Electrolysis resto of a morgan vise(lots of pics)
06wt
chicago 434 UNION CARPENTER
heres the morgan 50 wen i got it, i used 2 power supplys from computers as the DC source, if anyone has questions on electrolysis just post ur question so everyone can see it. as for now im assuming most on here know about electrolysis rust removal.
after sum wire brush
06wt
heres the dynamic jaw after electrolysis bath
and the static jaw before and during gun blueing, i gun blued the whole thing but i only took pics of progress on the static jaw
heres the handle during blueing and held up to bare oiled steel to show the contrast
06wt
I dont! lol and it has intrigued my little engineering mind! how is it done?
ill give ya a quik explanation, but google electrolysis rust removal and u will have all the info you want, but basicly u use DC power, the part being cleaned is -/black/ground/cathode and a piece of steel u use as an anode is +/red/hot/anode
wat u want is low voltage high amperage, thats y i use computer power supplys cuz i can use the 5 volt wires and get 30 amps
as the electrons flow from ur work to the anode they pull all the rust off as the flow out of the work, leaving ur work clean and not removing any good metal.
when u take ur work out of the eectrolysis bath it will be covered in black oxide just like industrial tools, use a scuff pad to remove the oxide and u have clean shinny steel underneath
chevyboy91188
Tampa, Fl
ahh i see, makes complete sense I never thought about that I am going to have to try that now on my coil springs that are really rusted
KCarGuy
50 miles outside Chicago, illinois
Great Job! I am amazed at the before and after photos.
I have a Morgan Chicago 40 and I have been using it for over 25 years...Its a great vise!
Mine is painted Chevy Orange, but I do love that natural look!
Stuart in MN
Minneapolis
just gun blue and oil, it will look just like it does now for years to come, just rubbing it down with oil every once and a while
I really like gun blue for this sort of thing, I've used it on a number of items myself with good results.
06wt
its good for fragile parts and parts you dont want to remove alot of metal from, also good cuz u can set it up and leave it alone while you do sumthing else
Even 11
Colorado
Noice!!!! I gotta get an old vice, suddenly my newish wilton and mini columbian is nowhere near as cool!!
-Dane
jam022316
Indiana
Man that's awesome. I didn't know that was possible. I'll really be doing some research on that now that I see how well yours turned out!!
06wt
yeah the jaw was so abused that there was material smashed over the screws, so i just drilled them out and ill use new hex head harware , didnt get to makin the jaws today, mayb tomorrow, i did get the material to make them though
06wt
i use potassium hydroxide(koh) works the best and the fastest, but sodium hydroxide(lye), sodium carbonate(baking soda), sodium bicarbonate (washing soda), will all work, any alkaline solution will work
mjozefow
Lafayette, IN
I was under the impression baking soda would not work. Go figure. I like washing soda due to it's mild nature. Lye works well too.
LoneGunman
The Gunshine state
I'm sure some of you are aware of this but some of you may not. Do this in an open garage or someplace with ventilation, hydrogen is formed as part of the process. Sodium hydroxide (lye) is nasty stuff, wear a face shield. ALWAYS add the sodium hydroxide to the water and beware of the exothermic reaction when you do. The amount of sodium hydroxide used in electrocleaning is usually not enough to get the water too hot upon mixing, if someone decides they want a strong cleaner and dumps a bunch of sodium hydroxide in the water the water can boil from the exothermic reaction, I KNOW it can happen as I have done it
Do not use stainless steel as your anode as recommended on some forums, doing so contaminates the solution with hexavalent chrome which leaves you with no legal way to dispose of the solution, the feds don't play when it comes to hexavalent chrome.
Professur
Mo-Ray-Al, K-bec, Ka-Na-Da
A 6' kiddie pool works well for this sort of thing. Or one of those plastic sand boxes that have a cover and look like a giant bug. The sand box is good if you're going to keep the soda mixture for repeated use. Naturally you don't want to do this covered tho. The gases given off aren't fun. But you really need to make sure the kids know not to go swimming in 'your' pool. The sand box again is a good one, since you can attach hasps to secure it.
red92s
Regular ole Arm & Hammer baking soda in the yellow box works just fine, is cheap, and easy to find in any area of the country. Maybe not as potent as other choices, but you can dump it right into the grass when you are done.
06wt
hexavalent chromium is produced during electrolysis when using a stainless anode. there is no real benifit to using stainless steel anode for rust removal, but thoose who are making hho generators ita big plus cuz the anode lasts alot longer, but if you want to use
stainless as an anode you will produce hexavalent chromium, disposal of the solution can be done at home. you need to lower the ph of the solution by diluting it with water, at ph levels of 2-3, you add 3lbs of sodium metabisulphite for every 1lb of hexavalent chromium, this will create an inert solution that can be safely disposed
but as tool guys de-rusting tools there is no need for stainless anodes, plain mild steel works just as good, but the more surface area the better on the anode side, the electrons will flow in the path of least resistance so you have to surround your work with anode/anodes
autopts71045
Illinois
Hi, I don't know if anyone mentioned it, but there is a good chance replacement jaws are still available for your Morgan from Milwaukee Tool Co. When you call, your call goes right into the factory and they will want dementions. They even sent me a catalog with price sheet. They are nice to deal with.
06wt
they did come up when i was searchin, but i havent called them yet i will, what # did you use to contact the factory?
