Snap on drawer slide part numbers?
bindernut
St. Louis
hey guys, does anyone have a part number for the drawer slides for a KR537? I need the ones that hold the 2nd wide drawer from the top. Both slides are bent, making the drawer hard to pull out/push in.
Thanks,
Mark
mrshaun
Killeen - Fort Hood
537A1500TR 1 Drawer (Top)
– 537A1500TR 2 Drawer (Top)
2,3,4 533BA1900ATR 3 Drawer
5 533BA2000ATR 1 Drawer (Bottom)
– 8-267 2 Offset Runner HD (Dr. 6)
6 537AA1600TR 7 Drawer
– 8-1257 22 Offset Runner, Std. Duty (Drs. 1,2)
– 533DA0100 1 Cover & Drop Front Assembly
– RKKR530 1 Cover Stop Kit
– 533A4001 1 Trim Channel (Left)
– 533A4002 1 Trim Channel (Right)
– 537A0002 1 Lock Bar Assembly
– 531A0311 2 Protective Tip
– 531A0303 1 Lock Bar Guide
– 537A4500B 1 Door Assembly
– 8-1618 6 Guide, Nylon
– 1-976 2 Plug Button
– 8-16337 1 Lock Assembly
– 8-6737-1 1 Cam (Lock)
– 1-1347 1 Lockwasher, 3/4 Internal Tooth
– 8-13637-2 1 Spacer, 3/16" (Lock)
– 8-337-3 1 3/4 - 24 Hex Nut
– 52638 2 Drawer Remover
– KN450ASV 1 Nameplate
maybe this will help
Rusty32
Iowa
ive got a whole box of nos snap on slides i bought once for whatever reason i probably have some for cheap if you have a problem getting them replaced
mrshaun
Killeen - Fort Hood
i show they are still available at 6.80 each and 1 in stock at my DC, I bet there are more at other distribution centers though.
Vinko
Los Angeles
I just bought these. I thought there was one other number my driver sub'd for something else that fit better on certain drawers. I gotta check.
Shaun: the info you have is more complete than the SO website. Is this info on your truck computer or an older parts catalog? Just curious... I covet my drivers collection of every scrap of paper catalog and publication from SnapOn for the last 50 years or so.
Some of those parts that we've tried to order on the 537 like the lock bar assembly is out of stock.
What exactly constitutes these two parts above? As simple as the names would suggest or more parts to it than that?
What about these two things?
Protective tip? Lock Bar guide is I assume what feeds the bar on either side?
What about these two?
Also I found out the original metal inset into the recessed lower portion of cover was aluminum per an old timer at SO not stainless as I had thought.
I'm having some stainless cut to spec if anyone's interested. In OEM finish, which appears to be #5.
jerrydratliff3
Hawaii
I cleaned out an old warehouse last week, and found an old red tool box. The lock is broken off. The top drawer is missing, and the only way to know what it is, was by looking at the drawers. I'm planning on refurbishing it as much as i can to make it useful, but I can't find this tool box any where. Its a 7 drawer, looks like it had a top at one time or another. The drawers come off by pushing one clip up, and the others side down.
