Displaced Hokie
Finally got around to restoring this 6" 1941 Simplex machinists vise I picked up at the thrift store for $8. Honestly, the dang thing was like brand new once I got to looking at it closely. It looked sort of bad as at some time it was gunked with brown paint over it's original green. The pads are hardly even scratched up!
I also built a stand from part of a factory guard rail I got at the scrap yard for $7.
Here we go...
As found...
Apart and after much scraping and sanding. I had to really scrape around the lettering so it would look good.....
Painting. Colors were chosen by what excess paint I had. Ends up I had a lot of John Deere green. I'm kind of tired of JD green, so I mixed it with some black to make a darker green. I also had two cans of new "sunshine yellow" I bought at Walmart on clearance. So I used these. The red is actually Duplicolor brake caliper paint. It's the hardest, smoothest brush paint I've ever used. Just awesome stuff.
Welding up stand (basically just welding a mounting plate to the top). It's upside down here. The big base was already there, as was the yellow paint. I filled the tube with sand to add weight.
Finally getting some decent welds done. I was pretty rusty. Buzz box (see above photo) w/ estate sale 6013 rods. Again, using what I had...
Welding on threaded studs (more on that later)...
Painting the base...
Final...(some of the lettering is goofy as the letters weren't fully cast)...
And what were those threaded studs for? For extra weight at the base, I mounted two John Deere 50lb rear wheel weights I had. I always needed a good place to store these anyway! This thing is very stable, even with a heavy object clamped in the vise. All total the whole deal weighs 200+ lbs. I may mount it to the floor one day.
Hope you enjoyed the ride! Now she's ready for another 70 years of clamping and bashing!
Hokie
Here we go...
As found...
Hokie
