Remember these late 1980s Craftsman sockets?
Djosbun
Surprisingly I still have a few left. The most used sizes eventually had the plastic ("will not roll away from you when dropped") eventually crack enough where it fell off. Actually broke one of these once (these are 1/2" drive) removing a transmission crossmember. Sears replaced it!
Wasn't one of Craftsman's better ideas. The plastic collar is nicer than plastic encountered today.
-- Dave
ransil
pa
I have a set. Bout the only ones I can read the size on easily.
Sent from my SM-G960U1 using Tapatalk
D
Djosbun
That is the best thing about these sockets: they are super easy to read. The one in the picture has the most wear on the size 'window' which is pretty astounding as they have been laying in the socket draw since 1988 or 1989. I never had them on an organizer. Seems to be a type of rubber that covers the size. The other four are in better shape.
-- Dave
BlackLS2
I still have a short and long set of those. My rubber held up well. The problem I had is the little insert that displays the size pops out, and gets lost. I liked the sockets as some were fairly thin walled compared to others I had. I took to cutting the rubber off...
bonneyman
Desert SW
Ha, I just found a single shallow socket with the collar on it like this at a pawn shop. Was 1/4" drive 1/4" 6 point. I snagged it because I thought the plastic collar would help me spin it in a restricted area instead of slipping over the chrome. I didn't know it was from the 80's :lol_hitti
malibu101
Walnutport PA
Yes, they were part of the sets that featured the stainless ratchets.
I have a set of 1/2" drive SAE sockets that I cut the plastic rings off of. You can still see the discoloration on some. They are stamped as normal under those rings. I'll try to remember to take a pic tonight.
I have the 1/2" ratchet but seldom use it. I left the 3/8" ratchet in a junkyard MANY years ago and still miss it.
malibu101
Walnutport PA
Notice the black leftovers on the short sockets, that's from cutting off the plastic.
I didn't even remember I had an extension too.
DFB
Southern VT/Western Mass
Have a couple spark plug sockets like that with the black band seemed neat at first but turned out pretty useless as there were many places they didn't fit
