FrankenTable Drill Press Bench
Modern Jess
Bay Area, California
I've been working on this drill press bench for months now. It recently showed up on the front page of GJ (before it was done, even!) but I figured I owed it to you all to post a proper build.
Here's the finished product:
And now, the build!
The idea kind of evolved over time. It started with a rickety old butcher block table that a friend gave to me many years back. It had seen a lot of abuse, and was infused with years of two-stroke oil from scooter engine tear-downs:
I turned it into a pile of halfway decent salvage maple, which sat on my workbench for another month or two:
Somewhere around the same time, I acquired this monster bench-top drill press that I've already posted about. It's a 60s-era PowerMatic 1150, with a three-phase motor and a VFD. Importantly, it has a fully functional variable speed feature, which (combined with the VFD) makes it really useful for metal work:
I was after a bench-top model because all the wasted space around a floor-standing drill press really bugs me. Every inch of my workshop is precious space, and I really hate wasting it. The stand I initially put the drill press on was okay, and about the right height, but was only marginally useful for storage. What I really wanted was shallow drawers for all the drill-related stuff that you use around a drill press. Stuff like this:
Before I actually acquired this specific drill press, I was thinking I could set a small bench-top DP on top of a rolling tool chest, and started to investigate the offerings from Harbor Freight. Once I actually got the drill press home, though, I quickly realized that it was far too big to set on top of a typically-sized cabinet. And at 250 pounds, the weight was a bit of a concern as well.
So I started thinking about building something shorter and more appropriately sized. Around that time, I discovered the Harbor Freight 26" top box, which had the advantage of being relatively compact and had very shallow drawers. I braved the pandemic and went to HF to pick one up:
I pondered how to proceed for a couple of days, trying to come up with a way to use the pile of maple from the butcher block table with this new top box. The challenge was to make it sturdy enough to support the drill press, and I wasn't entirely sure I had it in me. After some measurements and some rough calculations, I managed to put together a SketchUp drawing of what I thought might be a workable design:
The next few months would be a long slog of working toward that idealized goal.
The top of the butcher block had split, but the dimensions were wrong. I had to split a piece off one half and glue it to the other half:
In order to put the whole thing onto heavy-duty casters, I had to sleeve the wooden legs, which ended up being a full metal base that the rest of the table would interface to.
This was a good opportunity to improve my very, very awful welding skills:
The whole project was going back and forth between metal and wood, which I actually enjoyed. When I got bored with one, I would switch to the other.
I spent a good many hours planing the top, not so much for flatness as just to shave some of the oil-soaked wood off the top:
Then it was on to the legs, and lots of test fitting:
I used my Festool Domino in order to fasten the aprons to the legs, even though I knew that I would garner much hate on YouTube for daring to use an expensive tool. It's weird how some people get offended at something so trivial. Maybe they want me to use nothing but a butter knife and 40-grit handpaper? I don't get it.
Eventually it started taking shape:
As I was doing all the dry-fit before glue-up, I realized that I didn't have any clamps long enough to span the width of the bench. Not wanting to make a trip to HD (which I knew from previous encounters to be a pandemic ****-show) I improvised by adding some threaded rod to the project, bolted through the legs and all the way through the tool box.
This turned out to be a huge improvement to the overall strength and rigidity of the bench, as it made the tool box a structural member. There is no way this thing is going to flex or wobble.
It also gave it the bench's final name, as the threaded rod sticking out of the legs reminded me of a certain movie monster from years gone by. And thus, FrankenTable was born.
Not content with merely making it sturdy, though, I continued with the original wooden bracing I had intended, sending it well into overkill territory:
I then used carriage bolts through the aprons to reinforce the inner bracing even further. Belt AND suspenders. And another belt. And three more pairs of suspenders:
The final task was to seal the butcher block top, and for this I eventually decided to try my hand at poured epoxy. It actually turned out really nicely:
And then, finally, moving day. I let the epoxy cure for a good 48 hours, but I was still paranoid I was going to destroy it right off the bat.
Et Voila!
Oh, and I did end up buying the full-height HF tool chest, which will make a nice addition to my shop. This will be the new home for my machinist and metalworking tools:
Modern Jess
Very nice table and set up for that sweet PowerMatic drill press.
Thanks!
Your welding skills look far from awful as well
That's because I only showed a closeup of the weld that didn't ****. :) That particular weld was TIG, and didn't need any filler rod -- I just melted the corner into the puddle. Much easier to do that way. I used MIG on the underside of the frame, where it wouldn't show -- and really, I'm glad nobody will see it.
