proper ground will make a cheap gun look great and a pricey gun look shabby it it doesn't have one. Like a car - powder needs a good ground to work properly. Give it a ground to take a lightning strike. I attach that solid core wire to a 1/2" ground rod running horizontal in my booth and hang all parts from that with the ground from my gun hanging from that. While shooting your powder, try taking another auxiliary wire and attaching it as a ground to the part in different areas, it can change the electrical current enough to help a trouble area take powder.
Hot flocking. Heat your part to about 200 degrees, pull it out and shoot it. The powder will stick wonderfully. Not appropriate when doing a 2 or 3 color piece, but hot flocking hard parts is an easy cheat.
Get the idea of dish soap/degreaser out of your head. You will be creating yourself many more headaches. Brake cleaner works in a pinch, acetone is great. Anything else Eastwood wants to sell you is unnecessary - and probably either iron phosphate or acetone. I kept a pair of tweezers nearby to pic any signs of lint or foreign debris off. Use an LED light to check for areas requiring more powder. The free ones from HF "with any purchase" work great.
In my time, I never once received defective powder and never heard of it actually happening. FWIW, keep you powder sealed and stored in a cool dry place and it will last for years. I have powder 15 years old I wouldn't hesitate to use IIRC there are only a handful of companies who actually manufacture powder. MOST everyone online is a reseller.
If you have more questions feel free to shoot me a PM. Good luck.
