Snap On TM737 questions
bmwpower
Q1: Can I fit a new style red/black comfort grip handle on this?
Q2: How do I take apart the head to lube it? Seem kinda dry.
Fedwrench
Valley of the sun
on the drive side there is a split ring you can separate with a razor blade or pick. Walk the ring around and the head will fall out. I don't think the handles are interchangable. Perhaps Chadster or MrShaun could clarify.
pmohr
Maryville, TN
Surely you could find someone to trade you for a TH737, what with the hard handle collectors around here. Or just sell it, and buy a TH737.
Zrexxer
Pflugerville, TX
Oh man, why would you take apart a perfectly good holy-grail orange hard handled ratchet to put that new nasty rubber grip on :shocking:
boostedgt
the D
those orange handles were ugly back in the day and they are ugly now!
the yellow and blue/purple handles are a different story:beer:
bmwpower
I know Moose has an affinity for them for some reason :) and I think that guys with the most Snap On ratchets obviously has a couple.
Call me weird, I like the soft grip for some reason. I think it has to do with my hand size and my need for better grip than a smooth metal handle. Call me butterfingers I guess...
Moose-LandTran
The Brink of Insanity (England)
I just find them the most comfortable to use. Love 'em.
Opposite of you, yesterday i swapped this yellow torx handle onto a spare 1/4" breaker bar. Just need a ratchet handle for it now. :)
How much you want for that orange handle?
bmwpower
Depend what a new rubber one will cost and/or if I could even do it.
caper
cape breton
The stems on the soft handle ones are longer than the hard handles.Every soft handle I've taken off to convert to hard handle I've had to cut the stem of the ratchet to make the hard handle fit.Shouldn't be a big deal going from hard to soft.
mrshaun
Killeen - Fort Hood
put it in a vise and use a prybar. sometimes you have to pull on the handle really hard and gently pry it off.
some handles will swap, but you may have to drill out a plastic handle to fit the soft grip and might have to drill the soft grip to fit the plastic. trial and error my friend.
I bet you will be able to do it. I have never had someone want to go from hard to soft. harder is better ( no puns intended there boys )
wellstig1
Torrance, Ca
Do this to it. Works especially well when you are using it as a bit/nut driver.
Merkava_4
Clovis, CA.
You're supposed to put an open end wrench on there first so that the pry bar doesn't mar the front of the handle. I thought everybody had read Moose's tutorials by now..... :headscrat
bmwpower
Dude, I try, but I can't keep up with you guys. :)
I will check out Moose's thread.
Moose-LandTran
To do what?
You can lever it off easy in a vice. (mine isn't even bolted down) and once drilled properly you can tap it on with a plastic hammer. The yellow one i did yesterday was a tight fit and i was pounding it on with a plastic hammer and it didn't leave a mark.
bry@n
Ocean County, NJ
could be any one really. I would prefer to have a hard handle but I'm a little intrigued by the instinct handle.
Can you hook a brother up Moose?
bmwpower
Petty,
So whatchu think? Swap the whole thing or handles?
Bry@n,
Hold tight. I might sell it.
Moose-LandTran
I could probably hook you up with a yellow one, suitable for a 1/4" ratchet. Same as the one i posted above. :)
After making the Instinct ratchet for DaMaN, i was surprised at just how good it feels. I actually do find it very comfortable, i may have to try another one of these for myself. Maybe a 3/8".
bmwpower
Ok, that'll definitely work. Oh well, I guess I won't get to try do the Moose special. :)
Petty, do you need more/better picts? Are you ok as is? It's got a couple nicks here n' there.
PM me and we can exchange info.
mrshaun
Killeen - Fort Hood
I have a press to remove handles, but it weighs a ton and is a pain to put up with it.
I left it on the box once and forgot about it, needless to say that the box on the other side of the truck became a scratch and dent box once I made a left hand turn. scared me to death when it hit that other box. I thought I had run over a car it was so loud.
Moose-LandTran
Got any pics?
mrshaun
Killeen - Fort Hood
the jack is a 2 ton hydraulic jack.
takes about 3-5 minutes to set it up to remove a blade from a screwdriver.
sorry pic is off the cell phone and may show up sideways
mrshaun
Killeen - Fort Hood
screwdriver goes in at the bottom and you let the jack down and tighten the blade down with the gold bolt and then jack it up and it slides right out.
weighs about 25 pounds
