Snapon Flex Head Speeder Ratchets; discontinued why?
billymade
New Mexico
I recently picked up a used 3/8" Flex Head Speeder Ratchet FSLF936; I am finding it to be really useful and love it! Why did they discontinue these and do you dealers think they will bring them back in a dual 80 configuration?
48548
Phoenix
Look at the pictures of mine, I put dual 80 heads on them and the one FSLF936 has a made in USA head on it. Also one of the TSLF936 I am waiting for a kit to make it a compact 3/8 since they are rated for 90 lbs or torque should be good to go... Now you should covert the head over and you will love it even more.
billymade
New Mexico
48548, did you order the head as a replacement part or just swap out new ratchets? What did you do with the old 900 series heads?
bchee, here is the propaganda from Snapon when they came out in 2002:
New Flex Head Speeder Ratchet from Snap-On Offers Maximum Versatility In Removing Fasteners
KENOSHA, Wis., Dec. 4, 2002-Snap-on Tools Company has introduced the new 3/8-inch Flex Head Speeder Ratchet to offer technicians speed, flexibility and reach to remove fasteners in a variety of situations. The new ratchet easily adjusts to be used as a speeder to turn fasteners even faster.
The Flex Head Speeder Ratchet (FSLF936) features a flexible head that can be positioned in a range of angles to adjust hard-to-reach fasteners. The new ratchet has a narrow head profile to help technicians maneuver and reach into tight spaces.
Technicians can adjust the head and handle of the ratchet to a
90-degree angle and use the tool as a speeder to complete jobs
quickly. The speeder provides the fastest way for technicians to manually turn and remove fasteners.
The gears of the Flex Head Speeder Ratchet provide smooth action and require little movement to engage subsequent gears, which is useful for areas with limited access and little space to move. The bent handle of the ratchet provides maximum leverage and knuckle clearance during ratcheting.
The Flex Head Speeder Ratchet is 13.75-inches long and has a speeder radius of 2.62 inches. It is made of precision one-piece forged steel and contains a high-strength internal mechanism with a 36-tooth gear. The patented (4934220 and 6125722) sealed ratchet head keeps dirt out and lubrication in for long, trouble-free life.
The fact that it is a speeder, flex head and ratchet make it very useful!
48548
Phoenix
You can't order the heads, so I have a dual 80 and 2 tf72's with the 936 heads on them. I also have another FSLF936, but it still has the 936 head on it. I wish you could order the heads and that would have solved the problem for me.
Bart Simpson
