FS: Craftsman 80/100/150 Drill Press Parts & More
FrankLee
seMI, 48317
Price
varies
I've got lots of King-Seeley and Emerson Craftsman drill press parts. Craftsman 80, 100, 150; 12-1/4", 13-1/2", 15-1/2".
Lots of Craftsman 115.6962 motor parts.
Some parts shown are for table saws/band saws/jointers/grinders flanges.
If you don't see it here, ask.
I do have a couple cast iron pieces... most are pick-up only from s.e. Michigan.
See something you need or want? Send me a pm for price.
F
FrankLee
seMI, 48317
more...
F
FrankLee
seMI, 48317
F
FrankLee
seMI, 48317
Craftsman Pivoting Motor Mount
Repainted with Rustoleum Hammered Black
$30 shipped to you.
I'm using the same style mount for my column lathe.
img_1393-jpg.2189778
F
FrankLee
seMI, 48317
13-1/2" Craftsman 80 Spindle Pulley Assembly
Bearings turn smoothly. Internal splines in great shape.
$40 shipped.
F
FrankLee
seMI, 48317
SOLD
$35 shipped
This is a very nice upgrade from the factory quill lock.
This quill lock has the ball-end lever handle from a column collar.
The cylinders are steel, not softer zamac.
The sleeve cylinder is 7/8" diameter and 1" long.
The threaded lock cylinder is 7/8" diameter and 1" long.
The lever clears the spring tension knob. Very nice chrome.
Matches the ball-end lock handles for the head and table. It works perfectly.
This will fit Craftsman 80, 100, 150 and later drill press. It will also fit other brands.. Atlas, Walker- Turner and others.
F
FrankLee
seMI, 48317
Parting-out this Craftsman 150. This is a model 103.24501
All parts clean and ready for installation.
Shipping extra.
Hub/Pinion/Spring/Pin Assembly
Double-loop spring
Hub & feed handle rods are threaded 1/2-13
Scrapes on two knobs
$70
$60 (hub and feed handles only)
Female splines in excellent shape.
Original bearings are very smooth.
$40
Quill Lock Assembly #1
Nice chrome handle
Steel cylinders
Nice upgrade for an early 100.
$20
Quill Lock Assembly #2
Unplated zamac handle
Steel cylinders
$15
Quill Lock Assembly #3
Chrome on handle is not peeling, but has wrinkled finish.
Zamac cylinders
$10
Head Lock Assembly
Original blued finish
Steel cylinders
$20
SOLD
Rapid-Adjust Feed Stop Assembly
Complete.
New quill bumper included.
$50 (rod, collar, bracket and bumper)
$45 (rod and collar only)
SOLD Quill/Spindle Assembly
Quill with snap ring.
Run-out on the taper is ~0.002"
New sealed bearings
New rubber spindle washer
New rubber quill bumper
$70
SOLD Jacobs "Safe-Lock" Chuck
Model 633C
Refurbished... dismantled, cleaned and lubricated.
Key included
$50
SOLD Pivoting Motor Mount Assembly
New stud with jam nuts (may need to be shortened)
New rubber bumper
Some rust.
$40
SOLD Motor Pulley
Original drill press pulley matches spindle pulley profile
5/8" bore with key slot
$40
Tilt Table Taper Pins
Feed Return Spring - NOS
Feed Return Spring
Jacobs Chucks
Diamond Tool and Horseshoe GT28C Tile Nipper
Atlas Drill Press Parts
Craftsman Bench Grinder Parts
Parting Out a Craftsman Emerson Gen 3, 15-1/2" Drill Press
Sleeve/Collar for Craftsman 100/150 Drill Press MSA - Multi Speed Attachment
Craftsman Belt Sander Parts
F
FrankLee
seMI, 48317
Feed Return Spring
This is the loop & tang style spring for:
  • Craftsman/Dunlap 12-1/4" drill presses
  • Craftsman 100 15-1/2" drill presses
  • early Craftsman 150 15-1/2" drill presses
Very good condition!
$45 shipped
The pinion shaft on a Craftsman 13-1/2" drill press shaft can be slightly modified to accept this spring.
Many updates above
F
FrankLee
seMI, 48317
This is the double-loop style spring for late 150s and several later generations of Emerson drill presses.
