Hi-Lok Ratchets?
Bull
What are these things? I've seen ones that look like Protos, then others that look quite odd. :headscrat
mrshaun
Killeen - Fort Hood
hi lok ratchets are for use in aviation. They have a hole so you can put an allen wrench down the middle to hold the inside of a fastener while you turn, it. that is how one guy explained it to me. someone else may be able to do it a little better.
48548
Phoenix
This is correct, I have a couple of snap on, got them cheap, and the newer ones have a clip to hold the socket on as well, the older snap on I have you had to use a screw in the socket to hold it on, I just changed the gear out in the older ones, and kept the newer ones with the clip which works fine.
nissan_crawler
Wichita, KS
The good ones are gearless. If you can so much as twitch the handle, you can get a fastener loose with them. I have one at home like this.
Think of a hi-lok as a countersunk screw, but with no drive in the head. There's a female hex in the threaded end. You put the "nut" (hi-lok collar) on it, put your ratchet/socket on, then put an allen wrench through that hole into the end of the hi-lok, and tighten.
The collar has a ring cut into it, so the part the socket drives snaps off at a preset torque, leaving a perfectly round "nut" on the fastener.
Technically, if the hi-lok fits right, the allen wrench should never be needed in the first place, but that's another story...
