Built Me A Workbench
strnge
MD
I looked at everyone's workbenches here and came up with my own idea. It was the first one I have ever built. I made the height due to the fact that I am 6'3" in case you are wondering. I determined the height of the shelf by looking at what I needed to store on and under it.
8 Feet long
42 Inches tall
35 Inches wide
Started with this:
And this:
My girls wanted to help:
Final outcome:
This thing is SOLID!!!!!!!!! It weighs a ton!!!
John Timmins
Flagler Beach, FL
Nice clean 4x4s. Around here it's not easy to find them that are not pressure treated.
When those girls are grandmothers that workbench will still be around! :)
Johnnie
That looks great. Currently I have an old crib that is taking the spot of my workbench that I plan on building. I want to make it just like yours except on the bottom shelf on either side I want to install on sliding shelf.
gary300
Riverside, Ca
Now put some electrical outlets above the bench, add a good bench vice and you are all set!
Bench looks a lot like the one I built (42" tall because I am 6'4") except I used doubled up 2x4's instead of the 4x4.
Teken
The Bad Lands
I'm going to ask a silly Q here please bare with me. For the second shelf where the four post meet, is it just the angle the picture was taken or did you in fact cut out a perfect square so those beams went threw there? :headscrat
Unless you simply cut out a square at the end and the legs simply hug against it, please clarify with close up pictures . .
metal1313
clinton NJ
looks like he drilled a few holes and cut out the square for the leg..i like it, and it reminds me i need to buy bolts for mine
TONE
Tek..........
I see what youre talking about and understand your question.
Its hard to tell if he did that in the pix. Kinda fuzzy.
I did do that once, and boy was it a pain in da rump!!!!!
Teken
The Bad Lands
Tek..........
Because if he did, and you did, that has to be the most accurate cut I have ever seen for a make it yourself bench . . :thumbup:
TONE
Tek.........
When I built my bench I framed it out very close to this one. I took the plywood and made little templates of the 4x4 posts.
Just traced them on the plywood. Drilled holes in the corners and jigsawed them out.
I had to pound the plywood down the bench posts. Posts where not exactly square and true.
Once I got it near where I wanted it I build the second shelf, then dropped the plywood onto it.
Worked good, looked good but was sorta a pain.
Crash913
I am planning on thieving this design and I was wondering if two more legs bracing the center would be overkill?
Mike in Ohio
Canton,Ohio
Great looking bench!! Help from short people is always a lot of fun. Job takes 1/2 again as long and is 4 times as enjoyable to do.
sirsloop
Damn... I just tore out the pathetic excuse for a work bench the previous owner put in my garage. I'm gonna build myself TWO of those! HA!
e-tek
Saskatoon, SK
At the risk of making this all about your daughters.....Now I REALLY wish I had girls! My 2 boys would have either hit eachother with the hammer - or me!
strnge
MD
I have 3 vises to choose from:
Which one should I mount?
I am mounting the electrical outlet strip tomorrow.
Mike
strnge
MD
Too much work to do that. I used the cut out sections and cut them again to fit around the 4X4's. Perfect match.
Mike
strnge
MD
No need. I cross braced the underside of the top and the shelf every 16 inches.
Mike
babzog
Eastern Ontario, Canada
Mike
I'd use that big beast on the R hand side... looks like it has an anvil plus it's adjustable.
When I built mine, I put electrical outlets along the front of the bench (idea stolen from this site). Nice to plug in and not have cords dangling over the bench,
jwhcars
Central PA
Nice job you did on building your bench and taking the time to allow the girls to help....you have made more than a bench ....you made a memory.
akdiesel
Wasilla, AK
I would choose the Wilton but do you have the bottom base for it as well, not sure it would work with out it.
gary300
Riverside, Ca
Mike
I like the one on the right the best. From what I can see in the photo, it has the widest jaws and the heaviest handle. Be sure to use all of the mounting bolts. Yep, the grinder is better on a stand alone stand, a lot easier to move around when grinding on a large object.
rrudd2
Petersburg
A piece of fatherly advice...
Do yourself a favor and get this print enlarged and framed, and hang it in your shop. It'll serve you as well as that workbench will.
Seems like just last week, my daughters were 7 and 4. The oldest turns 22 tomorrow. Time flies. Savor and save the moments whenever you can!
volvo
PNW 45th Parallel
Hey..DAD...... How about getting those little helpers their own shop aprons from HD and a starter tool kit to help out dear old DAD.
strnge
MD
:) Sounds like a great idea. Daily they have been asking me to build something else with them.
