Please confirm Mr. Heater Big Maxx wiring
Steve671
Brentwood CA
So I just wanted to confirm that I am using the correct wiring schematic before I connect these wires. I have the Mr. Heater 45k Big Maxx gas heater and the Ritetemp thermostat. Here are photos of the board in the heater, the thermostat, and the page in the manual that I am intending of following. Does this look like the correct wiring diagram?
Thanks,
Steve
Chetter
Northern Ohio
By what I see that should work for you. Wire it just like it shows and then turn the power on and see if the fan will come on when you turn the fan on to manual, it should. Then turn the t-stat on and get the temp up so that it will tell the furnace to start. It should turn the pre-fan blower on and within about a minute it should kick the ignition on. :thumbup:
rickairmedic
louisville ,Ky
Steve it will work fine till that Homie desperate POS thermostat kicks the bucket :D. I keep telling yall honeywell honeywell :D.
Rick
Nvr2loud
Unless you plan on running the fan without the heat, you only need to connect R-W, you don't need to wire to G.
