vanvanvanvan
Hello - I'm trying to figure out how I should insulate the roof of my detached garage. I've read a bit on here about the methods, but I'm wondering if there are specific recommendations for what this roof looks like.
The garage is in the Chicago area, and was built by a contractor. My goal is to be able to work inside it on most hot days, and most cold days - but if it is super cold and I can't get heating and insulation to make it comfortable, missing those days is fine.
The garage has a pyramid hip roof, with two vents near the top on two of the four roof planes. The garage is about 20' by 20', and the roof is probably from about 8' high off the ground to 12-13' off the ground. So far, my plan is to use R-13 faced fiberglass batt insulation on the walls - correct me if that is unwise, I haven't gotten far into installing it yet.
For the roof, I was looking at hiring a contractor for spray foam, but based on the pricing I've seen and the process, it might be beyond my hoped-for budget. Is there another way to do that roof that would work for this style garage? Also, I'm just planning to use that space for storage, once I get it insulated.
Thanks for any advice!
