Air Compressor Takes Flight
Davefr
OR
Wow!!! A 100 gallon compressor must be close to 1000 lbs and for it to take off and fly over several homes is amazing.
MrSurly
East Texas
Seems...implausible, but then, it doesn't sound imPOSSIBLE>
Maybe rather than the compressor it was an auxiliary tank or a gas cylinder being charged?
pancho400cid
Austin, TX
A 5 HP compressor runs for several minutes then shuts off when the pressure switch trips at the high setting.
There is MORE than enough stored energy on tap to move a thousand pound compressor "several houses down".
Gives me the willys. I'd really like to see if the compressor was in fact mounted on the tank (roof hole on re-entry makes me think "yes"), whether it was a horizontal or vertical tank, and exactly how the tank ruptured.
My pet theory is that horizontal tanks are scarier because the lengthwise weld at the bottom (where the water accumulates) can unzip. I've seen vertical tanks get pinholes/rust out but never get a long split. Not saying it couldn't happen you understand.
sberry
Brethren, Michigan
Evewry once in a while something happens to one. Never know if the owner was fooling with it, if it was stock or someone fix it better. The why would be real interesting since its so rare. Millions and millions of comps in service and lots of them do not have the water drained.
NUTTSGT
Northern Central Ohio
Could have been a home brewed unit that someone put together sans a pressure switch or one that failed.
If a pressure switch failed, I wonder how high the pressure would get before the tank relieved itself ?
sberry
Brethren, Michigan
Both switch and relief failed? I used to fix a lot of stuff better, bout killed myself a few times. Lots of stuff, especially "listed" type stuff has been very carefully assembled, some so simple the safety is not obvious. Wood burning furnace is a good example. So simple, so much back and forth to get them right. **** we take for granted and dont give a thought to or may not even make sense to start with. Mess with it a little and it is compromised.
csp
Franktown, CO
The video clearly stated that someone working with the compressor accidentally damaged it.
I would interpret this to mean that something happened which damaged the tank enough to make it rupture.
mike93lx
Richmond, VA
**** like this makes me want to find ways to not need air in my shop, beyond a small portable compressor.
Sure it is rare, but when **** goes sideways, it makes a hell of a mess
NUTTSGT
Don't always take what the media has to say for granted. Many times they get it wrong as they "interpret" what the fire report says as they have no clue what they are talking about.
Case in point, copy/paste from the OP's link.
When it came down, it ripped through the home’s roof, tore through the second floor, and came to rest in the first floor, per Pixley.
Look at the picture, it's a one story home. While it may have came through the attic flooring, that's not the second floor. A NFIRS report will show the amount of levels of the structure.
EDIT: I just sent an email to see if I can get a emailed copy of the NFIRS report.
rlitman
Long Island
...My pet theory is that horizontal tanks are scarier because the lengthwise weld at the bottom (where the water accumulates) can unzip. I've seen vertical tanks get pinholes/rust out but never get a long split. Not saying it couldn't happen you understand.
I share the same pet theory. The tank bell end is also thicker than the cylinder walls, and it's shape funnels water away from welds. Most of the photos online of exploded tanks are of horizontal tanks, but I do recall seeing one vertical one as well.
I've got an 80 gallon tank, and I'm sure the news could report it as a 100 gallon tank.
JRC3
Southwestern OH
I remember the compressor owner popping up around here last year asking about repairing a compressor tank a buddy gave him. He shrugged everyone off and fixed the pinholes with a couple drywall screws and some JBW. lol
dffay
Think of the guy at the house in between mowing his lawn and watching this thing arc overhead. Geez.
67carl
California
The link DRP provided has video footage from a ring doorbell showing it fly through the air! Screen shot from that video;
MrSurly
East Texas
Almost a certainty that it’s a Chinese tank.
Recall, anyone?
tdkkart
Eastern Iowa
It's not even a 60, I think it's a 30 or 40 gallon upright, watch the video, it's small in front of the firefighters, and did nobody notice it had no motor or compressor on it, just the tank, so more than likely a home made arrangement.
It doesn't take a lot for the motor start contacts to weld shut and let the compressor run on forever, or until something blows. I've had a pressure switch stick, which is why compressor circuit is wired through a contactor so the compressor doesn't get any power when the shop lights are turned off.
pancho400cid
Austin, TX
Yeah... Definitely at odds with my theory about horizontal vs, vertical.
More like 30 or 40 gallons as said, and with no pump/motor unless they got knocked off during the incident.
Secondary air storage with over-pressure relief removed maybe?
Pardon the poor screenshots:
D
DRP6833
Firestone, CO
Pancho, in your third screen shot, it's the little spec in the triangle at the top of the porch that's the airborne tank.
Stuart in MN
Minneapolis
I saw a little portable compressor where the pressure switch failed and the tank exploded. It was pretty much turned inside out and looked like a big potato chip. Fortunately no one was in the garage when it failed, but the car that was parked next to it didn't fare so well.
The news article does illustrate how there's a lot of kinetic energy in a compressed air tank.
JRC3
Southwestern OH
I was in this thread this morning before I went to Menards...Decided while I was there to pick up a 1/4" valve and line to make an easy drain kit. Also picked up a new pressure gauge to replace the old one on it. A couple years ago it got a new pressure switch and pop off.
pancho400cid
Austin, TX
Wow - You're very right... FIXED LOL!!! Thanks! The video looks like that thing is rocketing down from outer space.
My 60 gal Cambell Hausfield vertical is from 2002 IIRC and I have a Speedaire horizontal that's significantly older than that. I'm thinking it's time for a replacement.
The Tool Tyrant
Bonita, Ca. (San Diego)
Very interesting. Looking closely at the exposed ripped steel, it looks shinny rather than rusty and also looks like the failure was not at the weld seam. Being as no pump or motor, I'd guess it was being used to boost storage capacity.
Could be the receiver was being over-pressured beyond it's MAWP, as in it was designed for a maximum of 150 PSI and someone was pressuring it to 200 PSI or more.
I know that my Quincy QR-25 325 is rated to 200 PSI continuous and 500 PSI intermittent...so who know what some bozo :eyecrazy: was trying to do :wtf:
rlitman
Long Island
The motor and pump don't just separate from a tank cleanly on their own, so clearly this was an old tank being used solely for storage.
However, the broken pressure gauge shown in the video tops at 100PSI, and the needle is on zero, so I don't have the feeling that this was all that over-pressurized. But who knows.
NUTTSGT
If you look closely, the pump/motor mount spots ave surface rust. There is also not scratch marks or gouges in the top where the motor/pump should be, not even a section of broken off corner still attached.
I'm still thinking home brewed concoction. Notice they haven't talked to the owner of the tank ? Atleast not that I have seen.
Ponco's screen shot
NUTTSGT
Again using Poncho's screen shot.
The large plug on compressors . . . I always figure were an inspection plug. :dunno:
Does anybody have one that is tapped with a smaller bushing in it ?
Showkey
"MEMBER EMERITUS"
Wausau WI
When the myth buster did the water heater to failure and flight......they were at over 300 psi.
walta
Dutzow Missouri
I would not argue with the 100 gallon claim without a tape measure. From the photos the tank may well be 24 inch diameter and 48 inches tall.
Given it failed at the weld it must have been way over pressurized.
The tank looks to have a welded on tag making likely to be an older US made tank.
I would guess it was rated for 150 PSI and that weld was factory tested to 300 PSI. That begs the question where did a home shop get 400 PSI air to blow the tank? Very wild guess is someone got hold of a scuba tank compressor and was fitting this tank to it.
Can anyone make up a better story?
Walta
