picts of your in-floor heat set ups.
E.rodz
st.paul MN.
please post up some picts of your in floor heat controls and pump set ups I am just setting mine up for a 750 sq ft.carport and would like to see some set ups done and please let me know how it works and how warm you run it. thanks in advance.
chevelle64
Re: picts of your in floor heat set ups.
Here's a few shots of mine. Set it up last year and had it set at 58 degrees. This year I'm setting it at 60. I think some heat from the pipes is affecting the thermostat, that's why I bumped it up a bit. I need to insulate the pipes a bit more. Probably should have placed the thermostat a little further away...hindsight. Very happy with the overall operation, no regrets. The system does not run very often at all, the garage is very well insulated. Hope that helps.
E
E.rodz
st.paul MN.
thanks for posting the picts.just out of curiosity how did you get all the air out of the system with you air seperator not at the highest point? how big of an area are you heating with it?
E
E.rodz
st.paul MN.
here is is far as i got this weekend.very time consuming .hopefully i can presure test later this week and install by next weekend.:bounce:
MN BIANCHI
Moorhead, Minnesota
Mine should be operational later this week. I am waiting for the off-peak controller and electric meter.
goshawks00
Damn and I thought air bags were tough!
Barry
nate379
Palmer, AK
Those little instant water heaters have enough power to them? :wtf:
Burl
Where Mountaineers are free
30 gal. NG water heater, 1000' total of 1/2" pex, I keep it at around 59 deg., been in operation about 1 month. Still getting the bugs (and air) worked out.
72Tunaboat
Snohomish,WA
A aouple projects I have done in the past.
A Waste Oil boiler installed at a Honda Service center
A residential install
tdkkart
Eastern Iowa
I believe the pump manufacturers recommend running the pumps vertical rather than horizontal. Laying the horizontal makes it hard for them to clear air pockets.
E
E.rodz
st.paul MN.
just checking out your handy workjust wondering how an oil burner can have no ex vent stack?just not finished? or am I just stupid if you ask my wife she will answer that one for you.lol.thanks for posting
72Tunaboat
Snohomish,WA
Sorry, I should have posted it with the photo. The venting wasn't done yet , as well as the wiring. Thanks for pointing that out. :beer:
rlme36
Can I ask where you got all your mechanicals? I am also looking to purchase the hydro shark set up.
thanks,
rob
nate379
Palmer, AK
This is mine. Heats the house and garage.
chevelle64
As far as getting all of the air out: I put water in through the fill valve, with the shut-off closed, and that forced out air and water through the drain valve. I kept the water flowing for quite a while to make sure most of the air was purged. The air seperator takes care of any remaining air. I'm no expert, I followed Radiantec's directions. My garage is 26 X 32 X 14. I attached a picture with the valves labeled.
duaneb9729
Pumps can be mounted in any direction except for the motor pointing down, it makes no difference at all to the pump or how it works in the system
E
E.rodz
st.paul MN.
thanks,
rob
I bought just about everything from menards a local building supply center.I will let everyone know how it works shortly.
5wndwcpe
Southeastern, PA
Here's mine
engineer2
Chicago burbs
Simple 2-loop counterflow system running off our home water heater to heat 500 sq ft basement family room. Really don't need the bleed valve. BTW, the Watts brand temperature regulator valve is ****. Get a Taco instead.
nate379
Palmer, AK
I was just curious, trying to compare to my boiler, which is either 90 or 95,000BTUs.
My boiler keeps my house at 70* when it's -20* out so I can imagine that your setup works just fine as well.
MN BIANCHI
Moorhead, Minnesota
The electrician just got is fired up yesterday. It has been below zero here for the last 10 days or so. When I talked to him today he said the shop was over 50 degrees after running less than 1 day. I will be out there on Saturday and check it out. Hope everything works as planned.
E
E.rodz
st.paul MN.
