ThrifyGarage
I've heard rumors that this modification can be performed. I picked up a GearWrench 81206F 3 Pc. Full Polish 84 Tooth Ratchet Set for $65 and 88 tooth rebuild kits from Matco for under $15/each. So far I have completed the 3/8" ratchet build. I am working on a YouTube video for the install. I will be sure to update on any issues I discover.
For those interested in doing similar mods the Matco part numbers are as follows:
1/4" Rebuild Kit: AFR8TKB
3/8" Rebuild Kit: BFR8TKB
1/2" Rebuild Kit: CFR8TKB
From what research I have performed this may not work for the new 120XP Gearwrench ratchets but should work on 60, 84 and 90 tooth ratchets.
Here is the completed 3/8" Gearwrench ratchet next to a 60 tooth Matco Flexhead.
Prior to dissasembly here is the Gearwrench next to a 36 tooth 3/8" ratchet.
Everything laid out with all the part numbers.
I removed the snap ring.
Removed the cover plate and the 84 tooth ring.
Next, I removed the pawl and the spring.
Last, I removed the drive selector.
The Ratchets didn't have this detent ball.
Here is a look at the parts laid out next to each other. Matco on the left, pretty much identical other than the drive selector and the number "2" on the Matco contrasting the "84-3/8" on the Gearwrench pawl.
Next, was time for reassembly.
Boom! Done!
Here is a look next to the unmodified 1/2" Gearwrench.
I'll throw in the Matco for comparsion.
Out of curiosity I also installed the 84 tooth internals inside the 60 tooth Matco. No issues whatsoever.
I'll be sure to followup with an update in the coming weeks on the 1/4" and 1/2" ratchets.
Boom! Done!
