My Garage Build 24x24
NockOn
Halifax, Nova Scotia
Might as well start my own tread LOL
I'm building at 24x24 detached garage on a monolithic slab. Been very frustrated with the delays of getting my building permit. Took 35 days pushing me back. As soon as I had my permit I contacted my contractor for the slab. Finally it all started last week Friday 16th October.
Was hoping for as little digging towards the back as possible to getting rid of some squishy stuff. Well the pictures tell a different story LOL
They had to dig up to 5 feet of very smelly mushy stuff, it was like Jello. Took them almost 2 days to hit bottom.
I have a big whole on the other side of my house so they dumped it all on that side as it will never get built on. Also once it dries out it will make decent fill to just seed grass over.
N
NockOn
Day 2, they started filling in the whole with what they call 4/6. Its rocks from 4 to 6 inches. 3 loads were planned and they used 10 :willy_nil
old__man
Gander, Canada
If it makes you feel any better 3 years ago it took HRM longer than that for my garage permit.
How high are your walls?
old__man
Gander, Canada
They used the same thing on mine. You know you've reached a new level of adult hood when you are paying good money for a bunch of rocks.
N
NockOn
Day 3 they kept at it and the base started to take shape.
N
NockOn
Day 4 I wasn't home so couldn't do much got my Son to snap a few pictures before it got dark.
N
NockOn
Ain't that the truth. I was telling the guy digging that for every scoop is was bringing up I felt money slipping out of my pocket LOL
N
NockOn
Thursday (Day 5) was busier. As they were laying out the forms, one of the guys dug my trench for the power. Good thing because they pulled some huge boulders that I couldn't have moved on my own. We put the conduits in through the slab for a clean finish.
N
NockOn
Day six was more of the same. I kept adding conduits for my power and communication. I'm now 10 feet from the house and will handle backfilling on my own. I also want to keep that end open for inspection just in case. Forms are all finish and all spiked in with 6x6 and rebar all the way around. I've also gone around and marked all my J-bolts. If the J-bolts are at the wrong spot, I'll have only myself to blame for it LOL
Also by the end of the day the base for the driveway as also in place. The plan is to pour concrete Monday.
N
NockOn
Nice size build. What are you framing with? 2x6 and trusses? Heat and insulation?
What’s going to happen in there?
Thanks for the question. Walls are 2x4x9 I wanted an extra foot to be able to move a sheet of plywood without denting the ceiling LOL
Im using engineered trusses and I'll have 2 ply 9 1/2" LVLs for my garage door header
I'll have heat using a 12K BTU Heat Pump and Obviously insulating walls and ceiling.
Cheers,
old__man
Gander, Canada
Yes I got this guy that operates to -30C: https://senville.ca/12000-btu-mini-split-air-conditioner-sena-12hf/
Just came in a little early yesterday LOL
Interesting, that's the exact one I installed in mine a few weeks ago. So far it is way better than the old money sucking resistance heater I had in my previous garage.
If you are doing the install yourself be prepared to have to cut the factory flares off, a couple of mine weren't exactly stellar.
N
NockOn
Nice, did you install it yourself or got someone else to do it?
old__man
Gander, Canada
I did it myself. Too expensive to get it installed. It is a bit of a gamble as I couldn't pressure test it (didn't have the right adapter for my welding tank) but it was a risk I was willing to take. All my tools were bought of amazon. The instruction manual that comes with the pump is actually very nice. Well laid out and lots of pictures and explanations, it's definitely written for the novice.
In Halifax you should be able to find someone willing to just do the hook up for you.
N
NockOn
I’m planning on doing it myself as well. I have a friend with all the tool who has help a dozen people already. I used to fix airplanes for a living so I figured a Heath pump couldn’t be that hard [emoji39]
old__man
Gander, Canada
It's really not hard and this is coming from a person who breaks aircraft for a living.
N
NockOn
Ah ah, don't take offence but we use to tell ourselves between techs that it took more smarts to fix them then to break them LOL. I've had a few instances of getting called on the flight line for a broken radio and I just had to turn the O-N-O-F-F switch to the ON position. But that was usually new pilots being trained.
N
NockOn
Sorry Captain I missed part of your question. The garage is going to hold at least one car in the winter. It’s going to get some storage shelves on one side. The back will have a workbench. I like to thinker and used to do woodworking. House is fully finished so nowhere to play and with retirement in sight in 5 years, I need somewhere to escape. I might start doing my own oil change and swapping my tires in spring and fall as I use winter tires on their own rims.
old__man
Gander, Canada
I ended up doing 2x6 with 24OC so that I would have less thermal bridging. How thick is your slab? Ever think you will put in a hoist?
It is unfortunate you are building now, lumber/OSB prices seem to be the highest in history.
captain14
Im curious why only 2x4 walls in your area? Wouldn’t more insulation in 2x6 walls pay you back quicker. You should be able to do other things beside watch your retirement money go quickly with less insulation.
Will anyone help you lift the walls as you build them?
Every little project you do allows you to gain a little more confidence with your wood working time.
N
NockOn
Its just a garage so didn't care too much about insulation to an extent. I grew up in a house that was built wit 2x4 and dont remember ever being cold. Might cost me a little more in power for the heatpump LOL
Slab is 10"x12" on the perimeter with 2 rebars and 4" in the middle. I'll never have a lift in there. If I need anything done that needs a lift, my mechanic can deal with it. I don't mind doing little stuff but my days of tearing cars apart(I rebuilt a Fort ****** EXP years ago, including rebuilding the engine) are over. Woodworking is more my thing
N
NockOn
Most garages in my area are 2x4 some go 2x6. Insulation and heat pump is more to control humidity then for temperature control.
I'll be splitting the walls in two, 12' each section plus my 22 years old is doing University from home so I'll have him out when its time to lift walls.
captain14
Ah, it’s character building great? Having your son help you lift the walls?
Very similar to someone using a reel mower to cut the grass instead of a gas push mower.
N
NockOn
Sorry been so busy building from 6AM to after dark that posting pictures has fallen to the wayside. Will take a few minutes tonight and try to upload what I have on my phone.
N
NockOn
Here's the pics from the slab and a few details
N
NockOn
Walls going up and the Trusses. Yes we had snow overnight and had to shovel before starting the next day :-(
N
NockOn
Cutting the trusses tails to get a 18" overhang on the eaves. The trusses in stock were 24" overhang. The wait was 8 weeks to get custom ordered trusses.
N
NockOn
Rakes. I think they turned out great for a guy who's not a carpenter but an electronic tech LOL
N
NockOn
Roof Sheathing and Shingles. I finished at 11PM that night. Little Giant ladder was best thing I've purchased in a long time.
N
NockOn
Installing the faschia boards and the jig i made to make my life easier as I build mostly by myself
Slowbuilder
Chandler, AZ
Did the excavators do anything to enable the water to drain out of the 10 loads of 4/6? Seems like you would want the base to stay as dry as possible through the freeze/thaw cycles.
N
NockOn
Nothing could be done it’s just how that area is. But it’s about 5 to six feet under the slab so shouldn’t be an issue. My house basement sits lower then the garage and 18 years later, no issues.
