slopecarver
So I've aquired this compressor from my gramps, it is a 2hp 30gal Speedaire. I've been having some problems getting it working properly. It would pump up the tank to about 40psi then either stall out or spin the drive pulley on the belt, this was in 110v mode on a 20amp circuit. It would also have problems starting up when there is air in the tank. Would it be better to retrofit a v-belt drive? Is there something wrong with the motor, it seems like it just doesn't have the power. Who in their right mind would have a 24 amp 110v circuit? I have an old Master brand motor 3/4hp at 1725 rpm, if I were to set it up with the correct speed reduction would it work?
