Powerbuilt Tools
Fedwrench
Valley of the sun
Powerbuilt quality can be hit or miss. Some items like their Powerbuilt pro series ratchets are pretty damn good for their price if you shop around.
In the past their reversible ratcheting wrenches were also quite good but, they may have switched suppliers since they're now color coded, incorrectly by the way as red is for sae. :wtf:
lardy1
Yeah. I was trying to get a good look at the Pro Tech series ratchets. It was mentioned that they resemble the Carlyle 72 tooth and I wanted to see. Their promotional pictures don't show the anvil side well enough to see if they have the telltale plastic insert covering the prongs of the retaining clip.
Coincidentally, Blackhawk 72 tooth ratchets (I think now outdated) have that feature.
Rabid Badger
They do.
Those reversible ratcheting wrenches look like they're made by the same people that make the double-ended low profile ratchets for Harbor Freight. If so, the mechanism should be quite sturdy.
WinMod21
I've had a Powerbuilt flex-head ratchet w/the angled handle (probably not pro series) for 35+ years that has always worked great and still does.
BlakeTheCarGuy
Roanoke Virginia
I have some PowerBuilt tools I have a front end suspension kit for cars from them it has the tie rod tools and ball joint tools and all that in there and it is amazing I picked it up for $110 at the pawn shop new it goes for around $300 or so I think and everyone is always asking to borrow it and I do have a set of the socket Allen keys and they are decent too.
MaximRecoil
Maine, USA
In 2011 when I dragged my '69 Dodge out of the woods, before trying to start the engine I wanted to see if I could turn it over manually. For that I needed a breaker bar and a 1¼" socket. I'd normally buy stuff like that online to get a brand I want at a [usually] better price, but I was anxious to see if that old 318 would start, so I went to the local auto parts store (I think it was Carquest at the time; it's Advance Auto now), and Powerbuilt is the brand they carried. I was hoping for Blackhawk, because that's the brand they used to carry, at least in the '80s and '90s, but no such luck.
In any case, the big 1¼" 6-point deep socket, which I only used that one time, seems nice enough. It rings like a bell if you tap it with a piece of metal, and the full-polish chrome and machining look good. The 24" breaker bar looked nice when it was new, and has always worked fine, but it has some spots where it rusted through the chrome. Granted, I've kept it in the trunk of my car (for use as a lug wrench) since 2011, but chrome plating that's truly good quality should be able to stand up to that without the steel rusting. The chrome-plated bumpers on my car are over 50 years old and have been completely exposed to the elements for all that time and they haven't rusted.
sreeb
SoCal
This. For $46 for an 11 piece set those could be a great bargain. Hopefully the anti slip open ends are semi decent. They forgot the 19mm though :(
An even better bargain at the current $41 hopefully. I just ordered one.
sreeb
SoCal
I have the ratcheting wrenches in hand.
They look and feel OK. Appearance and "feel" are good.
Back drag seems a little high but I don't have any similar to compare with.
I'm not too sure about the no slip open end feature. Time will tell but I have other open end options if I don't like them.
Overall, I think they were a great buy.
