I am looking to pick up a 2 post and one or two 4 post lifts for my warehouse.
For the 2 post, I'd like to be able to put my truck on it (8500lbs). What is the main difference between the models that have a tie across the top, other than possibly crushing your vehicle if you aren't paying attention?
For the 4 post, I assume just get a wider one to be safe?
Are these layouts (lift in yellow) practical? According to the specs on my forklift I only need 8' isles. I know from experience I do much better with 10'+. Currently my cars are sitting 11' from the racks. Using one of the larger bend pack 4posts all the way to the wall it drops clearance to the post down to 10'. Tight, but it should work. I am debating dropping down to a 3500lb lift which should give me more clearance if it poses a problem.
My current situation
Usually I rotate every couple days except in winter where most aren't used at all.
Would appreciate some input on design and lift types.
