rburke65
Hi Guys and Gals.....For everyone that has OSB in their shops and garages, are you happy with it? Would you do anything different if you were to do it again? Looking for some input before I build. Thanks
Did you just hang and paint or caulk and or cover joints with furring strips, or....?
Lots of folks seem to like it. I think that is is somewhat out of place when you see someone go through hoops and sweat bullets agonizing over the epoxy floor, yielding a floor job that is way too good for a shop environment and then slap this cheap, smelly, formaldehyde-out gassing excuse for sheathing on the walls. Some guys say that they hate to tape or they can't do it...LEARN. You have many more walls in your house that will need repair or remodeling and you ain't gonna get away with OSB in there.
If you use a circular saw to cut the sheets, make sure to use a straight edge to keep the cuts nice. If you take the time to keep the sheets square, you really won't have a gap.
How about both? I hung OSB, then drywalled over it. My purpose was mostly in noise suppression - I caulked the studs, and between the OSB and drywall - but it's nice to have smooth walls and still be able to hang stuff anywhere. The downside is finding the studs when it's necessary to do so. Very difficult!
Mark
I went with t1-11 for my interior siding.
It's exterior grade, so some water won't hurt it.
It has edges that are designed to be overlaped so the seams disappear. I think it looks great. I just left mine unfinished, but you could stain it or paint it or whatever if you wanted to.
Phil
To properly install OSB, you need a minimum 1/8" gap on all edges and around all openings to allow for expansion/contraction due to moisture content.
One MAJOR little problem with OSB....FIRE!
Most codes require 5/8" drywall....especially if one wall is next to a house or close (< 5') to someone else's property.
If you get a small fire in the garage...the OSB is going to go up like a match.
OSB going up like a match? I don't think so, due to all the glue, it actually kind of tough to get started...
Now, once you have a fire built against it with the OSB vertical and unprotected, you can get a decent surface burn. But under those conditions, the paper on regular wall board will also burn pretty good, then the gypsum will crumble and burn through. It makes a decent 30 minute fire wall.
Did you know that NFPA andOSHA allows fireproof flammable cabinets to be made out of plywood?
Howard