:bounce: its alive! got it hooked up and running last night slab was 24deg. 8 hrs later the slab is 56 f .I will post up some more picts as soon as i can.:beer:
E
E.rodz
st.paul MN.
wooohhoooo. its alive. !!!!! the system is up and running this system is heating 650sq ft. slab has went from 23f to 62f in less that 24 hrs.the boiler is a hydro shark 10000kw it is prob. spinning the electric meter wheel off and into orbit.I can't wait for the next electric bill.:thumbup:
Weedwaka
That looks great !!
What is the minimum flow rate on your Hydro Shark boiler ?
tdkkart
Eastern Iowa
That looks great !!
I assume you're asking about minimum flow rate before it will start heating, such as on some gas fired heaters??
HydroSharks, and other Seisco manufactured heaters do not have a minimum flow rate to induce heating. Rather, they use a system that maintains and monitors a very slight temperature difference between the input and output.
Just as soon as that difference is not maintained the boiler kicks on to full heat, where it will remain as long as the output temp is below the desired level. Once the heater is able to maintain the desire output temp it starts modulating back to a lower power level which it adjusts as needed to maintain output temp. Once water flow stops the output temp will obviously jump up, at which point the hetaer shuts down completely.
Simple system that works very well.
I am using a 7KW Siesco to heat my 30 x40 pole building, works great.
70ss
STL Area
[QUOTE
I am using a 7KW Siesco to heat my 30 x40 pole building, works great.[/QUOTE]
What are your heating bills?
tdkkart
Eastern Iowa
Not cheap, depending on your perspective. I figure that my shop is my entertainment. I don't go to the bars, I spend very little money anywhere else.
In the last 26 days I've used 895KW, yes I went and read the meter just for you(not really, I'm keeping some records and I read it every time I go out there).
So, apply that to your local rates. I keep the temp at 58* in 1/3, 50* in the other 2/3rds 24-7, which is plenty warm for me if I'm moving around, I don't wear a coat to the shop.
My average electric bill for the shop(seperate meter) the last 14 months has been $65/month.
The encouraging part this year is that I was only heating 16x30 last winter, made some insulation improvements over the summer. This year I am heating the entire 30x40 for the same or less $$$.
Yes, I could do it cheaper with gas, however there are a number of factors that prevent me from doing it right now.
70ss
STL Area
Thanks, sounds reasonable to me. I have a 36x48 garage with a small apartment in it thats only 350sq. ft. or so. I only have the radiant under the apartment so mine should be even lower hopefully. Thanks again.
E
E.rodz
st.paul MN.
ok so maybe I have some issues of not leaving well enough alone.after i tripped on some left over alum. diamond plate and started thinking hey this would look good on the radiant system.this is the final product and it woorks great accept the lux themostat wich apeared to be doa.replaced it this weekend and everything works great now.going to try a slab. temp at 62f and we will see how much that costs a month and go from there..now its time to get back to finishing the rest of the shop.thanks to everyone for posting there picts. :thumbup:
72Tunaboat
Snohomish,WA
Nice work ERodz. You did a clean install and the Wall and trim look great. I wish all mechanical rooms looked as sano.:beer:
custom1
Pa
Erodz, That's a clean well thought out system, out of the way in a corner near the breaker panel. I like the diamond plate. I may have to steal that idea for mine. I need to protect the pex from the floor up about 4' to the manifolds. I'll post a pic later of what I have so far.
One thing I noticed about this thread. You have a 10k heater for 650sf and tdkkart has a 7k for 1200sf. How did each of you arrive at the size to use? I haven't bought mine yet, and have about 950 well insulated sf.
And please do keep us informed of the electric cost. I have asked this question before and rarely get details like tdkkart gave above.
E
E.rodz
st.paul MN.
the boiler that I used is a little bigger that recomended but I do live in MN. and if you look close I am trying to plan for the future I am going to add another loop when I add a infloor lift and I will coil some tubes around the lift to just heat the center of the other bay that is 26x30 hopefully that works or the boiler just runs less??? maybe??:headscrat
