Notgrownup
It gets decent reviews and I just need a basic welder in the shop. I don’t want to spend tons of money on a welder , I was considering a basicArc stick welder but I think the Flux core wire will be more flexible.
I recently purchased the Hobart Handler 140 for under $300. at Farm & Fleet. It will take a bottle or run flux core.
I would go stick before flux.
HF only has a 90 day warranty. You aren't going to be able to return it if it dies after 90 days. Sure you can buy the extended warranty, but at that point you might as well just by the equivalent machine for the same effective price from a better brand.NGU, Personally I would stick with the Harbor Freight. Why? Simply the Harbor Freight stores are all over the place. If you happen to have a problem with it simply return it. The other brand would more than likely send it out and lord knows how long it would take to return. Just my too scents worth, Ken
Get one that can be converted to gas.
I have a similar unit made by Century (90 Amp) and was ready to throw it out before adding gas.
If you learn stick, everything else is easy !I would go stick before flux.
That's really only true of the really cheap and nasty flux core machines.The problem with alot of the older and smaller flux core machines is they were AC and would make some ugly welds. But with mild steel flux core needs to be run DC. And guess what the Titanium 125 is DC and can make some good welds, even on thick stuff. This was two passes on each side, the center piece was 3/4 inch thick, done out in the field off a generator.
All I want it for is lightweight welding like welding a angle bracket on my trailer or a ring on there to bolt hold downs for my Harley in the trailer, very light uses...My son in law has a Stick, MIg, Tig, plasma cutter Oxy/ acet set up so if it’s heavier duty I can go there...
My shop is more set up to work on my Motorcycle and woodworking than anything but I think it would be nice to have a little welder around.
Why?
Especially since no one knows what is being welded.
Well my son in law told me today that he might be upgrading his MIG set up and I could get his Miller set up...I will see what he decides.
no, please dont, study ohms law before buying
That’s not a bad route. If that doesn’t work, I’d consider the Hobart before a HF unit.
My first MIG was a Lincoln flux core. Yes it works, but nowhere near as good as a unit with gas.
I’m with sberry, I believe I’d rather have a DC stick welder with small rods if I could get away with it before going flux core.
This is a gas mig set up Lincoln 140 ,... He is buying a Nice set up so I know where it’s coming from.. lightly used. All I need to get is a tank, mask, gloves etc?.
