so it happened today on my shop 2 post lift
sweetk30
finger lakes area upstate ,ny
the button stuck and it was a good thing i was NOT alone in the shop . friend held the cable for the over head safety wire to kill the flow of juice and i turned the breaker off .
i recall not to long ago on here a member said he had this happen and wired in a 2nd switch so both had to be pushed to make the power flow .
this will be my modification ! and also it might just get a disconnect cord / socket combo to get away from the hard wired setup on it now . this would have helped a lot .
larry_g
oregon
Give us a clue to the brand and the brand of the switch and motor HP . Can we assume the switch contacts welded closed? If this is a brand specific problem then maybe we can get the MFG to step up or at least other members with this same setup can be prepared.
matt_i
Some important follow-up questions to me would be: suppose you didn't have the friend, etc..would the overtravel cable & switch have stopped the upward travel by contacting the roof of the vehicle? Is it in the proper location to work correctly? Does it need a cover or a coated cable so it doesn't scratch the roof?
Samh
Canton GA
I don’t have a lift, but does these not have limit switches to prevent them going past a certain height?
sweetk30
cheep china quality EAGLE 9k 2 post lift already in the shop when i moved in . has a baldor motor and monarch pump unit .
the switch was the factory tiny push button with a 25amp 220volt rating . UNIMAX switch model ADPDJO switch like the one in he pic i found on line .
the overhead safety cable works and this vehicle was to short to hit the cable if it went up that far . so in this problem it would have let the pump do the internal bypass until i got to the breaker .
going to plan out the repair today . thinking maybe the disconnect and new switch only just to keep it simple stupid . and there is min extra space inside the box now at this point so i need to pick the new switch to fit .
rjacobs
Dallas, TX
Get a 30a, 220v switch and wire it in with your existing power wire. Mount it in a surface mount box near the existing switch(that failed) then if that same thing happens again, you just flip the 30a/220v switch off.
zmotorsports
Northern Utah
I've never heard of this happening but thought "what if" when I installed my 2-post lift.
For that "just in case" scenario, I just installed a double pole/single throw 30-amp switch just above the push button on the column of the lift. I now get in the habit of turning off the switch anytime I am not using the lift or leaving the shop for the night. Much quicker to get to than the breaker panel in the event of an issue.
Jking24
I have the same brand lift at work and the switch sticks sometimes. Mine isn't a contactor problem the switch sticks mechanically(doesn't spring back up) mine has always released with a little peck on the switch. The fact that it has always released has made me a little lazy to repair it. I like all the ideas mentioned here any one of them would work fine
Modern Garage
Southern Minnesota
I have to ask: How is this a problem?
I can't picture any damage from the pump motor running against the pressure relief for the twenty seconds it would take me to walk to the breaker box and flip off the power. Seems like an answer in search of a question, or am I missing something?
Joe
brownbagg
When I wired up my lift I put a 30 amp disconnect right above the motor for this very reason.
yes , me too, I got one of those quick throw amp boxes, the one with the lever mounted couple inches from switch
it has happen to me too, the micro switch got stuck
also it help because i can padlock off, keep my buddies away when im not home
woodzy
Se Michigan
Not car lift related, but at the tool shop I work for, the crane has an up limit switch and when you press the up button, the hook will rise until it hits the switch - at that point, if you don't release your finger (or if the button is stuck) it will kill the power to the up circuit of the hoist. Well, that works as expected except the time the operator lowered something to the floor and left the pendant go. The down button was stuck and the hook it the floor and continue to unwind until it started to wind the wrong way. Up went the hook until it hit the up switch - it killed the power to the upper button but that didn't stop the power to the down button. A few seconds later a large crack and the hook came dropping to the floor. Good thing no one was around.
firebirdparts
Kingsport, TN
They do not. If the lift is fully extended, it will mechanically stop and the relief on the pump opens. That doesn't hurt anything, but it does run the hydraulics at 2500 psi, and just generally it's a bad idea to get in a situation where a relief valve really really has to work, because it might not. If part of the hyrdaulics blew out, then the lift wouldn't fall, so it's not "unsafe" but it would sure be messy.
My lift has a couple of rubber lines here and there, so if I let them age old enough, in theory they would eventually break. So that's a concern.
