Occasional heat in attached garage
Ralphxj
NE Ohio
I have an attached 2 car garage, I believe it's 25x25x8 and fully insulated. I plan on using it for some baseball hitting a day or 2 a week during the winter. Looking for a way to heat it up just enough to not freeze when we are hitting (50° max). I have a small kerosene heater from an old appartment, but its WAY too small although I have used it out there before. Thinking propane might be my best bet, I have 3 tanks I keep full for my BBQ so I could use one of those. What would everyone suggest?
PWilks
Minnesota
I would buy a cheap torpedo propane heater from menards or HD and prop the door open an inch or two while it’s running.
rharman
SoCal
I bought something similar to this. Works great. Just crack the garage door for ventilation.
Search Amazon for "Propane Heater". It was about $100.
Lennyzx11
Bennington Vermont
One disadvantage of propane that in unvented like this is condensation inside an enclosed area. I know the OP was told about cracking the door. Not good enough.
Propane releases water vapor pound for pound and carbon dioxide when burned.
Another way is 4 cubic ft of water vapor is released for each cubic foot of propane.
Or around a quart of water per hour on the typical 30k heater usually found.
Disclaimer. I’m no expert. Just someone with a few years of walking into a cold winter shop and having ice inside on a cold morning.
In my Vermont shop, I see water condensation form on all metal and glass surfaces and the pegboard walls. Tools and parts were rusting in the boxes.
Non vented propane heaters makes a quick heat but a vented system is better.
Though I use a wood stove now and a wall vented propane mobile home type wall furnace on a thermostat set at 45.
The propane heater carries the load well when I’d rather raise the thermostat than build a wood fire.
(Read being lazy)
This helps keep the concrete floor and interior from large temp changes. Actually works out cheaper this way and a lot more comfortable than heat up, cool off cycles. The wood stove brings temp up to 65-70 pretty quick and dehumidifies the area.
An attached garage has some restrictions my detached doesn’t also so be safe.
Ron_J
Central PA
I don't care for the torpedo heaters. I tried the wall mounted ventless heaters and didn't like the amount of heat they put off either. I ended up with a 240v 5000w electric heater and it worked great in my 2 car garage.
It would heat up the area where I was working in no time, and kept the whole garage comfortable.
the problem I have with them is that you really need to be able to mount it where it blows on where you will be, otherwise it will take longer to heat than you want.
https://www.globalindustrial.com/p/...DIOQTl4oUuY0SQ4PQN4eg1pFFAkgsRuhoC7r4QAvD_BwE
R
Ralphxj
NE Ohio
Would the extra moisture from propane be any worse then any summer night when the humidity is like 150%?? I figure once we are done in the garage and I have to move the Jeep back into the garage the dry winter air will even out the extra moisture from the heater?? Not sure how that will all work. I thought about electric, but figured that would be more expensive??
Ron_J
Central PA
Yes, it is. But in my experience, to heat it for a couple hours 2 or 3 nights a week didn't even register a second thought on the bill.
I would say it will depend on how often you plan to use it.
Jazz1
Thunder Bay On.
I used one of these 110v radiant heaters to keep 24x30 garage from freezing while out of the country. Normally I be stoking the woodstove
R
Ralphxj
NE Ohio
How do you heat the attached house?
If it is forced hot water, you have some good options.
Hot water with baseboard heaters. The problem is there is no heat on the walls on that side of the house, everything is on interior walls. I would have to RIP out walls to get heat out there. Actually just ran new lines into the house from my outdoor wood boiler, but didn't plan on needing enough heat to run lines into the garage.
R
Ralphxj
NE Ohio
I really only plan in using it, 1 day a week, 2 tops and I don't think I i would use it 2 days very often, so 1 day a week would be the most common.
Chuckster in NJ
Hunterdon County NJ
R
Ralphxj
NE Ohio
A BTU is a BTU. Consider opening the door to the house and placing a box fan in it.
The laundry room exits into the garage and it doesnt doesn't have much heat. When we remodeled that room I could only add a small baseboard in there due to the dryer vent placement.
BillK
Beautiful Southern Maryland
If you have electric available that is the way to go. I have something similar to what Steve linked to in my 22x22 attached garage. This is the one I have:
https://www.marleymep.com/products/qmark/unit-heater-muh35-series
If I turn it on when I get home by the time I eat dinner it will have the garage at at least 65 degrees no matter how cold it is outside. My garage is all finished and insulated except there is no insulation in the ceiling. Garage door is insulated and very well sealed, which makes a huge difference. Not sure how your temp are compared to here in Md. Might be a touch colder ?
510ebl
Southern New Jersey
Looks like it could be in the high 20s / low 30s up your way tonight (completely guessing where in NE OH you are)... maybe give it a try. You have nothing to lose? See what the garage temp is in the morning.
