Jberger93
I know they sell the 4 wire push connectors. But I dont trust them with the hot wires. Is there a trick to twisting the 4 wires together before putting a wire nut on? I am learning electrical and **** at this
Linesman pliers. 20 years ago when I was busting homes full time, I didn't carry linemans in my pouch. I used my angle head dykes to pre twist. It worked great then but I cannot get it to work worth a damn now.
Solid or stranded? I'll assume solid 12ga copper. Strip all four ~1.25" then hold them tightly together, pull all four tips together and twist on a quality, new and correctly sized wire nut.
I never pretwist and in over 45 straight years in the trade I can count the number of failed connections on one hand. I tug on the individual wires to make sure the aren't loose after I'm done.
Linemans pliers, but nowadays I just grab a Wago.
I like it!This just gave me an idea to cover almost all the bases.
Strip wires 2" long.
Insert all in a 4 hole Wago.
Grab Wago with linesman pliers.
Twist to get a good lay on 4 strands.
Cut off Wago.
Twist on Wire Nut.
Why not just use pushin connectors like Wago and Ideal? They're so easy to use and take up less space in a box than a wire nut for 4 #12 wires.
I think maybe some people are worried they will fail like backstab connections on devices. Have any of our resident electricians seen pushin connections fail (where the wire was fully pushed in)?
I’ve always used linesman pliers. I approach the wire nut like it’s main job is to insulate, not to hold the wires together.
I've come across 4-#12s over twisted with the end cut off with lineman's pliers (made up with red wirenuts). The wire engaged 1 thread on the wirenut which promptly fell off when touched![]()
The only thing in common is they both use spring pressure to make contact.Lots of love here for the wagos, yet everyone poopoos the backstabbed receptacle and switch???
