Moldy Oldy
Howdy Folks,I just purchased a ceiling hung NG 45K BTU Dornback garage heater in January 2010. It has worked fine for a month then started to flame out and not start. I installed a factory replacement ignitor and the unit ran for about 1 hour. No problems noted during starting and it ran fine and produced ample heat. I turned it off using the thermostate and let it sit for about ten minutes. I restarted using thermostate but unit would not stay running. It went thru its normal three start cycle then shut down. Again the ignitor lit up and fired the gas, the gas burn would last for about 5 seconds, but after 5 seconds the burners would flame out and not remain lit. I heard a click which I think is the gas valve closing then the burner flame extinguished. I also tried to start the unit again this AM and it did the same three cylcle start then shut down. Burners lit but would not remain lit. The main electronic control box was bench tested and passed with flying colors at the factory. Now the troubleshooting really starts...I was informed by the factory rep this AM to try reversing the polarity, the power in black and white wire and let us know what happens. Any info and assistance would be greatly appreciated. Thanks
Russ
Throw the SOB on the floor and kick the **** out of it !!!!
