DavidB
I'm back again with another round of pictures of wrench contact points. This time I have a lot of 13mm wrenches. Most of the images are of the box ends but since some of the wrenches have a non-standard open end I decided to show some of those too.
As before, here is a group shot of all the wrenches:
From top to bottom are the following wrenches:
1.Snap-On SOEXM13 (USA) – New, graciously loaned for the test by Chadster1
2.Wright 12-13mm (USA) – New, graciously donated for the test by TRTOOLSUPPLY
3.Craftsman Pro 45992 (USA) – Lightly used, purchased last year.
4.Craftsman Raised Panel 12 pt (USA) -V inverted V - 42917 – Used, from late 90s
5.Craftsman Raised Panel 6 pt (USA) -V inverted V – 42870 – Used, from late 90s
6.Craftsman Raised Panel 12 pt (USA) -VV- 42917 - Used, from my grandfather
7.K-D 63515 (USA) – New, graciously donated for test by QuattroJon
8.Facom 40R.13 (France) – New, graciously donated for test by QuattroJon
9.Metrich (Unknown) - New, graciously donated for test by QuattroJon
10.Signet (Unknown) - New, graciously donated for test by QuattroJon
11. Kobalt Stubby 22989 (USA) – New
12.Gear Wrench Ratcheting Stubby (China) – New
13.Pittsburgh Stubby (India) – New
Here are some close up pictures of the wrench box ends on the same fastener. The top picture shows the wrench in the “down” position hanging by it's own weight. The bottom picture shows the wrench in the “up” position where I am holding it up so it is tight against the fastener. The nut in these pictures has distances between the flats of of 12.78mm,12.78mm, and 12.79mm. These pictures will hopefully show the fit of the head on the nut.
1. Snap-On
2. Wright
3. Craftsman Pro
4. Craftsman RP 12 pt
5. Craftsman RP 6 pt
6. Craftsman RP 12 pt Older
7. K-D
8. Facom
9. Metrinch
10. Signet
11. Kobalt Stubby
12. Gear Wrench Ratcheting Stubby
13. Pittsburgh Stubby
Here are the pictures of the wrench's imprints on the nuts. These nuts are Class 8 and from McMaster-Carr. The part number is 90591A161. Dykem layout fluid was used this time instead of a Sharpie marker. The test wrenches were placed between two pieces of wood in a vise with the box end out. A bolt had two nuts placed on it then a washer followed by the test nut. Each test nut was torqued to 27 ft-lbs using a Harbor Freight torque wrench except the 10 Signet wrench. I was unable to find a secure way to hold it in the vice for testing. Instead I placed another wrench in the wise and torqued on the test nut with the Signet. Hopefully, it was torque similarly to the other nuts.
As a generalization, the wrench imprints are smaller than in the previous tests because the nuts are harder that the others used in my tests in the previous posts. Two nuts were tested in each wrench and the best imprint from each has been pictured.
1. Snap-On
2. Wright
3. Craftsman Pro
7. K-D
8. Facom
9. Metrinch
10. Signet
11. Kobalt Stubby
Once again, I'll leave you to draw your own conclusions from the pictures.
Since wrenches #1, #8, and #9 had non-standard open ends I thought I'd post some pics of them.
As before, I'll show two pictures to show how the wrench grips a fastener. The #1 and #9 wrenches are hanging by thier own weight in each picture. The #8 wrench is held in the clockwise direction in both of it's pictures.
1. Snap On
8. Facom
9. Metrinch
Here are some pictures of the imprints on the nuts. The first picture shows the top imprint and the second picture shows the bottom imprint. I define top and the upper part of the wrench shown in the first picture of the open ends above.
1. Snap On
8. Facom
9. Metrinch
Thanks goes out to Chadster1 and TRToolSupply for sending wrenches to be tested. Even more thanks goes out to QuattroJon for supplying wrenches and continuously encouraging me to do the test.
Sorry if some of the nuts aren't centered in the pics. I automated the process to crop and resize them since there were so many. I also apologize for bogging your internet connections down with all the pics...but hey, you were warned.
Enjoy
1. Snap-On
2. Wright
3. Craftsman Pro
7. K-D
8. Facom
9. Metrinch
10. Signet
11. Kobalt Stubby
1. Snap-On
2. Wright
3. Craftsman Pro
7. K-D
8. Facom
9. Metrinch
10. Signet
11. Kobalt Stubby
1. Snap On
8. Facom
9. Metrinch
1. Snap On
8. Facom
9. Metrinch
Enjoy
