Grease Gun Storage
Stephenw
Utah
For this project, I used a short piece of 3" ABS pipe and 2 end caps.
080a721bc43d42dfbab5f5d130cc7312
I used a combination square to draw center lines on the pipe.
da51bf6ca8a941d4bd9827c8bdfebfd7
This picture shows layout lines and the first hole I drilled.
272a2bf7746f479988bd9c57e3d81787
This picture is the finished pipe.
ecec77d6bffb47aa9645405da4e28512
This picture shows the assembly mounted to the center post in my garage. Note that I stood the pipe off from the post using nuts as spacers. This spacing was needed so that the end caps would not conflict with the post. I did not glue on the bottom end cap as I wanted it removeable so that drippings could be periodically cleaned out.
f4d6f8250f3a41d99b178119f070c7ed
This picture shows the grease gun stored inside.
c1bf87e42e87417aa96a3a1ffee6d98d
This picture shows the nozzle installed in it's storage hole. It is a 5/8" angled hole I drilled in the side.
716a2a5b7c1e42438199f3bda386927f
An overall shot. Note that the top cap is installed as a dust cover.
235dd5d00a0c4322ad5f94f3a0ef8c38
A shot of the gun handle.
e850caa241614ad09205a6c99023d2d7
mooman
CHICAGO, IL
Two questions:
1) How did you cut the slot?
2) What are the other holes there for?
Looks cool. I'll do this one fo sure!!
Stephenw
Utah
Two questions:
I cut the slot with a hacksaw. The extra holes were for screwdriver access to the screws holding the assembly to the post.
tigmusky
forest lake minnesota
Two questions:
I would guess the other holes are for mounting.
that's a clean cut slot, a mill maybe ????
very cool, thanks for shareing, I'll put it on my long to do list.
make me up for howdid you cut that slot??
Daye