Part number 38989.
It's the same style as this one, but it's NOS.
Still sealed in its original wax paper bag. Original detached part number sticker.
$50 shipped
Feed Return Spring
Jacobs Chucks
F
FrankLee
seMI, 48317
bump
Many parts above are still available.
Refurb Hardware Kits
I'm fortunate to have a really great fastener store near me; Mid-States Bolt & Screw. So, I usually have an ample supply of standard hardware parts for the Craftsman line of drill presses and usually replace much of them in all my refurbs.
I have enough hardware to offer custom refurb kits consisting of some parts below based on the dp model. Let me know what pieces you need and I’ll forward a quote.
A. Spindle Pulley Retaining Screws
Size: 8-32 x 3/4" slotted pan head
Application: Craftsman 80, 100, 150
full
full
B. Model Number Badge Screws
Size: 6-32 x 1/4" socket button head
Application: Craftsman 80, 100, 150, Craftsman/Dunlap 12-1/4”, many other machines
A 6-32 tap is required with #36 (0.1065") tap drill.
full
full
C. Head Trim Panel Screws
Size: 6-32 x 1/4" socket button head, polished.
A 6-32 tap may be required with #36 (0.1065") tap drill. The '46 to '49 machines were already tapped for machine screws here.
full
full
D. Head Trim Panel Screws
Size: 8-32 x 3/8" slotted round head, polished brass.
Application: Craftsman 150
An 8-32 tap will be required with #29 (0.1360") tap drill.
full
full
E. Spindle Collar Set Screw
Size: 5/16-18 x 3/8" socket cone point
full
full
F. Leather Disk for feed handle assembly
Application: Craftsman/Dunlap 12-1/4”
full
full
G. Leather Disk for feed handle assembly
full
full
H. O-ring Rubber Spindle Washer
Size: 5/8" ID, 3/16" cross section
full
full
I. O-ring Rubber Quill Bumper
Size: 1-5/8" ID, 1/8" cross section
Application: Craftsman 80, 100, 150, Emerson Gen 2, 3, 4
full
full
J. MSA Pulley Retaining Screws
Size: 8-32 x 3/8" socket button head
These are much easier to use with a 3/32" hex socket wrench than a slotted screw driver.
I've also used these for Packard motor bearing covers, Atlas bearing plates and more.
full
full
K. Rubber Bumper for studs on early pivoting motor mounts
full
full
K. Rubber Tip for the belt tensioning rod
Application: Emerson Gen 2, 3, 4, commercial
full
full
full
L. Rubber Cord Grommet
Application: Packard motor bases with a 16/3 cord
full
full
M. Motor Mount Lock Screw
Size: 5/16-18 x 3/4"
full
N. Roll Pin
Size: 3/16" x 1-1/4"
Application: H&TL crank handle
Replaces the one-way grooved pin. Direct fit, re-drilling not required.
full
full
O. Patent Number Badge Screws
Size: 4-40 x 3/8"
Application: H&TL patent badge
A 4-40 tap will be required.
full
full
full
P. Head Lock bolts
Size: 1/2-13 x 4"
Application: Craftsman 100, 150
I usually replace the head lock handles with a standard bolt. Once the head is installed on the column, there is rarely a need to move the head. In addition, the head cannot be moved with an MSA or Vari-Slo installed. There is no reason to keep the original handle.
full
full
Q. Tilting Motor Mount Stud Bumper
Size: 5/16"ID X 1/2"OD X 3/32"CS (square)
Application: Late Craftsman 150, 2 required. Replaces a grommet that wasn't used as a grommet.
FS: Atlas Drill Press & Sander Parts
FS: Craftsman 100/150 Drill Press MSA Sleeve/Collar - Multi Speed Attachment
FS: Craftsman Belt/Disk Sander Parts
FS: Craftsman Bench Grinder Parts
FS: Craftsman Emerson Gen 3/Gen 4 Drill Press Parts
FS: Delta Motor Shaft Guard
FS: Diamond Tool and Horseshoe GT28C Tile Nipper
FS: Jacobs Chucks
FS: Powr-Kraft
FS: Stationary Machine Switches
