First: These are not cheap. (cheaper than you could buy the material for, but still not cheap)
I have for sale, two super heavy duty extension cords. One 50ft and one 100ft.
The cord is yellow rubber 12/3 SOOW type, which is listed as extra hard usage oil resistant, sunlight and water resistant. These are actually rubber, not the SEOW junk which is an imitation rubber. The jacket on this cable is a bit thicker than your regular SOOW -see the picture of the cut end of cord.
The connectors are genuine Hubbell, with a special strain relief grip to handle the larger diameter cord. These connectors are pretty much the best you can buy, made of high impact nylon and indestructable.
Also available with a yellow rubber outlet box containing two industrial grade nylon face (wont chip or break) duplex recpetacles.
I have not assembled these yet as I dont know what configuration anyone would want. I have 150ft of the cable, the hubbell connectors, and ONE of the double outlet boxes on hand. (I can get more if there is demand). Once someone purchases I will assemble the cable(s) and pack for shipping.
I also have twistlock connectors, 20 amp 125v and 20 amp 250v (L5-20, L6-20 respectively) if anyone needs these with twistlock connectors installed.
Prices:
50 foot - $62.50
100 foot - $110.00
for the double outlet box, add $35.00
Shipping is from Los Angeles, will have to go UPS ground, too big for flat rate box.
Countries of Origin:
The cable is from Europe.
The Hubbell connectors are made in USA.
The industrial grade duplex receptacles are made in USA.
The rubber outlet box and cord grip is made in USA.
Now the pictures:
Prices:
50 foot - $62.50
100 foot - $110.00
Now the pictures:
