Eyes hurt with Miller welding helmet
afazz
Pittsburgh, PA
I had a Miller digital elite mask for ~10 years and it broke a few months ago, so I replaced it with another Miller. I bought the Infinity ClearLight Lens 280045 from Cyberweld. Immediately after using it, my eyes hurt while welding. It isn't welders flash (headache, sandy/bloodshot/water eyes, etc) but feels like I just looked at a bright flashlight. I tried adjusting the shade, delay, sensitivity, and everything else I could figure out how to adjust, but it still hurts my eyes and gives me the blotchy spots where the arc was, if that makes sense. I've switched to a $15 #13 fixed shade for now until I can figure it out, but obviously that's not a great solution.
Any ideas or thoughts? Is this something to be expected with the clear lens masks instead of the older ones that started at ~shade 5?
https://store.cyberweld.com/miwehebldiin.html
Jazz1
Thunder Bay On.
Return the hood, its faulty. Tell vendor the issue. Refund or replacement. Possibly Miller changed suppliers of the lens but I would want to exchange to give the Miller another kick at the can
BFBOB
Something's wrong!! Get rid of that helmet; don't risk your eyesight!
dogdog
Are you seeing a flash when you first start ?
Dead battery ?
That was my first thought... but not sure never owned a miller helmet... the HF ones is sealed... and it is not rechargeable... the Jackson I have has the battery easily accessible, takes 2x 2045
xOccupantx
Change the batteries.
I know it’s brand new, but that’s exactly what happens when the batteries are low.
Bretny
Dutchess county NY
This is why I only use a normal non auto hood. All it takes is a few millaseconds of a flash and I get what your describing.
driz
Northern NY
That’s just like my buddies El cheapo acted when it quit . Sore eyes and it welded ok just seemed bright and uncomfortable. Return it for another.
carmantl
I weld for a living and use an Elite. I haven't tried any of their newer hoods, but when any of our crew have problems with their hoods.....Change the batteries.
xOccupantx
A quality hood operates properly or not at all. Nothing in between. The lens operates at 1000’s of milliseconds.
Cool story, but I have the same exact hood which I’ve used everyday for 8 years.
That is exactly what happens when the batteries get low. So it’s best to change them yearly as preventative maintenance.
ItsNemo
Canada
Get new batteries but put a meter on the old and new (use the 10 amp setting) and see what they read first. Will tell you pretty quickly if the old batteries were dead or not.
Otherwise, I'd exchange it. I have a digital infinity and can't say I've ever had the feeling of sore eyes from it.
A
afazz
Pittsburgh, PA
Thanks for the tips, I'll try new batteries and see if that helps. I'm a little concerned that battery life affects the switching speed and skeptical that the new batteries weren't good enough, but I'll try it first before contacting Miller.
bbbarracuda
I don't know what batteries are included with welding masks, but i always throw away any batteries included with a new piece of equipment. Most "free" batteries are worth less than free.
kald
Central Fl
Are you getting reflections back inside your hood?
I like my helmet adjusted off my face and it happens to me if I wear a light-colored shirt to weld in. I made a neck/throat guard out an old glove wrist piece to block the light and it helps.
They make aftermarket ones but I wen the cheap route.
eaglefan1
This!! Nothing moves as fast as light does, not even auto lenses.
Pipeliner hood with a inch removed from top and bottom. Surgical tubing for a secure and comfortable fit. American Optics lens. Money maker
scubadoober
This, the infinity doesn't cover the chin as well as the elite and the side flare out more than the flat sided elite. It also tends to sit further from the face even after adjustment. I would fashion a leather chin cover or buy one from Miller, Tillman, or Black Stallion to name a few. I have seen the same problem with this same hood and it was from reflection.
A
afazz
Pittsburgh, PA
Updates! The Covid had me distracted but I finally ordered some fresh Energizer CR2450 batteries. They made no difference. Here are some videos, I’ve started testing with LED flashlights because the same thing happens.
Fresh batteries, brand new from McMaster-Carr good until 3/2029
Here are two clips that illustrate what I’m seeing, you can see the bright flash just before the mask switches.
And here is a comparison with the same flashlights used on a #13 fixed shade mask, proving that the flash is not a back reflection.
I also tried a few different techniques to block back reflections as suggested, and was seeing the same problem. Ask here is a shot of the mask itself.
So am I crazy, is this mask defective, or just junk?
