W.I.P.
Guys,
I'm not an electrical code guru so I call upon you for some help. I've searched around and although there seems to be a lot of info out there i've found conflicting answers on this. I'm pretty sure I need a to drive a grounding conductor into the ground for my detached garage. The question is what is the proper way to hook it up? It's a 50amp 220V feeder with 4 #6 wires, Black, Red, White, and Green. I know the black and red are the 2 separate phases of 110V and the white is neutral. I have these hooked up correctly in the sub panel already. The neutral and ground bar in the sub panel are isolated from eachother as I think they should be for my situation.
There is also a gas line running from my house to the garage so because of this I can't just use the green ground conductor included with the feeders as the main ground. In this situation I need a grounding electrode at the garage correct?
So what I'm thinking I need to do is install the grounding electrode at the garage and run a #6 conductor from the electrode to the ground bar in the sub panel. Do I still need to hook the green wire coming from the house to the ground bar as well?
