Questions on installing car audio system in my garage (pics).
Venumb
S. Central PA
I'm attempting to run a car audio setup in my garage but before I get too involved (and in over my head) I have a few questions...
What I'm running:
- Sony head unit without RCA's
- Line output converter
- 85W RMS @ 4ohm 2 channel amp
- 12V 70ah 600A battery
- 6V/12V 2A/6A battery charger
- (2) 10" woofers, (2) small mids, (2) tweeters all in the same box (pictured)
- remote bass control
What I need:
- inline fuse for pos cable
- capacitor
My questions:
- What is the best way to ground this system?
- What size capacitor will I need?
- What amperage should I run my charger at while operating this system..or should I not use the charger while the system is operating?
- Is there anything obvious I'm missing that I'll need for this system (besides earplugs..lol) ?
blazemaster83
Lacey, Wa.
you dont need a capacitor. your method should work, is that a sealed battery? if not it will produce fumes when you use it. a car runs at about 14 volts, and going down to 10 and below can destroy components. 12 volts should work. I would not use the charger unless it is a trickle down charger.
You can use a 12volt power supply like Daman suggested, just try to get the amp rating close to the amp rating on the amplifier.
Or it would be alot easier to just sell that stuff and buy a cheap amp that can run at the ohm setting the speakers require.
V
Venumb
S. Central PA
I can run this amp at 2ohm or 4ohm..the speakers are 4ohm.
V
Venumb
S. Central PA
Understood....
However, I'd like to try to make this setup work.
I've seen others do it. I'd just like to make sure I have all the loose ends tied-up before I start splicing and plugging stuff in.. ya know?:shocking::shocking::shocking:
Prototyper
Kalispell, Montana
I did the exact same thing for 4+ years in my shop. Used a standard cranking battery, charged with 2 amp automatic trickle maintainer charger. Only a couple times, when I had it playing pretty loud all day, did the battery run down to the point that the amp started to cut out. It will work fine for you, but I strongly recommend you get an automatic charger. Also a marine battery box is a good idea to contain any nasty stuff the battery may emit, as well as guarding the terminals from accidentally setting something conductive on it!
Get a charger, hook it all up, and let her buck!
Jon
V
Venumb
S. Central PA
Jon
Got one.:thumbup:
How did you ground / run your neg wire?
franksinatra
Minnesota
With out question save money and get a powered home stereo receiver. Heck if you sold your stuff you could easily buy an *** kicken system for your garage. I bought a Yamaha RX100 and a pair of Cerwin Vega RE30' floor speakers off Craigslist for 250.00 and my entire block complains. I dont want to be a downer , but dont waste your time with the DC stuff in the garage. :beer: G
Damn, Im too late. lol. Good luck! G
makgreens
ooltewah,tn
def get a dc converter at radioshack...50 bucks but alot better than a battery and charger
i gotta get one soon so i can add some stuff to my shop
V
Venumb
S. Central PA
I believe that's the route I'll go before it's all finished. Then I won't (technically) be "wasting time with DC stuff". :lol_hitti
makgreens
ooltewah,tn
yeah its a better route...ive got a nice stereo system i could put out there but with all the welding and metal cutting itd be pointless
go to goodwill,thrift stores, etc and get some home speakers and hook those up
did that in my last garage and it worked perfectly
Todd.Brock
Cincinnati
I understand not wanting to spend some cheddar and using what you have. Thats cool. If you are going to have to spend any money at all, For the 50 bucks at the Hack, You could probably find a Fischer 2 channel 25w amp that would even be enough to piss off the neighbors and a pair of speakers. Just my .02.
V
Venumb
S. Central PA
Oh no..I guess my multi-quote looked as though I was agreeing with Mr. Sinatra.
I was actually agreeing with you about the DC converter.
V
Venumb
S. Central PA
FWIW..I already have two home systems in my house collecting dust that I could easily drop in my garage but obviously that's not what I'm interested in doing.
I also have the car audio system you see pictured sitting and collecting dust. I thought it would be neat to hook it up in my garage.
While opinions on my selected setup are fine, what I'm specifically looking for is tech info on how to best install it. Hope that clears up any confusion.:)
kwhitelaw
wish I would have seen this earlier, as I just sold off an inverter cheap..
anywho, you really should use an inverter.. no need for chargers, no need to worry about battery fumes etc..
tdkkart
Eastern Iowa
You need to visit the packrat thread..........