How tight are the front doors? Are they insulated? My attached, unheated garage stays over 40deg in the dead of winter, but we have a bedroom above so no loss through the ceiling. Adding insulation to my overhead doors and tightening the seals/gaskets added a minimum of 5 degrees all winter. I also rarely get much strong wind from the front of the garage. Leaving the door to the house open for a while makes a noticeable difference when I am working in there for an hour or two, but the door leads into a larger living space and not a laundry room.
I realize I have not suggested anything regarding adding heat, so I will add that my dad installed (about) 16 feet of 240V electric baseboard heat to the garage in the house I grew up in. It made a significant difference.
R
Ralphxj
NE Ohio
That all makes sense. If I was looking to keep it heating, I would have added a hot water unit (already have 2 I'm not using) when I redid my outdoor wood boiler lines this summer. The only time the garage gets below freezing is when its below 10° overnight. Really only worried about heating things up for an hour or 2 a week for now. I should probably seal up the garage door just to help things with and without the added heat in the shop.
BillK
That made the biggest difference of everything that I did. I actually replaced my original wood door with an insulated steel door that has all of the proper seals along the sides and bottom. That alone made a world of difference. I have my electronics bench in the garage and typically am out there a couple of nights a week at least and honestly cannot say that I ever notice it on the electric bill.
Tduby
Da U.P.
Sounds like electric radiant heater would be perfect just place it where you will practicing it will keep you warm while you are out there
acer66
Western North Carolina
You already have an inside wall and it is fully insulated so heating cost should not be so high.
I have a detached cinder block wall garage that only has ceiling insulation and I just keep two little electrical radiant heaters in there during the winter in there so stuff does not freeze in there and to take the edge off working in there and that made hardly a difference with my electric bill.
R
Ralphxj
NE Ohio
Looks like the cz220 is the winner. Even better it looks like Rural King has it for $62.99 on their black Friday sale!!
R
Ralphxj
NE Ohio
Ok, just installed the cz220 and so far, VERY underwhelming!! Either my fan is not working right, or this thing is VERY underpowered. I can barely feel any heat or air moving 5 feet away on any of the settings. The fan just seems very weak and isn't moving any air. Is this normal or is something wrong? I don't think this would heat up a small bedroom as it is right now.
Crazyjake8493
Upstate NY
Sounds like something is wrong. Two of my buddies have that heater and you can feel the fan from about 10 feet away, possibly more. They have no trouble with their heating up their smaller shops to 65-70 degrees.
I have the similar but larger 7500 watt model, and on the 5000 watt setting it will heat my 20x30 garage (8ft ceilings, insulated) to at least 60 degrees on cold days.
R
Ralphxj
NE Ohio
I'll double check all the wires. Hopefully tractor supply will let me swap it for a new one and not have to go through the manufacturer.
MikeF2316
Thornhill, ON
I suggest electric radiant heaters. Radiant heaters heat things, not the air. Get a couple and point them at where you'll be. I have 2 1500 watt (120 volt) heaters in my garage, they work great.
R
Ralphxj
NE Ohio
Are you certain you have it hooked up to 240 volts ??
Yep, ran a new circuit. I'll measure the voltage at the fan to make sure something didn't get connected incorrectly, but it should be good.
R
Ralphxj
NE Ohio
I used a plug. I'll double check all my connections and see if it's not getting full voltage for some reason.
R
Ralphxj
NE Ohio
I have full voltage at the heater! Was hoping it would be an easy fix. I'll check some more wires and then probably have to return it next week.
R
Ralphxj
NE Ohio
Well I tried another one and it was just the same. Guess I'll have to start looking for another option, the cz220 is just not going to cut it. More then 4-5ft away and its practically useless.
Steve in UT
Sorry man, I guess I steered you wrong. I actually have the comfort zone 7500 and it does a great job, even on low. I figured the cz220 sounded just right for your application.:( :confused:
Ron_J
Central PA
I'm surprised this didn't do the trick for you. I have almost the exact same setup and it does just fine.
How long did you let it run? Mine will make it comfortable within an hour or so...at least in the bay that the heater is in. It takes longer to heat both bays.
BillK
Ralph,
How long are you letting it run ? Like I said in my reply my 5000 watt heater takes about an hour to get my garage up to 60 degrees if it is 30 deg outside. I turn it on when I get home and then go in and eat dinner. By the time I am ready to go back out in the garage it is plenty warm.
I wonder if you are expecting it too work a lot faster ? The air from mine does not really feel that warm a few feet away from the heater but it does the job.
ezzzzzzz
No. A garage cannot be tethered to the home hvac. It is a dangerous idea should he or a future owner do anything that could put vapors or fumes into that system. I'd bet it is against code anywhere permitting is required.
R
Ralphxj
NE Ohio
I ran it for a couple hours and it didn't seem to heat up at all. I'll try it again tonight before I return it. I expected more I guess. I'll take a couple of my digital temp sensors out there and track the temps over a couple hours and see what happens.
R
Ralphxj
NE Ohio
Not sure how I would get vapors into a hot water system.