Lifts which have a limit switch are usually trying to touch a car with the limit switch. It turns the lift off when a car touches it. It doesn't have any idea whether the lift is all the way up, it just knows where a car is.
Falcon67
Merkel, TX
Lift power, convenience outlet and motor rated switch at the pump
No. Mine would start to lift the roof until the rubber bumper sheared off, then continue up until the car lifted the roof LOL/Not LOL.
Chevy-SS
Rhode Island
Joe
Same question. My breaker box is 6 steps away, so I could be there in about 2 seconds. However, I can see if the breaker box is located somewhat far away, then a shutoff switch would absolutely be great idea.
sweetk30
Joe
i was lifting the car body off the front K-member with the engine and trans on stands and i was bumping the lift 2 sec's and stopping and checking for wires or hoses i missed .
so in this case you could have something still attached and rip it off or worse drop a engine / trans off the stands and have $$$ damages .
also some vehicles do not let you hit the safety cable / bar and could go up in to the ceiling and do damage t the shop and vehicle .
kbeefy
Harington, Eastern Washington
My lifts have a 30A plug wired in right above the switch. If the switch sticks I can pretty quickly unplug the cord.
The uplimit bar on my lifts only disconnect the button from the switch. If the switch is stuck the limit does nothing, could definitely crush a pickup cab.
I have seen the switches stick a couple times, usually from people 'bumping' them to move slow or a small amount.
JSK
Southern CA
Another poor-man fix would be to immediately press in the lowering handle. Oil would just bypass through the return line and pressure would not be able to build up. The lift would not raise. Might give you time to call for help.
428PI
Peabody, KS
JSK, good idea with just hitting the release lever. I just thought of it also. I had a lift at work once that would tend to "stick" but a quick second push of the button would make it release the contacts. I have a Harbor Freight hoist on my shed door that is starting to stick. It's kinda scary and could pull my door apart if not careful.
S4cruiser
NC
Happened to me with my Bendpak. Scared the **** out of me. Pushing it again and releasing made it stop. I think about it every time I push the button now.
Will be adding some sort of kill switch soon.
flyt100
Minnesota
That was me. Yep, I put another hole in the box and put another switch in series. I found that the return spring on the switch is kind of weak, and if the switch was pushed to the side, it could bind.
CJseven
Southeast Missouri
I installed a pendant remote switch on my lift several years ago, when I did I removed the original momentary and replaced it with a on/off toggle as a safety.
ItsNemo
Canada
My electrical panel is literally right beside my lift console (have an in floor mid-rise scissor lift). Unless I'm actively using the lift, the breaker is always off. The last thing I want is for something to accidently fall on the button and my lift to start rising while my vehicles are half parked on top (lift is centered but I usually park the vehicles left/right). If something ever stuck like this, it's a quick flip of the breaker for me.
tarmy
Nor Cal
I have those on my power tools…drill press (can hit with head if I am afraid to let go!) and table saw (can hit with my knee if afraid to let go!)4C2BFD7F-92DF-4F62-95DB-61F6BB5C7DAB.jpegF8FEA273-C3D8-4839-A1CD-6B65DD656346.jpeg
TurnipTruck
Southcentral Alaska
EFE7CD48-40A7-448E-926B-BDD5D7D92815.pngI had just received this Forward lift when this thread originally was posted, and used the link to purchase the STOP switch. Once the drywall and paint were done, I erected the hoist but didn’t lift much beside a steel table for a year while finishing construction.
This truck is the first expensive thing I lifted with my new hoist and the original push button welded itself ON. I panicked for hundreds of nanoseconds then slapped the paddle.
I dug around in my box-o-switches and found an industrial AllenBradley momentary that ohmed good and immediately installed it.
I took this picture the same day.
3F4938CD-55E9-40A8-8CB3-1E1524308316.jpegI tested the upstop later, and it worked properly, but the hood would have hit this side door track first.
CraigStu
Blacksburg, Va
I don't have a lift but did work on one for 25 years so I always read through threads like this. One thing that sticks out is that the uplimit bars don't seem like a very good idea. Don't they know we work on vehicles w/ a huge variance in height? I never thought about it before but maybe a limit switch on one or both main posts that contacts the lift head would be better?