79firebird
Victoria bc
look for an inverter out of a old vw van ive used them befor to run decks and charge batterys seamed to work real good
GSMetal
I had the same idea but changed my mind. I have a fairly nice boom box that I found at a resale shop for $20.00.
But it doesn't end there. I bought a really nice set of computer speakers with a sub woofer ($50.00) and then I put my old laptop to use to feed the internet music station Pandora.
It's pretty nice since when I work on my bikes I often have to reference something on the internet.
V
Venumb
S. Central PA
Great advice on the power supply folks!:thumbup:
I'm currently trying to figure out exactly how many amps/watts/ min./max. voltage is safe for my setup.
Looking at my power supply for my laptop it's specs are:
AC Input :100 - 240V~2.5A, 50-60Hz.
DC Output: 15 - 24V 5A Typical, 90W Max.
slopecarver
Erie, PA
Laptop power supplies are typically higher voltages than you would need, I was talking about a desktop power supply, they have a 12V output. You need 12-15 volts of input, car batteries get charged at about 14.3 volts.
kwhitelaw
most important is the amperage...you need to work off what your amp draws.. granted you will more than likely never run the amp at 'full tilt', but if it starts pulling 10a through this laptop power supply, you risk burning it up.
kwhitelaw
also, I see that the amp has high level inputs.. I'd just use those, no sense in running the LOC..
and I'll be honest, if you are only running that box, with no dedicated mid or high range speakers...its not going to sound too good..and if your bass knob plugs directly into the amp and adjusts say 80hz for example, that will require you to run full range into the box to cover all your frequencies, and allow the bass knob to function, but at the same time will cause the other speakers to sound muddy..you really need to high pass the smaller speakers in the box, which you more than likely cant do as im assuming the box only has a L/R input covering all sizes of the speakers...
mrb
ive modified a few computer power supplies to just run all the time. I have one running a 12v motor thats drawing 25-30 amps. These will run a car stereo no problem.
kwhitelaw
I guess possible then...I was working off what the OP posted of his specs..
V
Venumb
S. Central PA
I have my cross-over set on full-range..it sounds great,nice solid bass,with crisp and clean mid-high freq's. I have not hooked up my remote bass controller yet. I'll swap out the LOC for the high level input and see how it sounds.
A buddy of mine offered to give me two 12's w/ enclosures so I prob swap one of them in place of the box I'm currently running and connect two 3way 6x9's off the head unit. Who knows? I'm having fun with this setup..lol
kwhitelaw
Swapping the LOC and running it high level will allow you to lower the input sensitivity on the amp, allowing the amp to run cooler, and in a vehicle environment, help reduce the chance of noise being introduced into the system. Probably not an issue in this situation...
Switching in one of your friends subs and the 6x9'S will probably sound better, imo.. only issue is, the 6X9's would probably enjoy more power than the radio amp puts out...
its probably all a moot point though and should sound fine for a garage setup... :)
fireball 440
The only AC to DC converters I can find are for very low amperage. I have a 4 amp and the only others I've seen are 3 and 2 amp. I too have extra car stereo equipment I'd like to power in my basement. The low amp converters will power the CD deck, but not enough to power my 600watt amp and 2 10" subs.
Anybody know where to find the bigger say 20-30 amp AC/DC converters and how much they are? If they cost a lot I still have the radio thats in there, which is good enough I guess but it would be sweet to have a kicken car stereo instead.
kwhitelaw
here is the one I use..
http://www.hifisoundconnection.com/Shop/Control/Product/fp/vpid/1550776/vpcsid/0/SFV/30046
http://www.cascadeaudio.com/power_converters/power_converters.htm
Of course, I didnt pay that price (took 6 of them when my shop shut down)..If you peruse some car audio forums they pop up for sale from time to time..
kwhitelaw
WOW those are expensive! Guess I'll just keep the boombox I have now, which is fine.
they can be yes. at least new..at my shop, we had a single aps-55 running 15 or so amps, not all at once, but powered constantly, along with radios etc...
definitely pricey, but worth it if you need clean, regulated power.
mrb
you can do it with a computer power supply for about $20
mrb
any links? I'm interested in seeing a computer supply that will handle 20A continuous?
here is one example http://www.mwave.com/mwave/skusearch_v3.asp?scriteria=BA25817 20a @ +12vdc for $19.98.
on the output wires of it, connect the green to a black, and if a brown is present connect it to orange. Black is ground, yellow is +12v. connect all the yellow wires in parallel (each one is only #18 so you want to parallel all the yellow wires when feeding one large load), and parallel an equal number of black.
