Sand Paper Storage
Enad308
Melbourne, Victoria
Hi all,
I'm doing a little revamp of the garage and looking for storage inspiration for all my sand paper, drives me up the wall at the moment!
Cheers
Dane
Ing3018
Michigan, USA
The flat full size sheets store well in hanging files. I keep mine in a file box, organized by type and grit. I keep discs in their boxes. Belts hang on a nail.
PelicanPines
31 pocket accordion folder.
There are almost 30 sandpaper grits, so it works out well.
This... in flexible plastic... from Sears... says Craftsman on it... pretty sturdy... has held up over the years. Not as many slots tho...
didit
S.W. Ontario
Expandable file folders are great for keeping full sheets stored according to grit/type. I do need a file cabinet to keep dozens of different type discs, air file paper and rolls organized. This has always been a 'back-burner' issue for me and I have more curled edge paper on hand then should be, from improper storage. I am looking forward to seeing your responses.
niget2002
Josephine, TX
I use the beige metal cabinet in the center left of the picture. Full sheet down the right side. Round hook and loop in the middle. Each grit in its own drawer. 787bc7dc63bd6bb24be025461ebed2bc.jpg
Sent from my LM-G820 using Tapatalk
Stuart in MN
Minneapolis
For storing sandpaper disks like you use on a random orbital sander I've often thought those plastic desktop cabinets for CD-ROM disks would work well. Since hardly anyone uses them anymore, you can find them at yard sales all the time for a few bucks.
NUTTSGT
Northern Central Ohio
I picked this up years ago. It would be easy to build from scratch. Basically it is a box the size of a sheet of sandpaper, with hardboard dividers with tabs so sort by paper size. The weight keeps the sheets from curling.
View media item 107102
I like those dividers.
I have my round diss in their boxes in an Akro-bin. The full sheet stuff sits in a cabinet on a shelf.
I've seen guys use a file cabinet and hanging folders for each grit. I always thought it was a good idea if you have a filing cabinet in the shop with your manuals or paperwork in it.
BMWBOB
Washington State
Used file cabinets can be found for a song: offices typically don't use them anymore. I got two 4 drawer laterals for nothing. We're talking Steel Case, heavy duty cabinets. I've got hanging file folders for the sandpaper, but I've got ALL of my power tools and consumables
in there too.
The good ones won't let you open more than one drawer at a time....
Vahispd
SE VA
My sandpaper is in different drawers in different cabinets, so I'm in for better ideas.
nadogail
Coronado, CA
I store sandpaper sheets in their packets flat on a flat shelf. I only buy a single packet of each of the grits I use.
CraigStu
Blacksburg, Va
I have mine laid flat w/ a sheet or bright construction paper separating the grits. I have been thinking but not building a box like Nuttsgt has but w/ shelves. I think his idea of loose dividers vs shelves will get me actually building.
NUTTSGT
Thanks but I quoted another member. The credit goes to him, not me.
E
Enad308
Melbourne, Victoria
How about mail sorters found in offices?
My wife is a teacher and she is bringing me a metal one home tomorrow, she organises colours for the kids with Bull clips that you can label easily enough. Will let you know how it goes.
(Insert your countries spelling and object equivalence throughout the last paragraph)
:beer:
LS6 Tommy
Northern NJ
Hooked
League City, Texas
Made a 'folder' about 50 years ago using 2 pieces of masonite cut to the size of a full sheet of sand paper. The 'hinge' is a couple strips of canvas glued to each of the pieces of masonite. I made it to hold what I had with expansion to hold 2-3 times what I had at the time. We're talking poor boy style folder which I eventually outgrew so the canvas straps were removed but I still use it laying on a shelf. The weight of the top piece of masonite keeps the paper from bowing up due to the humidity. :)
brownbagg
if i got to have an organization for my sandpaper. im spending too much time in the shop
SuperCat
Sacramento, CA
The accordion file is a genius level idea! I like the labels for the different grits.
I am worried that it may be too organized for me and cause my brain to explode. LOL.
Thanks guys, every day is an education here. :thumbup:
Fatboy148
I like my paper stored flat vs on it's end. I keep the paper in the factory sleeves. It's not nearly as handy as having individual shelves for each grit but I use milk crates turned so the opening faces me. On the top of each pile, I have a chunk of 2x8 that puts a little weight on it.
shopnut
Florida
I bought one of time card racks years ago and STILL haven't put it up...
If you cut down your sheets so they are ready to go on a sanding block, the old time card racks can work. The right size rack might work nicely for the palm/DA sander disks too.
Here is the used one I picked up for a song years ago.
Right now, I have all my full size sheets stored in an expanding file. It works fairly well.
lilredex
Toronto
Found this Canada Sandpapers storage box a few years ago, it appears to be "one of a kind" as I could find no other info on it.
Sumboodie
AK
I don't think I've ever bought a sheet of sandpaper. I use a grinder or 5" disc sander, usually 40 grit for rough pass and 80 or 120 for finish.
Just use a disc for rare times i need to hand sand.
