Wow, I really like all the features on this Challanger lift. Check out the video. I'm sure it's out of my league price wise, but a lift is nothing to cheap out on. Many unique features like the Sym/Asym. configuration, 3 step extentions, threaded pads with drop in height extenders, remote controls for use while down near the floor, large footprint with gusseted bases(beefy).
http://www.challengerlifts.com/versymmetrictech.shtml
From their site:
"The Versymmetric® Advantage:
•Versymmetric® auto lifts safely and properly accommodate cars, trucks, crossovers, SUV’s and vans all within the same service bay. Their 2 Lifts in One™ lift design is perfect for lifting just about any vehicle within lift capacity.
•The Challenger Versymmetric Plus CL10V3 automotive lift provides open door clearance to driver controls for both asymmetric lifting applications and symmetric auto lift applications.
•The offset 3-stage front arms of the CL10V3 auto lift allows them to be stowed in an asymmetric lifting position, rear of the front tires. When the vehicle is driven through, the front arms make one sweep to the vehicle’s lifting point without having to reposition or shuffle the vehicle back and forth to reach its recommended lift points.
•All Challenger Versymmetric two post automotive lifts feature double telescoping screw pads that adjust to multiple heights to accommodate most lifting points without extra height adapters.
•Challenger designed the first and only two post auto lift on the market with BOTH 3-stage front and 3-stage rear arms. It offers the maximum arm reach and retraction to meet the recommended lifting points of the widest range of vehicles. 3-stage front arms provide maximum retraction for lifting wide body imports with designated outside lift points. 3-stage rear arms provide maximum reach for hitting the lift points of long wheelbase vehicles."
I also like the inground two post lifts...again spendy but nice. I like the fact that there are no posts mucking up the shop when not in use. The down side is that you can not park another car under the lift. My construction will be brand new, so I can consider planning an in ground unit. I also like the two inground Chinese sissor lifts somone here built...really cool and 0 intrusion when not in use...I really like that! Can you tell I STILL am on the fence...sigh.
http://www.challengerlifts.com/CS1020WV.shtml
