In my main work area, I have two lighting zones each operated by a 3-way switch. Both zones feed from a single 20 circuit. Zone 1 is pulling roughly 6.0 amps and zone 2 is pulling 7.5 amps with the light fixtures installed. Zone 1 contains all magnetic ballast fixtures. Zone 2 contains a mixture of magnetic (much cheaper models than zone 1) and some electronic ballast fixtures. I have been running this setup for about 4 years now without problems. If you follow my build thread, you will recall I acquired a pallet full of new electronic ballast fixtures that will be installed sometime in the future.
I'm in the middle of revamping all my electrical wiring and since some of these fixtures plug into switched outlets, I decided to add a GFI outlet to this circuit for protection. I wired it all up and turn on zone 1 - everything was fine. I then turn on zone 2 and the GFI trips. At first I figured I was overloading the 15amp GFI outlet since the breaker was 20amp, but then I tried switching on zone 2 first and the GFI still tripped. My conclusion is the GFI doesn't agree with some or all of the fixtures in zone 2.
So the question is: Can some types of fluorescent fixtures trip a GFI protection regardless of the the amp draw?
