larry4406
Several recent threads here on HVAC filtration have mentioned cold plasma generators to address indoor air quality.
https://www.garagejournal.com/forum/showpost.php?p=8222780&postcount=6
https://www.garagejournal.com/forum/showpost.php?p=6788514&postcount=3
Milton seems to have good experience with a Phenomenal Air brand unit and has recommended it on several threads.
The 4 of us in the home have all been sick this winter with congestion, ear infections, sinus infections, etc. So, I purchased an iWave-R Air Purifier Model 4900-20.
http://www.nucalgon.com/products/iaq/iWave-R
The iWave units seem to be much more readily available than the Phenomenal Air brand. Not sure if these are snake oil or the holy grail..
Installation was straight forward. I have an upflow heat pump so I installed it on the return prior to the coil and after the last filter as per the directions. I chose to mount it on the exterior so I can see the power light. There are brown wires for connection to a remote indicator lamp which I did not need as the power light is visible with my mounting arrangement.
I would have preferred that the unit had terminals for direct wiring vs flexible wire leads that are permanently attached. Input voltage can be 24VAC to 240VAC. I chose 120VAC and the unit runs 24/7 with the way I wired it (a recommended method vs fan interlocked). We run our fan 24/7 anyway. I don't like how the 120V wires are exposed but it is what it is.
Time will tell if this thing does anything more than lighten my wallet by ~$400.....