Modern Jess
That’s a very good looking DP stand. Great to use an old table and bring it back to live in the shop again. I’ll watch the video later tonight.
Thanks, and hope you enjoy it!
That is a very nice build! The maple top is beautiful! What became of the top of the toolbox?
Much thanks! The top is sitting out on a pair of sawhorses on my back patio. I haven't figured out what to do with it yet. Maybe it will come to me eventually.
Jeff Ivers
Oklahoma
Turn it sideways, add some shelves, and hang it on the wall?
mv213
Dallas, OR (the OTHER "Big D")
Just wow. I love the drill press! And I love everything about that table. Always enjoy seeing wood and metal used together. I wish my welding sucked as bad as yours, haha.
bimmer1980
York, PA
Nice job on the drill press table! I have a similar idea for one of mine, so it's helpful to see the end result on a project!
Can you elaborate a bit more on the electrical setup and the channel integrated into the wall? I'm assuming there is an electrical raceway around the perimeter of your garage? It looks pretty slick!
Hammer1963
Kentucky
Nice build! Great way to combine wood working and metal working. Using the top box like you did is fantastic!
scooterbum46
South Central Michigan / ex Gulf Coast Florida
Great build - I'm already thinking how I could use that some type of top box under a workbench now. May I ask though, why didn't you countersink the threaded rod ends into the legs? I'm just thinking the maple legs are more than thick and strong enough to sink the nuts into the legs.
Modern Jess
Thanks! I've wanted to combine the two for years, but have either lacked ideas or time or both. Lately I've been trying to improve the metal side of my shop, and this might be the first tangible result of that.
If you like metal and wood together, there's a YouTube channel (not mine!) that you might like: Scott Turner | Forme Industrious. Lots of videos, most with metal and wood.
That might be the nicest thing anyone's said to me all week. :)
Modern Jess
Thanks!
It is in fact electrical, and it supplies the entire perimeter of the shop. The product is WireMold 4000 series, and it's about 1 5/8" deep. It looks like it's recessed into the wall, but actually I thickened all the walls to make the electrical panel flush, adding 1 1/2" of insulation in the process. There's a link to my workshop build in my sig, where I show the whole build process.
Below the electrical is some aluminum strut channel, which will eventually have air lines running around the perimeter of the shop as well.
Modern Jess
Wow! That is really nice!!
Thanks much, glad you all liked it.
I'm pretty pleased that the dimensions ended up working out. I've gone down this kind of path on other projects where I just couldn't make the dimensions work, and ended up giving up in frustration. I got lucky with this one.
You're absolutely right, and I spent much time debating that with myself and with a couple of good friends who were following the build in real time. At some point, I christened the build "FrankenBench", and the threaded rods kind of built on that theme -- they remind me of the neck bolts from Frankenstein's Monster. I ultimately decided to celebrate that fastener rather than hide it, in keeping with the theme.
If I get tired of them, I can always recess them later. More likely, I would do what I did on the corners, which is a black carriage bolt through the leg and then a coupler nut on the other side to a piece of threaded rod. You can see in the video, those corners start out just as threaded rod with nuts on the end, but in the finished product, they're carriage bolts.
Abeo
Calgary, Ab
Nice job, really came out well.
When I saw the ends of the threaded rod, I thought it would be a great place for a pair of push handles that span the two... if you wanted to hide the ends, you could trim and add some acorn nuts. Not sure if their height works out though.
You could also use them as mounts for towels, spray cans, etc.
bigguns69
Iowa
So you took the lid off the upper cabinet in your design. Looks good. Not being able to access and use top volume would bother me.
Modern Jess
Yep. Not a lot of ways around that. I could have cut the top edge of the box off, but in the end I needed the DP to be at a particular height, so shortening the table wasn't an option. Given how much extra storage I gained, it's a small loss.
Plus, I figure I could slip used razor blades through the gap and never fill up the space for as long as I'm still alive. :)
Precisefastcheap
CA
I really like the build as a whole, but I am particularly interested in the drawer dividers. Where did you get those? They look like they could be a great option for parts storage.
Monza Harry
Windsor ON
Since this thread was resurrected, I had to re-read this to refresh my memory of the fine details, and I am really impressed with the finished result! You repurposed a less than well taken care of Butcher Block table and really brought out the previously hidden "Beauty", you used the available space to a high degree. Well thought out project! For your "Franken Bolts" you could put some 1/4" X 1" flat stock across them and hang your "C clamps" on, just an idea. So if/when you refinish the drill press would you do matching/complimentary colour? Thanks for Sharing! Harry
