Our SuperGrip is similar to SharkGrip, so far I haven't been able to get a good picture of it. I did have a few where you can see the grains, but they were so close up and without any reference to size that they really weren't helpful.
The grains are smaller than table salt, white opaque, and the density is pretty light, so it's just difficult to see, especially if there's any flakes or if the base color is a light shade.
We were spec'ing 0.5 lb per 200 ft2, since that's what is used in a lot of commercial applications, but for residential use I think we're going to go with 0.5 lb per 300 - 400 ft2.
It's good stuff. Although aluminum oxide provides more traction, and is more durable, I think it's definitely overkill for most residential and even most shop applications. A warehouse with heavy forklift traffic, or a floor with constant and heavy grease, sure; but considering that AO is much more of a pain to clean - not worth it. Plus if you ever get down on the floor to work under the car, bare skin to floor contact can result in unpleasant road rash.
I don't see why it wouldn't work in a solvent based coating, but since we deal only with 100% epoxies I haven't had direct experience with it. I do know that it's been used it with our EnduraShield polyurethane clear coat, which had been cut with about 10% solvent.
