Any recommendations for a good hole saw kit
potentz
Altoona, PA
Looking to purchase a quality hole saw kit. Will use for both metal and wood. Primarily need it to start for electrical work. Thanks
Diablo
Im an electrician, ive used them all and always go back to starrett.
Diablo
Looks good, i have those in my van right now. I have the electricians kit though, its just sizes that fit conduit hubs.
garfunkle24
Saskatoon, Canada
There's also this style of holesaw that gives a nicer finish:
http://www.averytools.com/pc-757-32-rotacut-sheet-metal-hole-cutter--large-sizes.aspx
However, for the mixed work you're doing, I think the other kind would be fine. I've had them branded Milwaukee, Starrett and Lenox and they've all seemed about the same to me.
Snappy
S.E. PA
I'm assuming the Starrett set is made in USA, judging by the price.I saw a Bosch set recently for around $90.00, but it was made in China.I just bought a couple Lenox hole saws to fill in my set. The Lenox reciprocating saw blades hold up well.
Vinko
Los Angeles
Lenox could be Brazil or elsewhere. Not necessarily China. Though I bet you're right :)
Also -- I'm pretty sure I've got Lenox from Swedish and English steel too. Large band saw blades. Global Components probably often refer to China (as in teh case of Vise-Grip), but could mean elsewhere.
I have a Starrett kit, but also have bought some other sizes that don't come in a kit. Either 2-1/16 or 2-1/8, I forget which.
btmatt
I cannot believe that I am going to admit this, but I bought the Harbor Junk bimetal set to cut holes in 3/16 steel and they actually cut as well as any other saw I have used. A couple of broken teeth, but they will still cut. Trick is to go SLOOOOWWW and be sure to keep the cut oiled.
84scrambler
Livermore Ca.
I have a mac tools set. I think it was around $130. I would recommend this one because they actually warranty it. I already replaced 2 that were warn down.
scooby074
Nova Scotia
Lennox or Starrett
In that Ebay set, theres probably $80 there in Arbours and arbour extensions. Looks like a good deal to me (at least it would be here)
Atlascycle
Fremont, Ne
if you are making cuts through thicker steel try to drill a hole in the path of the hole saw teeth to give the chips from the hole saw to go to.
scooby074
Nova Scotia
Definitely. This makes a big difference in the life and performance of hols saws in my experience.
george4
N California
That makes a lot of sense, but if you do not mind elaborating for a dummy – how big of hole? Centered on the cutting path? Off to one side?
scooby074
Nova Scotia
I usually drill right in the centre of the outline that the holesaw makes on the metal being drilled. Typically its a 3/8 or 1/4 drill i use (whatever's handy). You may have to offset the drill abit so you dont drill outside the path of the holesaw.
You want a hole big enough to let the holesaw shavings clear easily
Atlascycle
Fremont, Ne
It depends if you are trying to cut a hole or a slug. If you are trying to cut say a 4" hole then you would want to drill a 1/4" hole 1.875" from the center of the hole so the outer diameter of the hole saw will line up with the outer radius of the chip clearance hole.
wreckercologist
cyber-tool hell
We just got a few new Starretts in the shop this week. Made in Taiwan.
I looked at the Rigids tonight when I was at HD. They were made in the US of global materials. Just an FYI.
Speed kills if you're sawing steel, so as was said before, no matter the brand, slow down and lube up! :thumbup:
Stick Figure
Omaha, Ne
anyone found a good set to go through stainless? We do a lot of stainless work, and a 1" hole in stainless exhaust pipe becomes way more trouble than it should be with some of the saws i've tried.
nissan_crawler
Wichita, KS
For that, you're better off spending the money on a good set of hole cutters, especially if you're only cutting something as thin as exhaust pipe.
danski0224
Near Naperville, IL
If you need to make holes in boxes/panels, up to 3/4 conduit fittings, it is hard to beat a step bit (Unibit) for that.
Bigger/lots of holes in thin metal? Go buy an annular cutter. The previous link to Avery shows that style. Hougen also makes them.
Holes in wood... to run 1/2 and 3/4 conduit in? Go get a self feed bit or an auger bit.
Bigger holes in wood? I have found nothing better (yet) than a Lenox carbide tipped holesaw. Their One Tooth line is supposed to be nice... don't own any yet. I have had my 2 5/8" carbide tipped saw for 5 years now and it still works great.
I would buy these: http://www.mcfeelys.com/product/LHS-/Lyropa-Drill-Drop-Hole-Saws before I bought the made in China Milwaukee holesaws.
This place: www.holepro.com has some saws that will cut through cinderblock and stucco- I have a few of those, and they work well. Unfortunately, their products are made in China.
